Author Topic: Well here it is  (Read 28364 times)
Well here it is
« on: November 05, 2008, 05:46:23 PM »
Here's my Olive Green 126. It's been off the road for sometime, but it still started up like before :) Funny thing is, everything still works on it, just not all smoothly. I plan on putting it through a complete restoration to factory spec. I have some of the needed funds, but my biggest problem is lack of tools. Parts aren't expensive, but tools are :) So, it'll probably be early next year that i'll be getting into it.
For now, i've finally found space in the shed. It's been out under the stars since the roadworthy expired. I hope that now it's in a dry place that it'll stop rusting :) As you can see where it's painted there's rust, and under the carpet on the inner arches. The rest though is fine. It'll get a new paint job, fixed up interior, front suspension needs a total overhaul. The engine on the other hand runs fine. Just a big end crank seal is needed to stop the oil leak. The rest is just fine tuning of the carb and ignition points, valve clearance etc. The gearbox needs a check. The half axle rubber bells are ripped, the clutch will be checked, but that was changed not long before we stopped using it. All in all a big project, will post more pics as time progresses :)
Well here it is
« Reply #1 on: November 05, 2008, 05:50:52 PM »
I tried everything to stop the rust. I used PU foam in the holes (cavities more like :) ) and loads of paint. I knew it would only be a temporary solution, cos that wouldn't be the way to go. I still have the number plates, just that it's been temporarily 'off the road.'
Well here it is
« Reply #2 on: November 05, 2008, 05:55:32 PM »
Le enterior :)
The powerplant
Well here it is
« Reply #3 on: November 05, 2008, 06:26:44 PM »
Good luck with the project! What year is the 126? from the look of the interior and the bumpers ita an earlier model?
Just have one idea, when you go restoring the inside of the car, try some other colour other than blask (soo booring and sad...)
heres an how id go with an old school style...  :D ::
or try some of the other orig trim colours... (you did say youre going factory spec, so this is, in my opinion, the way to go....)  :wink:
either way you go about this, best of luck!  :smt023
nrg19uk
hahaha
« Reply #4 on: November 05, 2008, 08:43:20 PM »
im loving the green colour! good luck with the resto.. keep us updated.
thats the interior in my new deville i brought, brown cord cloth its horrid its gone all dark i should imagine it looked nice in its day thoe.
does anyones push button washer work? and how affective are they>??
Neil gargaro
Re: hahaha
« Reply #5 on: November 05, 2008, 09:34:33 PM »
Quote from: "nrg19uk"
Mine has the electric motor pump, works ok...
im surprised fiat didnt use the principle used on the vw bug, in the bug, air pressure from the spare tyre is used to push the washer liquid... simple yet effective solution, mugh better than that button...
Well here it is
« Reply #6 on: November 07, 2008, 05:32:48 PM »
Yeah those vacuum operated window washers do work if the button isn't broken. Mine is, so i get more  washer fluid on the floor than on the windscreen :)
It's a 1986 FSM. Just wondering: it's the basic level trim version, but the rear bumpers have space for the reverse and fog lights. Did they come with bumpers without the cutout for the lights? The bumpers i know of are:
Chrome, these plastic types which were on the 1989 even some 1990 models, BIS bumpers and the big type bumpers(1990 onwards). Any other types?
Thanks for the tips CroBis, though i'll probably stay with the vinyl. I don't think i'll have that much money to change the trim.
About the trim: has anyone ever taken out the roof carpet? Mine's sagging in the middle, which takes away alot of headroom. Doesn't seem too difficult, but if someone has a good technique, then i'd be obliged :)
Well here it is
« Reply #7 on: November 07, 2008, 06:02:20 PM »
As far as i know there were 3 types of bumpers; the big plastic ones on newer aircooleds and BISes, the metal ones (Cheaper saloon modells) and the ones you have (better trimmed DeVille models) this applies to original FIAT 126es, dk about polish made ones....
as for the headlining,, i just ripped mine out, though its easier on the bis (using the rear boot door)... shouldn't bee too difficult....
phreak97
  • Niki!
Well here it is
« Reply #8 on: November 08, 2008, 12:53:04 PM »
i'd love an early 126, they started in '89 here, theres no variety at all:(
as far as fixing the ceiling, i found out you can move the whole thing around a bit when mine was falling down at the front (it had moved away from the edge and wasnt being supported anymore), you can probably push it around so one side and the front fall out then slot the rest out after that, but if you just want to glue it back up, get a hypodermic needle from a chemist or somewhere, get a drill bit that's no bigger than the needle, then drill holes where you want to glue and inject the glue up through the holes. if done right you'll never be able to see the holes, as theyll be too small (less than a mm if youre good).
in most cars you dont need to drill through, you just stick the needle through, but a 126 ceiling is really thick, you can try just sticking it through first though, itll have a better result.
obviously youll need to choose a watery glue, preferably fast drying, because holding your arms up in the air for any length of time isnt so comfy. but above all it needs to be pretty strong.
good luck!
phreak97
Re: Well here it is
« Reply #9 on: January 10, 2009, 08:20:14 PM »
Just thought i'd write something, just that i haven't been able to do much (it is quite cold afterall :) ). I'll post pics of it soon, since then i've disassembled the lights,bumpers,some of the interior, nad door trim. I've ordered body parts from Axel Gerstl, and hopefully they'll be here by the end of the month. I think the hardest part of this restoration will be the repair of the bodywork and painting. Replacing missing trim bits and other accessories won't be a problem, and overhauling the suspension will seem to be an easier task than this. Anyway, waiting for the weather to warm up a bit :)
Re: Well here it is
« Reply #10 on: February 28, 2009, 01:18:58 PM »
Pics will be coming, but this weather doesn't seem to warm up :) Since then I've totally taken out the interior,except the dash (the roof lining i ripped out ,it was very brittle, and hopefully i'll either be able to find a new one, or make another one). Took off the bonnet, boot lid, door seals and started 'hole hunting'  ;D
Quite a lot of rust, and got rid of most of the PU foam that was in the holes. The inner door sills don't look too good, but it will be getting new outer sills :)
Bought some tools, and some time soon i'll be getting a MIG welder.
Re: Well here it is
« Reply #11 on: April 17, 2009, 08:18:33 PM »
Haven't been here for some time. Here are some fairly recent pics ('bout 2 weeks ago.)
Re: Well here it is
« Reply #12 on: April 17, 2009, 08:28:17 PM »
Since then I've bought a MIG welder and got into doing body work. The front I've finished (just minor welding here and there), so no holes there :)
Now on to the rear right wheelarch. Real nasty.
After that I'll be pulling apart the whole front suspension. There's some holes right next to the upper arm on both sides.
Then it'll be over on to the fenders and sills. That will be the challenging bit.
« Last Edit: April 17, 2009, 08:30:11 PM by GTMaster »
Re: Well here it is
« Reply #13 on: April 17, 2009, 08:41:32 PM »
keep up the good work  [-/
Re: Well here it is
« Reply #14 on: May 28, 2009, 07:55:05 PM »
Well, done quite a bit since then. The front right fender is off, and so is the right sill. Just rebuilding the bottom half of the inner sill as it was totally corroded. The front right suspension is out. Since i'll be pulling apart a lot of things, i'll be replacing a lot of parts, whether they're good or not. The  brake line nut was so tight, i pretty much ruined it, but i'm sure i'll be able to tighten it properly again.
Finished the rear right wheel arch as well. Just can't wait to get it going again, cos i really,really want to drive it :)
