Author Topic: Well here it is  (Read 28364 times)
Re: Well here it is
« Reply #45 on: May 09, 2010, 07:44:29 PM »
Thanks for the replies.
I renewed the shock's rubber bushes. It sits in a metal plate which i had to sand the sides off a bit (more oval shaped now) so it would sit  properly into the top of the wheel hub.When I tried to fit it  the plate didn't allow the thread of the shock to pass through enough so i could catch the nut onto it. I'll try and see if i can tighten the top and bottom nuts more, but i tried moving the shock cylinder itself by turning it and it doesn't seem to budge. I fitted new bushes in the wheel hub and leaf spring eye and i tightened the leaf spring bracket as well (new as well.)
If nothing else after the wheel alignment i'll just leave it as it is. I didn't notice anything when test driving it, but then again the tyres were fairly flat and it was a bit loud  driving with the doors off :)
« Last Edit: May 09, 2010, 07:48:28 PM by GTMaster »
gsxr126
Re: Well here it is
« Reply #46 on: May 13, 2010, 08:59:33 AM »
Test drove the car and the wobble was still there. Put it on the hoist (again) and found that the leaf spring bracket bolts werent tight. Then i noticed that the spring bolts/pins had pulled thru the chassis. I probably made it worse by driving it, but now i'll have to weld them up and try again.
Re: Well here it is
« Reply #47 on: May 13, 2010, 06:46:37 PM »
Sorry to hear that, must be a pain to repair  and a wheel alignment check may be needed just in case the suspension geometry changed. I bet you're a bit  >:( right now ....
gsxr126
Re: Well here it is
« Reply #48 on: May 15, 2010, 04:07:17 AM »
Not too p*ssed, just part of owning a 126, but i guess the accident didnt do it any favours. It really was a good car before it got nicked and in the 72 odd hours of ownership before it happened.
I cant wait to get my other 126 sorted so i can start driving it.
If you've renewed practically every rubber in the front end she'll drive like a beauty, once you get air in the tyres and a couple of doors of course. The one reservation i have about the std front end is the top a arm sits at a bad angle at std height and causes the wheel to lean positive on compression. Noy what you want really
Minor update
« Reply #49 on: August 01, 2010, 09:01:56 PM »
Not much happened since. Just haven't had enough time  >:( It's been primed but needs sanding and shifted it from the stable to the garage for the paint job. My only question is with the puttying and powder coating which has been haunting me: what causes it to just puff up and when pushed crack and peel/scrape off? It's as if there's an air bubble underneath it and the powder coating just doesn't stick to the layer of putty underneath. Funny thing is it only happened around the bits that was repaired (e.g. where the b pillar and sill meet) and  luckily didn't spread further. If i had pics i'd show but it's been driving me mad. Hopefully the whole package will be painted this weekend.
The only other thing i did was do a compression test on it. The engine was semi warm and got a 9.5 bar reading for both cylinders. Any one else with something similar? The engine will only be pulled apart so i can change the seals, i don't plan on replacing valves or piston rings as it ran very well before being layed up in the front yard.
Also what i noticed on the engine with the exhaust removed is that it was running on a very rich mixture (black smoke) which explains why it had bad fuel consumption but ran well. Hope the servicing of the carb won't ruin performance as the carb that's on it at the moment is off an earlier model (Weber 28 IMB 100 i think.)
« Last Edit: August 01, 2010, 09:03:42 PM by GTMaster »
gsxr126
Re: Well here it is
« Reply #50 on: August 02, 2010, 12:13:58 AM »
A. Did you key the surface prior to applying the bog? B. Did you use the correct amount of hardener? C. Was the surface clean before application? Not doing these would cause the symptoms you describe. Not teaching you to suck eggs btw
Re: Well here it is
« Reply #51 on: August 02, 2010, 05:31:39 PM »
Thanks for the reply. You can teach me how to suck eggs in the painting/puttying department as i hardly know anything about it  ;D
E.g what is surface keying? I think i used the right amount of hardener as it goes hard on the surface but beneath is a bit soft and doesn't want to stick to the metal/puttyed surface beneath. I talked to a paint shop keeper today so i think i know where i went wrong so i'll start from the beginning:
After welding i used rust remover on the repaired surface (where the spot welds were) because i knew i'd only be able to start on the paint work much much later on and didn't want to bother removing surface rust. What i didn't do with the surface after that was clean off the rust remover properly. I gave it a wipe with a cloth do get the dust off then applied a thin coat of rust preventing primer. Afterthat i used  knifing putty on it. In the meantime the two component (hardener type) putty ran out so i used a small amount of single component putty, which when applied too thickly cracked, so i was careful with it. After acquiring some two component putty i started using that again. All went well till the first coat of primer. That was a different type, a much thicker type to cover up the spot welds better. This puffed up and could be peeled off. It was sanded down and refilled with knifing putty. Then came a layer of  another type of primer that were used on the doors (turned out good , no problems at all). That puffed up too but not in the same places. That was sanded down, refilled and resprayed.
