Author Topic: Oil Cooler  (Read 9113 times)
Oil Cooler
« on: July 21, 2010, 07:41:11 PM »
OK , Oil Coolers , starting to get interested, so what's that all about then, crazy ideas going around my head & need someone to bring me back down to earth  ::)
Re: Oil Cooler
« Reply #1 on: July 21, 2010, 08:36:26 PM »
hot oil goes in gets cooled and goes round the engine gets heated again goes into the cooler again gets cool again goes into .... thats the tech talk over hope it helps.
Re: Oil Cooler
« Reply #2 on: July 21, 2010, 09:52:43 PM »
Bis man , I told you to stop playing with your fundamentals , you will go blind  :oops:
I know that what goes up must come down & that E equals MC squared  :oops:
You ain't helped my crazy ideas  :cry:
Still love you though  ;)
Re: Oil Cooler
« Reply #3 on: July 21, 2010, 10:37:14 PM »
I'm sure Steve will explain the technical bits, but Mick explained it very well lol.
Here's a picture of the adapter on Steve's engine ;D
Re: Oil Cooler
« Reply #4 on: July 22, 2010, 09:03:15 AM »
My thinking also Pete although Mick does have a way of explaining things in simple terms  :oops:
First question is ............. Is it possible to just tap into the existing threaded points on the crankcase , if so which ones  ???
Re: Oil Cooler
« Reply #5 on: July 22, 2010, 09:04:19 AM »
I want that one [-/
Re: Oil Cooler
« Reply #6 on: July 22, 2010, 11:54:27 AM »
Rusty I was told to drill a hole in the oil pump casing and block off the flow through the drive spindle this diverts the flow through the hole in the casing.  You weld on an adapter, can ba bought from all suppliers.  The oil then flows from the pump through the new line to the oil cooler it then return to the allan bolt just above and to the right of the oil pump, again a screw in addapter is required to screw into the block.  I was told this from an old Italian 500 abarth engine builder.  It is a lot cheaper than purchasing the market conversions.
Re: Oil Cooler
« Reply #7 on: July 22, 2010, 01:55:41 PM »
I tried to get that allen bolt out, it isnt playing ball, it's almost as though it was cast into the casing :oops:
Alfons1972
  • sorry for my bad english...
Re: Oil Cooler
« Reply #8 on: July 22, 2010, 05:09:18 PM »
in the german 500forum a part of owners tend not to touch the circulating oil of the engine.
They take the oil from the sump, then lead it to the cooler with an extern pump and lead it back to the sump. That helps lowering the temperature to about 90-100°C.
Someone told me, a petrol pump of an Mercedes W123 would be ideal for that.
look here: (ok, it's in german. But the pictures are quite good)  ;)
http://willsagen.de/?page_id=307
« Last Edit: July 22, 2010, 06:19:25 PM by Alfons1972 »
Fiat 500 R
Fiat 500 giardiniera
Re: Oil Cooler
« Reply #9 on: July 22, 2010, 06:44:16 PM »
Well my interest was raised by just having had the fan blow & the subsequent massive over heating although an oil cooler would not have helped much in that situation. Been in touch with the www.126fan.com guys and they say that the standard fan will disintegrate around 6,000 rpm . They only run oil coolers on their hill climb cars and the larger alloy sumps on fast road race motors. The 500 / 126 engine has the built in oil cooler with some of the fan air being directed down along the bottom of the sump vents. With the little connector piece between fan housing & sump removed I was amazed at the volome of air being pushed down there. With the connector on not much of that cooling air was being blown through. Combination of damage to base of sump plus build up of crud in the vent channels. Worth checking out if you are running an aircooled.  [-/
Re: Oil Cooler
« Reply #10 on: July 22, 2010, 08:14:57 PM »
thats definately got me thinking, although If I were to fit an oil cooler, I'd prefer to fit a can filter in there somewhere too.
It might seem a bit like overkilll, but the little engines do cook oil quite well when they want to!
Allan
Re: Oil Cooler
« Reply #11 on: July 22, 2010, 09:14:37 PM »
HI guys
Check out the systems as used on a production car such as some Lancia and 130TC Fiat. They run a bypass system with a built in thermostat so that the hot oil only flows through the cooler after it reaches a certain temperature. Remote filter systems are available as I have fitted them to rally cars. The problem that I see is that if the oil runs through the cooler all the time then the engine will take longer to come up to temp in winter. But then in NZ we don't know what that is like. The next question is where to mount the cooler radiator.
Allan
Alfons1972
Re: Oil Cooler
« Reply #12 on: July 23, 2010, 06:33:18 AM »
oh yes, it should not run all the time...
just use a switch for the pump. If you see the oil getting hot: switch on. If cool enough: off  That's what the pilot of an 126 surely can do... :P
Fiat 500 R
Allan
Re: Oil Cooler
« Reply #13 on: July 23, 2010, 07:02:10 AM »
When the oil has done it's lubrication job it returns to the sump via two slots in the crankcase at the flywheel end of the motor. It must still have some pressure at that point. Would it be possible to divert the returning oil by putting a fitting in the sump and blocking the little piece in the sump where the oil would normally flow and then put it through the cooler and back to the sump.
Allan
Re: Oil Cooler
« Reply #14 on: July 23, 2010, 12:30:26 PM »
Allan
There are several ways to use the existing pump to feed the oil cooler, but the concern is whether the extra force required to pump through the pipes and cooler are likely to put the oil pump under strain.
if the flow is altered then it is likely that it will lower the oil pressure. pumping oil down the pipes will cause a drop in pressure, not including the cooler.
Also, there will be a much greater strain on the pump at cold before the oil warms up.
An electric pump offers a switch or thermostat control and if fitted correctly, will not disrupt the internal oil flow.
The links Alfons posted earlier show a very neat oil cooler install on a 500roughly where the petrol tank on a 126 sits the other side of the car would work if fitting it to a 126
