Author Topic: Well here it is  (Read 28392 times)
Re: Well here it is
« Reply #30 on: January 05, 2010, 11:50:06 PM »
 I can only say, what has already been said.
 Jo munka!
Re: Well here it is
« Reply #31 on: January 06, 2010, 12:15:07 PM »
Köszönöm for the kind replies :) I am planning to get to work on it when the weather warms up a bit and also go to the local wreckers next week to have a look around. The guy there has quite a lot of bits and pieces so i'm sure i'll be able to acquire most of the things needed.
Re: Well here it is
« Reply #32 on: February 10, 2010, 10:23:57 PM »
Just a minor update: got a few bits and pieces so won't be getting anything until i start putting it together after painting. Got another drivers seat which i'm happy about as it looks like new :)  Stripped the old seat kept the springs and covers with the sponges.
Stripped the doors of the windows and locks (locks will be hard to put back in i think) and also put tar onto the floorpan where it was repaired. The only other thing i did was remove the gearbox, cleaned it and inspected what needs changing. Drained the oil which was clean but not alot :o The new half axle rubber boots i have but the input shaft is wobbly so looks like i'll have to take off the bell housing. Needs a new release bearing and release bearing fork shaft. I also intend on changing all the seals.
« Last Edit: February 10, 2010, 10:27:33 PM by GTMaster »
Re: Well here it is
« Reply #33 on: February 10, 2010, 10:26:03 PM »
Pics...
Re: Well here it is
« Reply #34 on: February 10, 2010, 10:26:33 PM »
Box
Re: Well here it is
« Reply #35 on: February 10, 2010, 11:31:17 PM »
youve done alot already!
whats them black stuff? seam sealant?
Re: Well here it is
« Reply #36 on: February 11, 2010, 09:05:45 AM »
That black suff is this tar insulator that they use in the building industry to insulate bricks and concrete. They come in big rolls and have plastic on them, which i think helps adhesion. I measured the size i needed to cover where the factory insulator was, since i had to cut it out when repairing the rust. I used a hot air gun to melt the underside of the tar strips, pushed it onto the metal so there wouldn't be bumps or air underneath it, then let it to cool. It's stuck on there well so i hope it won't come off :)
richk
Re: Well here it is
« Reply #37 on: February 11, 2010, 09:27:42 AM »
That black stuff is called Bituthene. I use it a lot at work for damp proofing underground stuctures like cellars. First paint the surface with a bitumen based primer maybe thinned down with a little solvent, then the Bituthene bonds on contact and believe me it's NEVER coming off again, so be sure to get it right first time :oops:
Re: Well here it is
« Reply #38 on: February 11, 2010, 08:25:15 PM »
Thanks for that, didn't know what it was called. I did paint the metal underneath it but it's just basic glossy green paint.
Re: Well here it is
« Reply #39 on: April 12, 2010, 08:31:28 PM »
Thought i'd "fill" in on what i've done since. Exactly that: filling. I can't say i'm a pro when it comes to welding but puttying requires the talent  of a sculptor  :) There won't be the big gaps between the front fenders and the front panel as i had to spot weld there as well. Anyone know good tips when it comes to puttying?
I  removed the gearbox and since have reinstalled it. I changed all the seals, fitted it a new input shaft and bushing, release bearing, half axle rubber boots, gearbox rubber mounts and filled it up with Agip 80w-90 oil. Also painted  the remainder of the chassis and sprayed it with underbody spray.
Hopefully i'll be getting a new breather pipe for the petrol tank and will be able to fit it this week.
Just cleaned and resprayed the thermostat housing and used a hot air gun to test the thermostat (which seems to be in working order).
I really hope that i'll be able to take the car off the blocks this weekend and roll 'round with it in the yard. One thing that bothers me is that the steering mech has started to leak oil  >:( So looks like i'll be taking that off when the car gets finished and will have to change all the seals...
Test run
« Reply #40 on: May 02, 2010, 08:13:51 PM »
Will have photos soon. Got it off the blocks and fired it up without the exhaust  ;D :) I fitted the old exhaust back and  went around the block with it without the doors on so it was a bit "breezy".
Re: Well here it is
« Reply #41 on: May 02, 2010, 08:20:17 PM »
I was wondering whether anyone experienced something similar to what  i did today. I fitted new shocks to the front and noticed that when the wheels are on the ground and i start to shake the front wheel i can feel something wobble and it seems to be the shock absorber . I've checked the wheel bearings twice, the kingpins were renewed so it came as a surprise. Hopefully it won't effect the driveability of the car...
gsxr126
Re: Well here it is
« Reply #42 on: May 07, 2010, 10:37:24 AM »
yeah i had the same problem when i fitted a different leaf spring, rack, control arm and stub to the drivers side. I still cant explain it. At 55-60 kays the front end wobbles pretty badly. I drove it like this for about 50 kays thinking it was the leaf spring needing to settle but no luck in curing the prob.
The gearbox sh#t itself after about another 10 kays (not related i think) so i havent had a chance to road test the new shocks i put in yet.
sorry i cant help much and i hope you dont have the same prob. i'll be fixing the gearbox this weekend and hopefully road test and let you know
Re: Well here it is
« Reply #43 on: May 08, 2010, 03:20:13 PM »
when you replaced the shocks on the front did you renew the rubbers and make sure that the bush was seated properly its very easy to forget the first rubber which sits under the body and betwwen the shock this can make it move around.
Re: Well here it is
« Reply #44 on: May 08, 2010, 10:15:53 PM »
I suffered a simliar sound caused by an old set of shocks with worn thread. The nut could not be tightened correctly, as a result there was some play which cause the knocking noise. Ties in perfectly with what bis13 said. After checking that:
I assume when replacing the shock you simply unbolted te old then bolted in the new?
If not have a thought about anything else you may have unbolted/ rebolted in the process.
