Author Topic: Oil Cooler  (Read 9114 times)
gsxr126
Re: Oil Cooler
« Reply #30 on: July 28, 2010, 04:08:12 PM »
Come on people, think outside the box.
Gotta love this thread,
In the red corner we have the externally assisted 'oil coolers'
In the blue corner we have the internally assisted 'oil coolers'
Introducing the pink corner - the 'heatsink'
This thread made me think of it. Why not use a large heatsink to cover the sump. I was looking at an old Alpine amp i have in my shed and thought - that amp cover/heatsink would look good as a fake ribbed sump under my niki. Then thoughts of this thread came to my head and of the possible oil cooling effectiveness of a heatsink. Seeing as fiat regard a small flap directed to the sump as adeqate, the heatsink's large surface area should do something if attached to the sump. The cover is huge, it measures 30x20cm and has sexy angled ribbed wings on either side.
Its simple-just bolt it up, cheap-you can buy old 80's amps with those massive heatsink bodies for nothing, effective-seeing how much heat even a small heatsink fitted to a computer can cope with, it should provide results, also effectiveness/wind speed should also increase as road speed increases, and most of all, very sexy-i'll paint it up red and polish the ribs and i'll have my Spanky Replica Abarth Race Sump.
Sorry - had too many JD&C's tonight
Let the riot continue..............
Alfons1972
  • sorry for my bad english...
Re: Oil Cooler
« Reply #31 on: July 28, 2010, 04:59:00 PM »
no, gsxr,
I think your idea is good. Why not? It's cheap and probably very effective. Most effective it will be when paintet. the colour does not mention. It is just because bright aluminium has a low emission coefficent. About 0,1. Paintet it will be about 0,9. that will increase the thermal radiation.
I'd like to have some additional colling at the cylinder head. is it possible to mount some heatsinks there? Probably beneath the tin housing?
Fiat 500 R
Fiat 500 giardiniera
Allan
Re: Oil Cooler
« Reply #32 on: July 28, 2010, 09:00:22 PM »
C'mon now GSXR126. But not the worst idea in the world.
Why JD&C. What wrong with Bundy?
Allan
gsxr126
Re: Oil Cooler
« Reply #33 on: July 29, 2010, 03:10:33 AM »
Alfons, i suppose anywhere is possible, its just a matter of bolting one on. We'll see how good the idea is. I'll try to get this done over the next few weeks and post some pics. I should probably hook up an oil temp gauge now and compare later.
Allan, thats Queensland sh*t, rough as guts and always gives you a sore noggin in the morning. I'll stick to my smooth sippin whiskey thanks.
Back to oil coolin. I'm sure you have all considered or realised that the main issue here is what we are actually cooling - the oil, but no one has yet to mention the advances in oil technology and what that means for our little engines. Any oil's stability will decrease with repeated heat cycles but i think the more modern oils/synthetics stay stable for longer. The right grade is available for our engines in mineral and synthetic, the trick is finding the right additives to ensure suitablity.
The right oil with the right additives and regular servicing should eliminate the need for any type of oil cooler on a standard engine - fake or not.
Alfons1972
Re: Oil Cooler
« Reply #34 on: July 29, 2010, 06:47:08 AM »
but you should not use oil with additives, because of our not existing oil filter. If there are cleansing additives, they will loosen the dirt in the spin filter and transport it to the bearings where the can lead to heavy engine failure. That's not amusing...  :o
But what you can use is an oil 20W-50 instead of 15W-40
What has to be mentioned you usually change the oil every 3.000 miles (or so), so the stability is not our biggest problem, I think.
Fiat 500 R
gsxr126
Re: Oil Cooler
« Reply #35 on: July 29, 2010, 11:57:17 PM »
yeah thats the trick - finding the 'RIGHT' additives. I agree with you on the cleansing additive. i think its called PFPE and you need to have to right amount in your oil  - i think.
The owners manual states that anywhere from 10W to 50 mutigrade oil can be used. Just depends on your climate.
Ive done 13,500 klms in my daily driver so far and have done two oil changes and i am happy with the oil i'm using. Its Nulon 15W-50 Synthetic. What i have noticed is the oil is a lot cleaner when its due for a change (every 5000klm) and its getting cleaner every change.
An oil's stabilty is basically its film strength and film strength is directly affected by heat and pressure so i would consider this as vital to maintaining correct oil conditions
Re: Oil Cooler
« Reply #36 on: July 30, 2010, 09:48:32 PM »
I'm ordering two ten row coolers, as soon as I've seen smallcox's car in person.
Just need the exact details on the drilling into the oil pump, drill and taping the return seems no bother.
Tried and tested the world over, i see an external filter is available so probably go that route too [-/
