Author Topic: my 1985 fiat 126P from holland  (Read 15904 times)
sleurhut
Re: my 1985 fiat 126P from holland
« Reply #30 on: February 19, 2015, 09:56:06 PM »
did some work on the car the last weeks.
because the car is probably gonna spend some time on the slalom course when its finished i figured out it would be a good idea to put in a rollcage. Original FIA approved ones cost a bit to much for my kind of budget. i dont need a fia approved one to run it on the slalom course. Got some measurements done and welded in a rollcage:
i cant run it with the doorbars in because that way you cant mount a decent size seat in to drive it :)
all the welding is done now, both doors needed a new panel where the lock is mounted. it was torn from the door because of metal fatigue of guys smashed the doors shut too hard
tommorow the sanding will start  :)
« Last Edit: February 19, 2015, 10:41:13 PM by sleurhut »
