Author Topic: Twin coil - what the hell????  (Read 12098 times)
smallcox
Re: Twin coil - what the hell????
« Reply #30 on: July 07, 2010, 05:10:57 PM »
Going crazy is part of owning a 126 :P SMILE you'll get it sorted
belstaff
« Reply #31 on: July 07, 2010, 08:24:26 PM »
As mentioned above the twin coil pack does require a resistor in series with the low tension side off the coil. I have tryed to find out how the HT side off the coil is wound to explain why both spark plugs must be connected but failed. I can only quess that the windings are centre taped and have to callapse at the same time to create a spark.
                Yes the coil primary is connected to the secondary as one plug fires positive and the other plug fires negitive making the complete circuit. one plug fires from the centre electrode to the earth . the other plug fires from the earth electrode to the centre . the positive plug always wears out first.  regards Gren.
[/quot
e]
phreak97
  • Niki!
« Reply #32 on: July 08, 2010, 02:06:20 AM »
I just did this at trade school, the secondary winding has no internal connection like it does on a single coil, each end of the winding is connected to a spark plug, so if you remove the connection to one of the plugs youre leaving one end of the secondary open and removing the whole circuit.
phreak97
belstaff
« Reply #33 on: July 08, 2010, 12:35:59 PM »
          Correction.
quote]  Yes i must have had a brain storm. using an ohm meter between the two low tension terminals you would get a reading of 1.3 to 1.6 ohms on a ballast ign coil. then on the two H.T. chimneys you would get a reading of 5000 to 10000 ohms. so has you said there is no internal connection.
 On a normal 1 chimney (points coil) you would get a reading of around  3.ohms on the primary terminals. Then connecting ether side of your low tension terminal with the secondry H.T. chimneyyou would get your secondary H.T. reading of 5000 to 10000 ohms reading. hopefully this clears up any confusion. Regards Gren.
phreak97
  • Niki!
« Reply #34 on: July 08, 2010, 01:18:49 PM »
you could try connecting up the old single coil setup from a 500 if you have access to one, that'd rule out your twin spark problem, but try new spark plugs first.
I feel like I could get this car running if I could see it for myself.. I think I'm kind of far away though:P
phreak97
« Reply #35 on: July 09, 2010, 10:49:12 PM »
swap in the entire system from the 500 including the spark plugs and try again?
also in a 126 the green wire to the coil is actually a ~1m length of resistive wire.. if you jumper +ve straight to the coil, dont leave it on there for too long, it isnt meant to get full battery voltage.
also, did you replace (or remove) the noise suppressor on the coil?
I wonder if this green wire could have been causing me bother with the 123 ignition.... :-X
Will check that tomorrow as I am very sad to have taken the 123 out.
« Reply #36 on: July 09, 2010, 11:43:59 PM »
Thanks for the words of encouragement, but It's not been as easy as it should be, or it would be running now I can assure you!
phreak97
  • Niki!
« Reply #37 on: July 10, 2010, 01:26:35 AM »
yeah no doubt, Ive had problems like this which just dont make sense as well. But persistance is all you need. You need to check each part individually and make sure it works properly, and keep an open mind, the problem probably isnt where you expect.
Have you checked if thwe earth strap between the body and the alternator is making good contact?
If you were using the green wire as the 12v input to the 123 then it could have caused problems for sure. Follow thw green wire along the firewall, just before it disappears into the car theres a plastic joiner and the wire changes colour, thats where your 12v from the ignition will be.
Otherwise you can run a wire from the alternator or starter motor then have a relay operated by the green wire to make it switch on with the ignition. Thats probably the best way to do it with the least voltage drop, but either way should work fine.
phreak97
« Reply #38 on: July 10, 2010, 09:17:12 AM »
I'll be green wire hunting  :oops:
I wish Jan lived closer or I'd pop-over and do some head scratching together there. :-X
It always sounds like it should be easy to sort on the forum but I know 126's have gremlins running around in them from new that are placed in the car to keep one guessing :oops:
« Reply #39 on: July 10, 2010, 10:06:31 AM »
It's not using a 123, as for the other checks please read the earlier parts of the thread as I have already checked the entire system. I will have to re-test with both plugs connected, but I've not been round to help for a few days as my plate is rather full at the moment!
Allan
« Reply #40 on: July 10, 2010, 10:11:11 PM »
Good Morning from New Zealand Jan.
I am following this tread with interest. My 126 P4 has the older standard ignition system as used on thev 500 so I can't help with any info there and I have not had anything to do with the redundant spark system.
If I were there I would go back to the basics by removing the rocker cover and checking the valve timing, resetting the tappets and then based on what I have read, fit a complete ignition system of the older type (coil, distributor with new points and condensor, rotor, cap, leads, plugs). Then with the rocker cover still off make sure that it was firing the correct plug and set the ignition timing. I would then power it up from an external battery so the vehicle system had no input other than operating the starter. That would be +ve to +ve side of the coil and -ve to a good earth on the motor, testing all connections with a multi meter or test light. Then without turning on the key pull the starter and it should go. I hope I am not trying to teach Grandma to suck eggs. What I have suggested will prove that the motor is a runner and that all that hard work was worth it. (It will make you feel good just to hear it run). Good luck and keep us all posted.
Allan
Jan-in-UK
« Reply #41 on: July 13, 2010, 09:51:42 PM »
I would like to thank all of you - my car does work now :) Darell came over and cured it with a nice help and advice from Michael. In the end of the day we still don't know what caused the problme as Darell has check and connected all these bits from a scratch. Fact is - none of the wasted spark coils (3!!!) works on this car. At leas one works on Michels 500.... Se we ended up setting timing, checking points and connecting.... TWO SINGLE COILS with each other and it does run. So all I need is double connection round standard coil (the one looking like single silver one but with two sonncetors for leads).
Does anyone has ONE kicking about????!!!
NEED TO GO UXBRIDGE this weekend !!!!
BTW: In good mood so I fitted few rare accesories to my 126 today - have a look in resto.
www.fsoclub.co.uk
