Author Topic: electronic ignition!  (Read 13593 times)
kev126
  • Built not bought
Re: electronic ignition!
« Reply #45 on: May 12, 2013, 09:12:22 AM »
That sounds painfully easy! I had a feeling it would be different wiring because of the different coil to air cooled. Thanks mate :)
1989 Fiat 126 BIS
jokke
« Reply #46 on: May 12, 2013, 11:10:16 AM »
did it fire?  :thumbup
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
kev126
  • Built not bought
« Reply #47 on: May 12, 2013, 06:48:48 PM »
It did! Ran beautifully until the engine warmed up then it cut out and wouldn't restart. We have tried everything and narrowed it down to the coil being crap. It's the original one as well. New one ordered :)
1989 Fiat 126 BIS
« Reply #48 on: May 12, 2013, 07:51:59 PM »
Well Done Kev for getting it to fit :thumbup unfortunately its not advisable to use the + feed on the coil because of the ballast resister wire, this maybe the problem, it should be wired as the accuspark instructions. diagram below.
This is how a ballast coil works
Why do some ignition systems have a ballast fitted where others do not?
Originally, all ignition systems did not have a ballast fitted which meant that the ignition system used a 12v coil with a 12v feed from the battery via the ignition switch. Such a system works fine when an engine is running, but problems can occur when starting the engine. The starter motor draws a huge current from the battery leaving less energy to create a spark across the spark plugs. The result is a weaker than normal spark which is not ideal for starting an engine. This problem is worsened by colder temperatures and/or a worn starter motor which will draw even more energy for starting and leave even less energy for sparking. To overcome such a problem, ignition systems were changed to run a lower voltage coil (usually 9v), and these coils could still give the same output as the original 12v coils. In order to run such a coil, the 12v ignition feed runs through a ballast, reducing it to 9v at the coil. To assist starting, a 12v feed (usually from the starter) bypasses the 9v ignition feed, giving the 9v coil a 12v feed. The result is a better than normal spark which is ideal for starting, particularly on cold damp mornings. As soon as the engine has started, the 12v feed is cut and the coil will run on the 9v ignition feed.
kev126
  • Built not bought
« Reply #49 on: May 12, 2013, 08:05:34 PM »
Do our 126's have a ballast resister?
The engine will only start once it has cooled down or is from cold. When it does, it will run on one cylinder until you rev it loads then it runs on two. The sparkers will show a dim light until you rev it loads then they both shine brightly. The idle is very, very rough like it was when I had the air leak problem. I'm starting to think it was the coil all along now.
Adjusting the timing just makes the rough idle faster or slower. Once I fit the new coil we shall see what happens, but the electronic ignition works great and I heard the difference as soon as I turned the key  :thumbup
Yesterday before I fit the ignition, it was juddering again when driving as well  ::)
« Last Edit: May 12, 2013, 08:10:24 PM by kev126 »
1989 Fiat 126 BIS
fixit
« Reply #50 on: May 12, 2013, 08:43:34 PM »
check the basics, has the coil got good earth all wires attached
is 'dwell angle' mentioned in your destructions
check the alt is charging on idle x low revs ;D
f
« Last Edit: May 12, 2013, 08:53:55 PM by fixit »
kev126
  • Built not bought
« Reply #51 on: May 12, 2013, 08:58:13 PM »
It's all fine F, spent hours and hours sourcing the problem and they all seem to lead to the coil. Nothing on instructions about dwell angle.
Jokke has wired it the same way and he has had no problems so it surely can't be anything to do with ballasts? I'm just confused :(
Hopefully when the coil arrives, it'll plug and play beautifully :) ill let you all know in the week.
« Last Edit: May 12, 2013, 09:08:54 PM by kev126 »
1989 Fiat 126 BIS
jokke
« Reply #52 on: May 12, 2013, 09:12:45 PM »
I diden't have any ballast on mine. :) and no problem starting or stalling. :)
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
kev126
  • Built not bought
« Reply #53 on: May 12, 2013, 09:34:58 PM »
It's gotta be my coil! Thanks for all the info so far mate :) I did a quick video before all the problems started occurring!
[youtube]http://www.youtube.com/watch?v=sdsEenDRe_g[/youtube]
1989 Fiat 126 BIS
DEYAN IYI
« Reply #54 on: May 12, 2013, 10:14:19 PM »
Bis's coil is ballasted like all the other 126 with double coil (before EL/X) by wire! The square one on the pic below. You must power the electronic module before that cable - a sky blue one #55.
http://www.pf126.ovh.org/elementy/danetechniczne/schematy/7.jpg
« Last Edit: May 12, 2013, 10:16:15 PM by DEYAN IYI »
kev126
  • Built not bought
« Reply #55 on: May 12, 2013, 10:39:51 PM »
The sky blue wire plugs onto the male spade on my coil, and on the male spade right next to it, we've ran a wire to the positive part of the new electric module.
The cable on the very far right is the sky blue one already on the car. The cable next to that (with the red connecter) runs to the module. The left hand cable runs to the black wire of the module.
1989 Fiat 126 BIS
DEYAN IYI
« Reply #56 on: May 13, 2013, 12:31:22 PM »
Exactly. You should conect the red one not on the coil, but on the other end of the blue one. Do not cut the blue cable, it's a special metal. The blue one is conected to an orange one somewhere around the rear left wheel. Now the module is powered with less than the nominal power of the system.
Read Pete126's post!
« Last Edit: May 13, 2013, 12:35:18 PM by DEYAN IYI »
kev126
  • Built not bought
« Reply #57 on: May 13, 2013, 01:45:41 PM »
I don't quite understand. If the sky blue wire is not connected to the coil, it will get no power? There will then only be one wire (left) connected to the coil. Is that correct?
1989 Fiat 126 BIS
kev126
  • Built not bought
« Reply #58 on: May 13, 2013, 01:54:13 PM »
Right, so I have to follow the sky blue wire back into the car, and connect the new module wire to the wire it comes from?
To sum up: don't run the module power from the sky blue wire. Run the module power from a 12v feed instead. ?
« Last Edit: May 13, 2013, 02:22:15 PM by kev126 »
1989 Fiat 126 BIS
jokke
« Reply #59 on: May 13, 2013, 03:50:33 PM »
Bis don't have resistor:
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
