Hello everybody.
I'm Sleurhut from the netherlands, 19 years old and proud owner of a 126P carcass
. In the Netherlands we dont have a fiat 126 dedicated forum so i started searching the internet and came across this forum.
I'm a trainee (guess its called like that in english) at a local universal garage. We do all kind of cars. recent makes and models but also oldtimers. We have a guy working there that had a fiat 126 for ages and he had plans to restore it to its former glory. The car got stripped down and some welding was done. After that he lost the drive to finish te project and the car ended up next to our scrap metal bin outside for about a year.
When we moved to a new workshop it ended up next to the bin again. a few months ago i decided it would be nice to have a little restauration project for my own. I work all day long on other persons cars but seldom on my own. I did the guy an offer and dragged it inside to start the work on it.
this is how it started:
<a href="
http://s683.photobucket.com/user/sleurhutje/media/WP_20140411_003.jpg.html" target="_blank"><img src="
http://i683.photobucket.com/albums/vv200/sleurhutje/WP_20140411_003.jpg" border="0" alt=" photo WP_20140411_003.jpg"/></a>
I had to pull the car inside on a jack because the brakes were seized solid. Time for some fresh brakes.
first removed al the junk from it to get a better look at it.
it needed 2 new outer sills, a new section in the front plate and 2 new floor boards. The doors also were rotted away.
the engine was not seized and had pretty good compression. It had not run for about 10 years but decided to give it a try before taking it out of the car. I connected a battery to it. Removed the plugs and soaked the cilinders in oil, squirted some oil on the rocker arms and turned it over bij hand. After fitting the plugs back in. i did a basic check to make sure i couldnt hurt the motor by trying to start it, The point looked pretty worn out but i had a strong spark. climmed back intro the car. gave it half choke and it started right up. sounded pretty smooth for something that had not run in 10 years.
The following days after work i removed the gearbox and engine. stripped it down. degreased the gearbox, replaced all the seals and gaskets and changed the boots.
the engine was the next to be stripped down and rebuild.
In the meantime i got more familiare with the fiat quality :
this car was brought in for MOT, the chassis girders (guess its called like that in english) were rotten out and the whole coachwork was rotted loose at the rear. Got me welder out and got it back to how it should he.
A few weeks later they brought a grande punto. the gearbox locked up on the motorway. A common problem with punto's.
but there was also good news. Reconstruction had started on the engine.
nicely painted cilinders back on there. cil head got new valve seals and i grounded in the valves.
it really is super clean.
rebuilded my alternator with new bearings etc
and got a nice alu oil carter
and fitted a bit more stuff to it
Im currently working on getting al the engine cooling covers painted black again.
I want to build a 126 in the same style as abarth and giannini did the fiat 500. so white body, red abarth logo's. hood a bit opened up. 4 point harness. bucket seats. lowering it.
i will post new photo's when al the cooling covers are on there. please tell me what you guys think about the work that is done.
sleurhut
