The only problem i had at the MOT was with the brakes. The difference was only about 2% on each axle, just the machine showed that something wasn't true and didn't let it pass. They're brand new drums as well, so i thought it was strange. When testing on the first drive i noticed that the brake pedal pulsated slightly when braking, but thought it would wear away with use. So luckily they let me fix the problem and had it ready the next day. I took it to a turner to get them machined. He said two of the drums braking surface was a bit 'ripply' but surprised him it caused problems. I could feel the difference though when braking again: much smoother, pedal goes in slightly more now and still pulsates just slightly (handbrake also finally works now, 5 clicks and it stops the wheels dead
) Paperwork was a bit of a pain but got that sorted too. Only need a slight tweak on the carb to get a good CO at idle (high at the moment)...
Managed to get the steering mech. sorted, had to put it together twice as it leaked oil even with new gasket paper, so the extra gasket paste fixed that
Just did a wheel alignment on it too as i just threw the front suspension together. No wonder i could hardly keep the car striaght. Had a toe of +3 deg on the front right and +1 deg on the front left
Only the front right castor was a bit off (+6 deg instead of min. +8) but probably due to having new bushes. The rear toe worried me a bit as it was -19 minutes instead of +8 minutes on the left and -8 min on the right... i'll just keep an eye on the tyres as it handles well. The rear camber is larger (+3 deg.)
Only have the roof lining to do... i'll try to get good shots of the car in a better environment:)
Well that's it from me at the moment, very happy and managed to also reach 105kmh the other day, had a approx. 45km trip today so very pleased
