Author Topic: electronic ignition!  (Read 13544 times)
kev126
  • Built not bought
Re: electronic ignition!
« Reply #60 on: May 13, 2013, 04:58:51 PM »
Jokke, is yours wired the same as mine in the picture I posted?
1989 Fiat 126 BIS
DEYAN IYI
« Reply #61 on: May 13, 2013, 04:59:13 PM »
Well, the scheme I've linked says other thing. Measure the sky blue cable, should be 1,7Ω  :)
jokke
« Reply #62 on: May 13, 2013, 05:09:51 PM »
yes. :) only I got one more from - on the coil, it's for my tach meter :)
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
DEYAN IYI
« Reply #63 on: May 13, 2013, 05:48:01 PM »
126 Bis - Workshop manual, Chapter 55, Page 13  ;)
kev126
  • Built not bought
« Reply #64 on: May 13, 2013, 06:15:39 PM »
I don't think the running problem I'm experiencing is the module, but the coil itself. The car starts up fine from cold just not when the engine is warmed up. Surely it wouldn't start at all if the module was wired up wrong?
1989 Fiat 126 BIS
jokke
« Reply #65 on: May 13, 2013, 06:25:13 PM »
if you had wired it wrong, it wouldn't start at all.
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
kev126
  • Built not bought
« Reply #66 on: May 13, 2013, 06:36:53 PM »
My head needs a rest  :o  :P
If my new coil works and it's all good I will be over the moon
1989 Fiat 126 BIS
« Reply #67 on: May 13, 2013, 07:26:04 PM »
Hi Kev,
 To put it another way the twin spark coil runs on 9 volts, the battery voltage is 12 volts, if you were to run the coil at a constant 12 volts you would burn the coil out because it is supposed to run at 9 volts, so what they do is run the 12 volts through a ballast wire or block, What this does is when the engine is cold when you start the engine 12 volts is supplied to the coil which gives you a whopping spark to start the engine, as the ballast resistance wire warms up it reduces the voltage to 9 volts so as to not burn out the coil.
When you connect the ignition module to the + side of the coil it will start and run until the voltage eventually drops to 9 volts, that is why you need to take the + feed direct from the 12 volt supply from the fuse box as in the instruction :thumbup because the module needs to have a constant 12 volt supply to work correctly.
kev126
  • Built not bought
« Reply #68 on: May 13, 2013, 08:24:34 PM »
I'm with you now Pete! So in theory, I could plug in the module to ANY 12v feed as the information is sent to the coil via the earth wire?
1989 Fiat 126 BIS
« Reply #69 on: May 13, 2013, 10:30:45 PM »
You got it, Try taking the power from the electric pump.
DEYAN IYI
« Reply #70 on: May 14, 2013, 08:22:51 AM »
Before buying a new coil, measure the one you have.
Magneti-Marelli BZ600A
Primary winding 1,48Ω +/-4%
Secondary winding 9000Ω +/-10%
Aditional external ballast (wire) 1,70Ω +/-5%
