Author Topic: Twin coil - what the hell????  (Read 12098 times)
Jan-in-UK
« on: June 25, 2010, 08:33:58 PM »
Story goes - we fired up my brand new engine inside the green one - lovely sound, runs sweet and everything was superb. Then I switched it off to proceed with the other jobs but I left ignition ON and after more or less 2h coil started to make strange sounds :) and melting itself :D
So ok, coil f***d I thought. I got hold of a new one, put wires the same way, NOTHING else was changed. And it does NOT start up what so ever. Obviously gets flooded every single trial. Checked cables 3 times, everywhere..... WHY?????
IS THERE ANYTHING ELSE WHICH GOES "BYE BYE" TOGETHER WITH BLOWN COIL?????? I will get crazy, co close to completion.
www.fsoclub.co.uk
Re: Twin coil - what the hell????
« Reply #1 on: June 25, 2010, 09:30:42 PM »
Check the points are opening and closing they can weld themselves together.
Swap the condenser.
check the fuses.
Jan-in-UK
« Reply #2 on: June 25, 2010, 09:31:34 PM »
Will do. Fuses are ok, so maybe one of other two issues :(
www.fsoclub.co.uk
« Reply #3 on: June 25, 2010, 09:39:23 PM »
Also if you have a multimeter or a circuit tester check you have 12v on the + side of the coil. its not unknown for it to take out the the wire to the ignition switch.
« Reply #4 on: June 25, 2010, 11:47:07 PM »
the +12v to the coil is fine, but we werent able to stick another condenser on it. That was my first thought. ?Didn't think about the points welding themselves, good idea
« Reply #5 on: June 30, 2010, 10:19:22 PM »
I gave Jan a help with this earlier, and I'm baffled!
I drove to his in my 500, then removed my coil (wasted spark), distributor, condenser and plug leads and put them on Jan's 126 - No spark!!
I also checked the plugs, then ran a jump lead from the +ve side of the coil to the battery, and the coil mount to the -ve, still no joy.
I cannot figure out whats wrong since all the parts work when they're fitted to mine!!!
Any ideas would be a big help!!
Jan-in-UK
« Reply #6 on: June 30, 2010, 10:41:22 PM »
I can only confirm I am getting grey haired as well and it would be really great help if someone would come up with idea what is wrong  :rant:
www.fsoclub.co.uk
rmbruton
  • before
« Reply #7 on: June 30, 2010, 10:46:58 PM »
could it be a break in the wiring harness?
« Reply #8 on: June 30, 2010, 10:48:53 PM »
this may sound stupid but when you refitted the coil did you make sure that the point of contact with the body has a good earth?
« Reply #9 on: June 30, 2010, 10:52:38 PM »
I was checking the multimeter from the +ve of the coil through to the block, so it must have been earthed ok, but just to confirm, the last test involved connecting the coil earth to the -ve battery terminal and the +ve coil to the +ve of the battery as I figured this would pick up on any dodgy earth or corroded wires
« Reply #10 on: June 30, 2010, 11:48:42 PM »
Have you checked the wire from the coil to the distributor ???
« Reply #11 on: June 30, 2010, 11:52:09 PM »
I made up a new one, then checked for open/closed circuit while turning the engine and it all seemed in order!
« Reply #12 on: July 01, 2010, 12:16:06 AM »
Thats a puzzle. so the distributor cam is rotating with the engine, Have you tried measuring from earth to the points or do the points spark when you flick them ???
« Reply #13 on: July 01, 2010, 07:00:27 PM »
Reading from the start of the thread it states that the coil got cooked after the ignition was left on i can only assume that there is some part of the loom that has given up due to this?
Jan-in-UK
« Reply #14 on: July 01, 2010, 08:35:26 PM »
All parts of the loom, high voltage leads and all mechanical parts were taken off michael 500 - still doesnt work. As michael said we even put battery voltage strait to the coil without loom on the way!! I am getting slightly angry  .:)
www.fsoclub.co.uk
