Author Topic: Oil Cooler  (Read 9115 times)
smallcox
Re: Oil Cooler
« Reply #15 on: July 23, 2010, 01:48:07 PM »
Would it be possible to divert the returning oil by putting a fitting in the sump and blocking the little piece in the sump where the oil would normally flow and then put it through the cooler and back to the sump.
Allan
Hi, interesting debate,
I tyred several ways to fit an oil cooler and as pics above show ended up with adapting the cam drive cover. Allan the only problem with the rear bearings oil return is you will not get as much oil flow as required and as pressure builds up to push the oil through the oil pipes and rad this pressure will be on the rear oil seal, not good.
Micheal is also right that the oil required to push through the oil cooler is not regulated until it gets to the pressure releaf valve after the oil has returned to the engine, I was concerned with this so done some maths and reconed the blanking plug thats required to block the pump i drilled a 3mm hole to releif the extreme pressure. Also as you now run the oil cooler you can use a synthetic oil of thinner viscousity.
Sweat 8)
Re: Oil Cooler
« Reply #16 on: July 23, 2010, 02:09:12 PM »
So my thoughts so far  </3
The standard 50+ year old design on the aircooled engine is fine but a good idea to check that the air flow passages are clear. tuning the engine requires an uprated fan that is the heart of the whole cooling system. The idea of a seperate pumped thermostaticaly controlled oil cooling system is interesting but a bit over the top for me as the beauty of the engine is the simplicity. My "crazy" idea might be to fit the larger sump then alter the base of the fan housing so the cooling air directed there is blown through an oil cooler. Use the shortest pipe runs possible to minimise any pressure loss  ;D
Allan
Re: Oil Cooler
« Reply #17 on: July 23, 2010, 10:07:31 PM »
A very interesting debate. I'm beginning to think that a totally independant system with its own pump is the way to go. This leaves the engine system working as it was designed to do. If you used the right pump you could also fit a remote filter to the system. Also you could fit a temp switch to turn the pump on when the temp reached a certain level. I would take the oil from below the rear main outlet and return it at a point very close to the oil pick up. Next question is "what about a dry sump set up"?
Allan
Re: Oil Cooler
« Reply #18 on: July 23, 2010, 11:30:44 PM »
Hmmm 126s and electics...i dunno...
Had electric windows, didnt work out binned them, put brighter bulbs in on relays and if you're not careful the battery goes flat on idle.
40psi through a bit of hose, through an oil cooler, it isn't going to suffer much losses at all in pressure. After all the flow isn't huge. If a hole in my rear bearing can drop the pressure then the flow must be small. Thermostatic control..why not simply take a leaf out of the fiat book and simply fit a flap to the oil cooler and duct the air through it.
Rusty's idea of the oil cooler picking-up air off the bottom feed to the sump has merit I think. A simple flap on this would mean in the dead of winter you're not loosing too much heat. The flap would direct more air for the heater [-/
A Bis would be better-off with the electric version as they have better electics.
That's my 5p worth :oops:
Allan
Re: Oil Cooler
« Reply #19 on: July 24, 2010, 06:09:58 AM »
Do you want to discuss dry sumps here or on another thread?
Allan
Re: Oil Cooler
« Reply #20 on: July 24, 2010, 05:06:37 PM »
I think the VW Beetle air cooled engines have a factory oil cooler as mentioned before, the fan blows air through it.
Allan
Re: Oil Cooler
« Reply #21 on: July 24, 2010, 09:23:55 PM »
But that would mean the air arriving to cool the engine would already have some extra heat to it. Another byproduct of running an oil cooler is the additional oil capacity.
Allan
Allan
Re: Oil Cooler
« Reply #22 on: July 24, 2010, 10:09:07 PM »
The more I think about it the more I like the idea of a remote fitted oil cooler. I agree with Uncle Rusty in leaving the motor as designed and built by Fiat. My thoughts as I have said would be to take the oil via a fitting in the sump from near the return slots at the rear main bearing and return it via another fitting with an extension inside the sump placing the cooled oil very close to the oil pickup. Both fittings could quite easily fit on the left side of the sump (side opposite the exhaust). Picking up from and returning this way would mean that should you no longer require the cooling system the only part you need to replace is the sump.
I have just looked at my engine compartmant and the logical place for the pump is in the recess on the left side. Mine even has two 6mm studs there on which to mount it. Which only leaves the most important part, the radiator. My first thought is to mount this somewhere in the front edge of the motor compartment just behind the fuel tank but clear of the left rear suspension. Another area is on the rear cross member although this may be in an area of negative air pressure and a third is on the left side on an angle.
This brings another problem. You would need to ensure that oil in the cooler radiator and lines did not return to the sump when the pump was not running hense overfilling the sump with oil. For this you would need the fitting of at least one non return valve. If you really felt the need to you could always run an additional tank in the system to give you greater oil capacity and therefore in theory at least greater cooling.
Someone may like to enlighten us as to the size, capacity and type of pump required to perform this task.
Keep the thoughts coming.
