Author Topic: my 1985 fiat 126P from holland  (Read 15904 times)
Mics126
Re: my 1985 fiat 126P from holland
« Reply #15 on: August 24, 2014, 09:13:26 PM »
very good work, this 126 is going to be the most rot free 126.
sleurhut
« Reply #16 on: September 08, 2014, 12:00:58 AM »
thanks, pretty satisfied with it.
Got the nose fitted to the car. batterytray had to be replaced., as wel as the underside of the nose. some guy sticked roofing asphalt on the hole to cover it  :(.
drilled all of the spotwelds, pulled out the batterytray. the new piece of the underside is welded in now.
and welded in the new one
smoothened the welds and dryfitted the frontplate
fits pretty good, needed some work on the bended bits where it meets the frontwings.
bended it a bit by hand and used the hydraulic press set that you normale use to push supporting beams back into position when you crash your car to press the bended sides to the outside to make them fit the fenders better. got it almost spot on. cheated a bit the last half a mm by beating the front wing a little bit to the inside to close the gap a bit more  :)
welded a new piece in the front wheelarch
and that wraps up the welding on it for now. cant find more rot. I will have to weld 2 small plates in the square holes in the A pillar where plastic trim would normally clip onto.
pulled the suspension
removed most of the old wheelwell filling
no rot!
this one before scraping it all out.
Got the underside mostly stripped back to the old white factory paint. degreased it well and applied 3 layers of thick akzo nobel epoxy 2k primer with a brush to get a thicker layer on it. dont have foto's of it but it sealed the panels of. waited 2 days before applying body sealer. a 1kg can got smeared in every little crease to get it all watertight. waited another day to apply anti stone chipping. and after that about 3 layers of bitumen undercoating. the stuff that wont dry out as fast. the chassis girders got done with tectyl ML.
hope this is enough to let it survive the dutch wheater  :-X
a few weeks ago i picked up a lowering kit second hand
and got everything for the suspension new except the front shocks and the traingles etc
started fixing the front suspension first, new dustcaps etc. replaced the outer balljoints
and next day did the other ones.
balljoints felt like new. not to supple not to stiff and they had good grease in them. regreased them and put new dustcaps on
got another pair of vents in the mail
a lot better than the original
did the whole interior but dont have photo's off it. now i'm busy replacing the seals of the stearing box and setting it up right. after that i will pull all new brake lines and refit the suspension with the new stuff
pietschokkenbroek
« Reply #17 on: September 08, 2014, 07:16:47 AM »
Great work!!
top-notch  :thumbup
sleurhut
« Reply #18 on: October 05, 2014, 08:52:58 PM »
school started again so i dont have that much time to work on my fiat.
got the stearing box degreased, took it apart and checked it out. bearing were fine, filled it with grease instead of oil (it will always leak out overtime, its a fiat :P) and fitted it back together. Had to adjust the bearing play and pretension on it to get it to work without any play on the stearing wheel.
love fiats attention to detail:
Front wheel hubs were next up. pulled the drums off:
everthing new.... 15 years ago. totally siezed up and dried out. had to be replaced
got a good set of brake backplates. stripped it down and primed it
all assembled. Had to mount new wheel bearings.
did the next set exactly the same way.
lol a picture of my moped was included in the folder. 1960's RAP
stripped the rear trailingarms down for shotblasting and powdercoating. checked the bearing races and regreased it so it can be mounted when the arms come back from coating
Got a picture this car is gonna look when its finished, love the look and stance.
KAL SPL
« Reply #19 on: October 06, 2014, 12:11:11 AM »
Wow I thought I went to a lot of trouble rebuilding , you sir are in a league of your own !
Aus's cleanest Niki !
poxxxy
« Reply #20 on: October 06, 2014, 10:38:59 AM »
Awesome work so far! I'm sure you're colleague will be envious of what he could of had :D
shielsy
« Reply #21 on: October 08, 2014, 05:16:30 PM »
hats off owen nw :o
sleurhut
« Reply #22 on: October 31, 2014, 12:05:20 AM »
thanks for the comments, my colleague likes the progress on it very much, he likes to see it will eventually  return back on the road instead of getting scrapped  :)
last part of the suspension that had to be tackled were the rear wishbones. one of them was to far gone to be salvaged. the arm is made out of different stamped pieces of thick metal that are spot welded together. moisture will work its way between them and causes rust, it was so much that it pushed the metal plate against the axle
got a good second hand one and got it shot blasted and powdercoated. rebuild starts.
and all finished:
sleurhut
« Reply #23 on: November 04, 2014, 11:56:58 AM »
picked up a set of cobra seats for it and mounted the suspension back on the car
When i installed the rear suspension i couldn't get the 2 rubber springmounts to seat nicely to the underside of the body. got them right and fit the springs. lowered the car on its wheels, lifted it up and this is wat i found
it would not stay in place. had to grind the rubber down a bit on the inside and use a very strong sealant (normaly it is used to glue the front windshield of a train to the coachwork) to glue the rubber to the body. then fit the springs and put the car back on its wheels, that way the springs press the seat to the body and make sure it bonds wel. next problem was the spring would sit loosely in its seat when lifting up the car, its an MOT fail here. But with a piece of crankcase breather hose around the first winding of the spring it would pinch it just enough.
i have a lowered front leave, but it only dropped a few cm's. when the engine is fitted the car will drop a bit more on the rear end and i will have to drop the front also a bit more. whats the best way to do it.
and i have another question, on the rear panel were the front mount of the engine sits on there is a small hole a bit off centre in it. Whats the purpous of this hole? can a crank handle be put through it or something like that?
