Author Topic: Well here it is  (Read 28365 times)
Thought i'd finish in a few words...
« Reply #75 on: February 12, 2011, 09:39:04 PM »
Hello, just had a look at my old thread and thought i'd end it properly  :D
 Well, I've done 1415km since its roadworthy and it's basically been used  daily, mainly city driving without a problem since. It even started immediately in -10 deg. C weather so i'm very satisfied with it. Haven't been able to properly check its fuel consumption with all this cold starting and city driving (got around 13l/100km  :-) but i do plan on going for longer trips once the weather gets better (very dirty now, haven't washed it since last November  :oops:). As usual with winter weather driving, i get fogged up on the inside quickly and the water condensation on the inside of the window sometimes freezes as well  :o
 Anyway, managed to stop the small leak from the sump as it leaked after i had put gasket sealent onto it. It leaked from 4 bolt holes so i put some gasket sealent onto the bolt threads and it has stopped (won't be surprised to see a tiny amount between oil changes). Has gone through its fourth half axle rubber boot, checked the oil level in the gearbox and it was just right. Noticed a small leak from the gear linkage shaft on the gearbox (even though i changed the shaft o-ring seal) but there's a larger leak coming from the speedometer drive so i plan on changing that as it's coming out on top at the cable. Also replaced the oil filler cap as well (nice and shiny now). Just the other day when greasing the kingpins did i see a thin film of oil around the bottom lid of the steering mech.  >:(, still better than what it use to be (the oil ran all the way down to the left outer ball joint  :D)
 Only needed to replace a headlight bulb (it was an old Tungsram one :() and the 75W bulbs I'm using are really good. Bought a pair of snow trays just in time for the snow fall at the beginning of winter but i still have damp carpets on the drivers side from the melted snow and water off my shoes in the rain(even under the drivers seat...).
 Managed to sort the doors just before autumn. Got out a polishing disc and paste and attacked them. Took me a while and had to push the bugger a fair bit but they turned out nice in the end, especially the two doors. The bootlid still has some greyness here and there. Washed it, waxed it, cleaned the windows and interior, bumper sprayed the bumpers and used some tyre spray.... it looked like new 8)
 Also bought a grease pump in the meantime as kingpin greasing is a frequent servicing activity. Bought some nice Lithium based 00 grease and in it went (just like having power steering  :P)
 Still need to make a roof lining for it. Was thinking of getting a 2mm thick sheet of polipropilane and glueing the carpet onto that (it's more flexible than the plywood i had originally and managed to ruin when fitting  >:().
 Will be doing a checkover at about the end of March (checking cylinderhead nuts, carb, valve clearances and points) till then it's  **- Will have photos of it nice and shiny in the sun soon (hopefully if weather permits) 8) and will keep an update in pictures especially of the journeys i have in mind....
 Well, the end  [-/
« Last Edit: February 12, 2011, 09:52:06 PM by GTMaster »
green-fly
Re: Well here it is
« Reply #76 on: March 15, 2011, 09:25:03 AM »
Hi,just read whole story,! Great work,well done ..wish I had your skills! Car looks great..enjoy it,cheers,brett
Dyzel
Re: Well here it is
« Reply #77 on: April 18, 2011, 05:07:37 PM »
Since then I've bought a MIG welder and got into doing body work. The front I've finished (just minor welding here and there), so no holes there :)
Now on to the rear right wheelarch. Real nasty.
After that I'll be pulling apart the whole front suspension. There's some holes right next to the upper arm on both sides.
Then it'll be over on to the fenders and sills. That will be the challenging bit.
How much cost in UK this new  threshold and wing. at last foto. Thank you sry for english words ,hard to find technical phrases :)
« Last Edit: April 18, 2011, 05:10:28 PM by Dyzel »
Re: Well here it is
« Reply #78 on: April 18, 2011, 07:38:17 PM »
[/quote]
[/quote]
Don't know the cost in the UK (i'm not from the UK), i bought these panels new from Axel Gerstl (the two new sills and two new fenders were 60 euro back then + postage, though it cost me more since i ordered the wrong fenders (which also cost more than the ones i needed in the end) and had to send them back at my expense...). The fenders are cheaper from 126fan.sk and another advantage is that their postal services are cheaper too. Though i do have to mention that i was 100% satisfied with Axel Gerstl's service (they also have lots of stuff for the 126 and Fiat 500).
The current prices at 126fan.sk are:
fender: 16.50 Euro
sill: 11.90 Euro
The current prices at Axel Gerstl are:
fender: 23 Euro
sill: 12 Euro
« Last Edit: April 18, 2011, 07:51:52 PM by GTMaster »
