Author Topic: electronic ignition!  (Read 13543 times)
kev126
  • Built not bought
Re: electronic ignition!
« Reply #30 on: April 28, 2013, 10:34:58 AM »
Wow! Does it work ok? Any problems?
You're a genius.
1989 Fiat 126 BIS
jokke
« Reply #31 on: April 28, 2013, 01:28:42 PM »
it workes very good. cars starts easier and reving good! :) haven't got any problems
But remeber to add som termal paste under the module before you mount it so it's not overheating. :)
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
kev126
  • Built not bought
« Reply #32 on: April 28, 2013, 01:45:06 PM »
Excellent! You say place it 1 - 2mm away, how important is this? I wouldn't wanna get it wrong!
1989 Fiat 126 BIS
jokke
« Reply #33 on: April 28, 2013, 05:21:36 PM »
it's not so important. but just have a small gap. it reads of a magnet, so don't think it's not going to work say if you place it 3mm from.. :)
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
« Reply #34 on: April 28, 2013, 06:25:03 PM »
Well done Jokke  ;D  I always thought that this was possible but do not have a Bis to try it on. I wonder what you use for thermal paste but I also think that it is probably less important on a Bis engine as the engine is less hot being water cooled. Also are you still making use of the Bis vacuum advance as drilling & tapping both plates will stop this if the module mounting screws go through both plates but if I read you right then you drill through and tap both plates but the supplied M3 mounting screws only go into the top plate. I just checked the magnet to module clearance on a couple of air cooled distributors and the gap is about 1.5 mms.
jokke
« Reply #35 on: April 28, 2013, 07:19:09 PM »
just use termal paste from computer cpu. is just for getting maximum contact beween the module and the plate it's mounted on. The screws that was in the kit is short enough to use so they just going in the first plate. so vacuum is working fine. :) ok, so 1.5 mm is optimal gap. good to know. :)
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
DEYAN IYI
« Reply #36 on: April 28, 2013, 09:08:05 PM »
I'm also happy to see that idea in action 8) Well done!
kev126
  • Built not bought
« Reply #37 on: May 05, 2013, 12:23:08 AM »
BIS OWNERS!
I am going to try this, and the kit is on offer! It is the correct kit, right?
http://www.ebay.co.uk/itm/190569972829?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
1989 Fiat 126 BIS
kev126
  • Built not bought
« Reply #38 on: May 05, 2013, 12:33:34 AM »
Scrap that, I've gone for the Powerspark one. A couple of pennies more expensive but I've heard the customer service is brilliant.
1989 Fiat 126 BIS
« Reply #39 on: May 05, 2013, 08:06:49 AM »
Seems allot of trouble to fit :o You might even need to take the engine out to stick the sensor on the flywheel. you will also need according to the diagram a twin coil pack, Where the accuspark has 2 wires :D
http://www.power-spark.de/index_en.html
kev126
  • Built not bought
« Reply #40 on: May 05, 2013, 09:03:14 AM »
Really? Surely it's just plug and play apart from modifying the plate inside the dizzy? I'm only going to try as Jokke has made it work with pictures and my timing all needs sorting anyway! A small price to pay even if it doesn't work I reckon. No more points resetting and blown condensers :)
1989 Fiat 126 BIS
« Reply #41 on: May 05, 2013, 09:11:28 AM »
Thought you were going for the more expensive setup as below, If your going for the identical accuspark/powerspark that's O.K.
kev126
  • Built not bought
« Reply #42 on: May 05, 2013, 09:49:11 AM »
Ohh, sorry for the confusion - you had me worried there! Yes just the points replacement :) if I am successful I reckon ANYONE could do it :P
Certainly seems the better option than to pay £95 + £??? To send off your own dizzy to have it fitted.
1989 Fiat 126 BIS
kev126
  • Built not bought
« Reply #43 on: May 11, 2013, 08:25:19 PM »
Jokke - where did you connect the black & red wires? I assume black goes to a chassis earth?
And the red?
1989 Fiat 126 BIS
jokke
« Reply #44 on: May 12, 2013, 01:07:39 AM »
And the red?
They goes to the coil. Red on + and black on - :)
« Last Edit: May 12, 2013, 01:10:38 AM by jokke »
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