Allan
Re: Oil Cooler
« Reply #23 on: July 25, 2010, 09:48:36 PM »
What's the point of a dry sump?
I dunno think thats modifying things a little too far..
Allan
Re: Oil Cooler
« Reply #24 on: July 25, 2010, 10:51:22 PM »
My dry sump suggestion is a little tongue in cheek. However a few years back when I was into flying small aircraft I visited the air show at Oshkosh in Wisconcin USA where they showed a Subaru motor that was dry sumped but did not run a scavange pump. The explanation given was that the were using the positive crankcase pressure to return the oil to the tank. The one thing we got plenty of in our engines is positive crankcase pressure.
And further to my post on oil coolers one point I omitted to discuss was the flow rate and how to get it right. If we force the oil through the radiator too fast then we will get very little cooling effect and if too slow and over cool the oil run the risk of shock cooling the engine.
Some one who has more experience in these matters might like to comment.
Allan
smallcox
Re: Oil Cooler
« Reply #25 on: July 26, 2010, 06:28:35 PM »
Rusty you started a riot with this thread you naughty boy, :P
Now fiat fitted a baffled tin sump to blow cool air across it to help with engine temperatures and when they did this it must have raised manufacturing cost, so from this they must have known that there engines got close to the high end of the spectrum that oils back then would cope with, after all a sump has cool air around it when the car is moving. Now as the engine got bigger and roads got faster and people travelled further then it must stand to reason an oil cooler will be required as you cannot cool the engine by fitting a bigger water radiator with engine size as would be the case with a liquid cooled car.
Now Mr naughty boy your talking about 800cc and with this brings more heat not only from thermal conbustion but also bigger frictional service area from pistons which is going to raise the oil temparetures when travelling at 70mph on the motorway.
Life would be wonderful if you could just tap in to the oil flow and return it but this is not possible but you know this already Rusty and if you did would possibly upset the oil pressure/flow within the engine. Now as mentioned a seperated aux elec pump would do the job put is expensive and complex and we don't like that on here. >:(
Now as puddlejumper shown if you tap somehow into the oil pump cover then return it to the blanking plug just right to the pump (yes they never come out Darrell so drill and tap) then you will not upset the oil pressure within the engine because until it get to this point it has not been pressure regulated to 40psi [-/are we happy so far.
Now if 7mm bore hose is used then flowrate will not be affected unless you use miles off the stuff. ;D. So the only thing left is the heat exchanger,  if to small will retrict flow and to big may drop oil temp to much, a 10 row cooler will properly be ok and you can cover 50% off it in the winter to stop over cooling. As mentioned also thermal shocking components by quenching with cold oil is not going to be an issue with a system like this as you bring the oil temp up as soon as you start the engine from cold unlike a aux pump that might kick in on demand once oil temp has got above happy temparetures. Also an additional remote oil filter can be placed in the system.
Now Rusty are you still interested?
Love you still. Smallcox [-/
« Last Edit: July 26, 2010, 06:30:31 PM by smallcox »
Re: Oil Cooler
« Reply #26 on: July 26, 2010, 07:00:59 PM »
If knowledge is power,  then smallcox must be well on his way to world domination by now!
Re: Oil Cooler
« Reply #27 on: July 26, 2010, 07:55:20 PM »
 :D :D Now look here Small "yellow peril" cox if you are so damn clever how come I can only get 100 giga wattts out of my flux capacitor  ;D ;D
How did I know that you would have calculated those flow rates & hence the optimum hose bore size  ;)
Must have been old gits intuition  :o
I was not thinking particularly about the 795 ccs engine but just ideas for "cool runnings" on any slightly modified engine. I think that a well maintained standard engine can be well thrashed and give a very good life considering the age of the design etc. Just like the contempory competition in Europe at that time Citroen 2CV , VW Beetle & the Morris Minor.
That blown air under the sump must be quite a volume at high revs but the sump design is from the 50's so not efficient and motorway driving was not invented.
After all these cars were designed in Italy and are famous for being driven hard. Seems like we are getting there but got to go back on the naughty step now  :oops:
Alfons1972
  • sorry for my bad english...
Re: Oil Cooler
« Reply #28 on: July 27, 2010, 05:56:47 AM »
probably you need something like this: http://www.ilmotore.de/shop/index.php/cat/c3_oil-cooler.html
besides, I would tend to use an external system with a separate pump. For this I will use display for temperature and a simple switch with control lamp.
If to hot, I'll switch on, if cold I switch off. I try to use used parts to keep the costs low.
My sump already has these plug-and-play-connections, a heritage of the seventies:
Fiat 500 R
Fiat 500 giardiniera
Allan
Re: Oil Cooler
« Reply #29 on: July 27, 2010, 06:12:44 AM »
Nice looking gear but I couldn't get it to talk to me in a language I understand. I'm with those who are going for the external set up and leaving the motor alone. This way we are adding to the cooling without asking the motor to do any additional work. Poor little thing works hard enough as it is especially the way some of us drive. The whole idea Dave is to allow us to give them more of a thrashing.
Regards to you all.
Allan
p.s. Loved the photos of the meeting.