« Reply #24 on: November 04, 2014, 12:35:29 PM »
The hole in the rear panel is for the power supply to the number plate light.  You can machine the front spring alloy supports to drop the front by 10mm and fit a reverse eye front spring this can give an additional drop of approx. 40-50mm.  The other option is to fit fully independent suspension to the front or if you are adventurous you could fit air bags.
« Last Edit: November 04, 2014, 12:38:14 PM by thepuddlejumper »
sleurhut
« Reply #25 on: November 04, 2014, 11:04:53 PM »
thanks ralph,
i already installed a lowered front leaf. The camber is also way off now. i think i need camber correction plates to place the a frame arms a bit higher to get the wheels to get to a normal camber angle again. I think i first finish the car and look at the hight then. according to some fiat 500 guy that comes by us for a chat quite often will the car drop a little bit more when it is driven. The leaf needs some time to settle itself in the rubber mountings.
want to run the car bumperless, will weld the hole shut then.
next to do is make the last brake line that runs from the master cilinder to the rear brakes, then it will be times to install the hoodpins and start paint prep.
« Reply #26 on: November 05, 2014, 01:16:03 PM »
I have found that leaf springs do give a bit with time but not much.  How did you install the new spring if you didn't use a spring compression tool then it is difficult for the rubber in the bushes to allow rotation.  I have seen 500's sitting up in the air because the spring wasn't compressed enough when installed.
sleurhut
« Reply #27 on: November 07, 2014, 08:31:04 AM »
I just mounted one eye of the leaf to the wheelhub. Then put a floorjack under the other end and pushed everything in place on the seats on the car, i did not use a soring compressor.
« Reply #28 on: November 07, 2014, 01:20:41 PM »
http://club126uk.co.uk/smf/index.php?topic=6123.msg42381#msg42381
See above thread, there is a photo of the spring compressor I used.  It is fabricated from some sq hollow tube with a threaded bar and some large washers, did the job.  If you look in the Haynes manual you will see a sketch of the FIAT tool.
sleurhut
« Reply #29 on: January 03, 2015, 12:12:47 AM »
hello everybody, first happy newyear!
the past weeks i did not work very much on the 126. did some small jobs, mayority was removing sound deadening and cleaning the goo that the polish glue left  :)
first i mounted some hoodpins to the bonnet and the frontlid. made in the uk :P.
all of the old sound deadening had to be removed since it started to break from being exposed to cold and snow a few times. Get a big hammer with a rubber head on it like paviours use and start hitting the surfaces. It will break in a million pieces and come of without much trouble. at least that was what de first panel did....
the second one had to be heated with a paint stripper and removed with a putty knife. i did not want to bust up the cables that run to the rear to much and they had to be rewrapped in new isolation tape with new connectors so got that out as well... until i had an empty shell without something in it
and with the help of an angle grinder with a wire wheel on it the whole inside was bare without any sealant in about one day
found some rot in the side window surround.
cut it out and made a nice new piece for it on the outside. welded it in. dont have any photo's of it. for the inside you can use the top piece of an inner sill, about in the middle. the curve in the sill matched that of the window surround 100%. saved me a lot of time trying to make an piece that would fit is nice.
i'm going to run a 4 point harness. cut out the old anchor point for the seatbelts, pretty weak and i sticks out to much. i want maximum room in the back.
got a piece of L bar welded in there
eventually i wil make nice aluminium covers for the 2 big holes in the sides where the filler neck protrudes, this is to give the window surround some strength
after that some anchor plates were made from 2.5mm steel and welded on 6 places to weld my rollcage onto. dont have pics of those
got a set of 13 inch wheels
they do stick out a bit to much, on the front it is no problem. but on the rear they reach 4 cm outside the wheelwells. to much for the dutch version of MOT. anyone got the wider arches for sale?
made the old style heater unit fit, had to weld 4 studs to the underside of the dash and cut away the old ones. found out the connectors on the new style and the old style gauge were the same. Got myself an complete old style dashboard and made it to fit.
you just put it exactly in the middle of the 2 studs where the steeringwheel will bolt onto. with a marker draw what will have to go to make it slide in the narrower hole in the dashboard, and just start cutting away stuff till it fits.
bended some sheetmetal to close the big gaps on the sides
now it fits just like it does in the old style dashboards. i will have to reinfore the hole on the back a little bit where the speedo cable comes in. with the old style dashboard mat on it you cant see it has been a new model dashboard in a previous life  :D
next job will be fitting the old style ashtray to the middle of the dashboard and welding in my rollcage
