Author Topic: Twin coil - what the hell????  (Read 12098 times)
Re: Twin coil - what the hell????
« Reply #15 on: July 01, 2010, 10:18:33 PM »
Lets start at the beginning.
Have you got 12v at the coil ???
Have you got 12v at the points ???
Have you got the isolation washers on the points and the distributor body ???
Have you got a spark at the plugs ???
Does the distributor cam rotate with the engine turning ???
Do the points open and close ???
Have you tried push starting the car or towing it round the block just in case the starter motor is taking too much power out of the battery.
« Reply #16 on: July 01, 2010, 11:18:41 PM »
Have you got 12v at the coil - Yes
Have you got 12v at the points didn't take a voltage measurement at the points, but I measured a closed circuit between the points and the -ve side of the coil, which answers the same question
Have you got the isolation washers on the points and the distributor body - yes
Have you got a spark at the plugs no.
Does the distributor cam rotate with the engine turning yes
Do the points open and close yes
Have you tried push starting the car or towing it round the block just in case the starter motor is taking too much power out of the battery. no, but I did couple up my working battery to the car which didn't solve it
I drove to his in my 500, then removed my coil (wasted spark), distributor, condenser and plug leads and put them on Jan's 126 - No spark!!
I also checked the plugs, then ran a jump lead from the +ve side of the coil to the battery, and the coil mount to the -ve, still no joy.
I cannot figure out whats wrong since all the parts work when they're fitted to mine!!!
« Reply #17 on: July 02, 2010, 12:26:48 AM »
Hi Micheal,
It has to be a fault in the wiring, If you disconnect the wire to the distributor there should be 12v on the neg' side of the coil measured down to earth, Just as if your setting the static timing.
« Reply #18 on: July 02, 2010, 08:31:59 AM »
A closed circuit between the points and ve won't be good enough.
Take the wire off the points and earth it intermediately against somewhere. If you can induce a spark this way the points are knackered and are earthing out somewhere inside the dizzy.
This earthing out could be within the points mechanism, I've had this on a relatively new set of points.
« Reply #19 on: July 02, 2010, 11:04:04 PM »
so what electrics have you got that work on the car?
« Reply #20 on: July 02, 2010, 11:38:11 PM »
Thanks Darrell, but I know the points, dizzy and coil are good. I took them from my running 500, fitted them to Jans 126 which wouldn't start, then re-fitted them to my 500 and drove home. As far as I can see, the only variables left are the mechanical drive from the dizzy, which works, and the +ve lead to the coil and the lead between the dizzy and the coil.
Pete, I suspect it is wiring as there's not a hell of alot left!!
I haven't tested the -ve side of the coil down to earth but will give that a shot.
I assumed running a jump lead from the earthing bracket to the battery would have ruled this out, but I'm open to offers as this is doing my head in!!
« Reply #21 on: July 03, 2010, 09:24:45 AM »
Hi Mate keep plodding away [-/ While you have your meter out check the voltage on the + POS wire on the coil down to earth, You mentioned that you have 12v but what happens when the engine is being cranked ???
As long as the coil is bolted to the car there should not be an issue with the earths, If you need to pickup a permanent live in the engine compartment you can do that from the alternator which is easier to get to.
« Reply #22 on: July 03, 2010, 11:17:43 AM »
If I remember right the coil voltage was 11.2v (still cranking well so no problems as far as I could tell)
While cranking the voltage dropped to 10.v I think, but I've had my 500 start on less
« Reply #23 on: July 03, 2010, 12:43:27 PM »
The reason i asked was to rule out a fault with the ignition switch and wiring from the coil, to front of the car, we are clutching on straws here (scratches head) ;D
smallcox
« Reply #24 on: July 03, 2010, 05:14:45 PM »
Hi All,
 Just been reading the comments to date, it's just so frustrating when your so close. I hope this may help but you propreley done this already as i am a little slow. OK the twin spark coil has 12v to it and you have run a jumper wire to the coil to prove this is ok (so supply is ok), on the twin coil the + and - terminals do not require the coil base to be connected or bonded to body earth to function as like a conventional coil would.
 1, With the points open on the cam and all wiring connected you should have 12v at both sides off the coil (ignition on).
 2, With the wire coming from the distributor disconnected from the - side off the coil connect your ohm meter to the distributor wire and the other ohm meter lead to a good earth point on the car. Now turn the engine by hand so the cam in the distributor operates the points and the meter reading should go from fully open circiut to fully short circiut and nothing other than this. Any suspect readings should be investigated.
Just one other thing both spark plugs, both HT leads must be in the circiut to get a spark, so a suspect lead or plug will cause complete failure to spark.
Hope this helps [-/
I know you used parts from Micheals car but did you changed the distributor complete or just the points and condensor? The reason i ask is that there is a insulated part on the distributor that may be damaged due to the meltdown of the coil as the points closed would have been in this circiut.
« Reply #25 on: July 03, 2010, 08:10:34 PM »
Hi Smallcox, nice 126 BTW!!
It was the complete dizzy swapped during the testing.
I was not aware that both leads had to be connected during this. After the parts were swapped, at each stage  Jan tried to start it while I help the plug against the block to watch for a spark, so this could be a big issue.
I think I'll have to try swapping the parts again, but with the leads attached this time.
Out of interest, why do both HT leads need to be connected to get a spark?
Michael
belstaff
« Reply #26 on: July 05, 2010, 06:26:32 PM »
 Its a wasted spark system. Both leads fire H.T. at the same time. One cylinder would be on compression stroke the other cylinder would be on exhaust stroke, hence wasted spark system.
 The H.T. spark runs down one H.T. lead uses the engine as the earth - then the H.T. runs back up the other H.T. lead back to the coil, This then  makes the complete circuit between the coil & earth. So you do need to have both H.T. leads connected to make the wasted spark system work.
 If you only try with one H.T. lead connected you will  find a very low Kv.
  Regards Gren.
Michael
[/quote]
phreak97
  • Niki!
« Reply #27 on: July 07, 2010, 02:26:45 AM »
swap in the entire system from the 500 including the spark plugs and try again?
also in a 126 the green wire to the coil is actually a ~1m length of resistive wire.. if you jumper +ve straight to the coil, dont leave it on there for too long, it isnt meant to get full battery voltage.
also, did you replace (or remove) the noise suppressor on the coil?
« Last Edit: July 07, 2010, 04:37:19 AM by phreak97 »
phreak97
smallcox
« Reply #28 on: July 07, 2010, 04:55:13 PM »
As mentioned above the twin coil pack does require a resistor in series with the low tension side off the coil. I have tryed to find out how the HT side off the coil is wound to explain why both spark plugs must be connected but failed. I can only quess that the windings are centre taped and have to callapse at the same time to create a spark.
Jan-in-UK
« Reply #29 on: July 07, 2010, 05:06:22 PM »
I will definitely go crazy if it won't start before weekend  :oops: lost my intrest in putting interior back together because of this s**t coil/leads/loom/points/sparks problem....
www.fsoclub.co.uk