So after that short story it still came off in  smaller quantaties though, which is what i'm repairing now. >:(
Car painters can throw stones at me for doing that  :) (and as my signature says: "You need time for a good job but you need more time for a s**t job" ;)
« Last Edit: August 02, 2010, 05:35:53 PM by GTMaster »
gsxr126
Re: Well here it is
« Reply #52 on: August 03, 2010, 01:17:49 AM »
Keying the surface means sanding with a 80-160 grit to get the bog to stick. Did you do this prior to applying bog? If your bog is still soft underneath, you either didnt mix it properly, didnt use the right amount of hardener or you applied it when it was going off. You must remove all traces of rust converter prior to starting any bog applications. I think your bubbling up problems may be starting from here. Filler putty can be used up to 5mm thick but knifing putty should be used just as a skimmer - 1mm max. Ive seen and done filler up to 10mm thick and it lasted but jeez the weight of that car went up by about 200kg once i finished - you dont want to be doing that to a little 126, stick to 5mm max. If you find that you need to go deeper than 5 it may be time to get the hammer and dolly out.
Difficult to diagnose without seeing it, maybe posting some pics might help.
This is how i would go about panel repairs - and painters can throw stones at me too.
Remove all paint to get surface down to metal, remove rust if any and plate, key/sand surface with 80-160 paper, apply filler bog if 5mm needed, knifing putty if less than 1mm needed. Once hard key surface with 320-600 paper and feather out the edges, apply 2PAC filler primer covering the repair area and overlapping by about 100mm in all directions, key with 800 paper feathering those edges and your pretty much ready for paint.
Of course there are books on the subject and the above is just a short description of a long tedious proceedure. Its all "live and learn" mate if you tackle these things on your own. Just remember that cleanliness before starting each step and adequate curing time will go a long way in avoiding problems. I like to go down to metal in my repairs as i once had a bad experience with bird poo stains coming thru my new paint as i only keyed the paint that time. Also make sure that all your products are compatible. EG you can use acrilic paint over 2pac primer, but you cant use 2pac paint over acrilic primer.
The 2PAC filler primer comes in cans and is very versatile - i once re'can'ditioned a whole car with a filler spraycan and got excellent results (here come the flying stones). Its sets really really hard and is a bitch to sand but leaves a very workable surface as long as you dont get it wet.
The way i see it - if you get someone to do the work for you it will probably cost 8-10 times more than if you did yourself, so you basically have 8-10 goes at this before your behind. Thats been my philosophy and it works for keeping me motivated.
Good luck with it - good to see your tackling what i consider the hardest part of building a car.
Re: Well here it is
« Reply #53 on: August 04, 2010, 06:57:47 PM »
Thanks for the helpful reply  [-/ I'll use it on a future restoration as i can't do anything about the puttywork now, which seems to have 'stabilised' but i don't want to do any puttying or painting for a while once the car's finished  :P  Keeping my fingers crossed for some good weather for the weekend. If all's well then it'll be green and i'll be able to take pics of it  :)
Ruined the new roof lining
« Reply #54 on: August 17, 2010, 08:47:42 PM »
Yes, never been so frustrated before. The guy who made the new head roof lining made it according to the old one yet it just didn't want to go in. So first one edge, then the other cracked and broke. So frustrated as it looks so good (beige carpet). Now i'm thinking about cutting it down a bit and just glueing it to the roof. I've searched the forum on roof lining topics and it all seems to be the same: no one has really successfully changed one before though many have just ripped it out of their cars  :P I even removed the rear window thinking i could slide it in easier from there: no luck as it just ruins the edges of the plywood-like lining. I'm thinking about removing the windscreen and seeing whether it slides in from there...
After a few more attempts it just started to break everywhere... though i'm happy that the car's green and i've sorted the electricals  :)
Some more pics
« Reply #55 on: September 19, 2010, 03:51:58 PM »
Hello all,
Finally managed to scan in more pics. I haven't given up on the car and it's looking good. Hopefully i'll get the roadworthy done this month or early next month. Still needs some minor work (bumpers fitted, wheels painted and new tyres need to be fitted as well as the mudflaps, rear windscreen, window washer and windscreen wipers.) I've put the engine together so i'll have pics of that too. I've got a new condenser as there are small sparks at the points (brand new points too) and i'll need to check the carb as i'm not satisifed with the idle (have to check the CO, some black smoke and stutters/stalls for a moment on acceleration) though it revs like mad  :P
Have more pics coming when the car is totally complete.
This is when i pushed it out of the stable ready to go into the garage...
« Last Edit: September 19, 2010, 06:30:49 PM by GTMaster »
Re: Well here it is
« Reply #56 on: September 19, 2010, 03:54:47 PM »
In the garage. This is where the prep work was done before painting.
Re: Well here it is
« Reply #57 on: September 19, 2010, 03:55:43 PM »
Masking and puttying ( >:()
Re: Well here it is
« Reply #58 on: September 19, 2010, 03:57:57 PM »
After the paint job. Not too good, and haven't got a full pic of the car with the doors yet. After the paint job i did the electricals.
Re: Well here it is
« Reply #59 on: September 19, 2010, 04:03:15 PM »
Put the doors together (had problems with the window winder. Got so tangled up i had to get a new one from the breakers.) Also had problems with aligning the doors (only when fitting, pushed some paint off  >:()
The right hand door lock was worn as i couldn't lock the door with the key. Got a new one but it was dodgy as i couldn't then open the door from the outside with the handle >:( So did some welding on it now it works fine  :)
Then started work on the engine:
