Author Topic: customising intake valve  (Read 4674 times)
deda
« on: February 23, 2011, 10:13:41 AM »
Hello folks
I am sorry for my bad english,but i hope that you understand what i want :)
i have one head of 650ccm like spare parts and i want to make some tuning
-2mm and bigger intake valve,exaust valve will stay normal...Question for you ,from which
car i may to put intake valve (if it is possible that it is not bigger than 35mm) Thank you
Re: customising intake valve
« Reply #1 on: February 23, 2011, 01:14:12 PM »
Hi Deda , your english is fine so do not worry. So it sounds like you are going to have the head skimmed to raise the compression . The inlet valves from a Fiat Panda 30 are 34mms diameter if you can get those. Much harder to get are Lancia Fulvia valves that are even larger. You will need new valve seats to do this properly and an engine /tuning specialist can alter the valve heads , seats and the inlet & exhaust ports to make the engine give a lot more power.  [-/
deda
« Reply #2 on: February 23, 2011, 03:39:07 PM »
ok.thank you..it will be difficult in my country find that....for me, to order something from e bay is problem..but i will find some fast solution,THANK You
« Reply #3 on: February 23, 2011, 05:07:18 PM »
It is not possible to get the valves in the UK either . They have to be ordered in from specialist suppliers in Europe. The air cooled Fiat Panda 30 car was never sold in this country so there are no spare parts here for that engine. If you can trade with Italy you should find some there. Another option , if you can do or have specialist machining work done, is to modify valves from another engine that has 7mms diameter valve stems.
DEYAN IYI
« Reply #4 on: February 23, 2011, 07:46:13 PM »
Vozdra, dedice :P (Hi, deda!)
The only way to obtain a standard part upgrade is Fiat Cinquecento 700 (2 cylinders, water cooled).
It is 35mm and the rest is the same as 126 (The exhaust valve is 27mm.) 126 Bis, CC700 and Panda 30 have valve seals on the inlet one, so you can do it as well.
According to the italian tuners the biggest valves that you can put without using eccentric guides are 36x31mm with 8mm stem.
Greetings, bro!
« Last Edit: February 23, 2011, 07:47:58 PM by DEYAN IYI »
smallcox
« Reply #5 on: February 23, 2011, 09:30:01 PM »
Hi Deda,
How about modifing your own valves that are fitted as present, 33 and 29mm with reshaped valve head and valve seats it's as good, (if not better) than the  next size up. Then with a little reshape off the ports and chambers, more fun 8)
« Reply #6 on: February 23, 2011, 09:57:29 PM »
The 2 cylinder watercooled  Cinquecento is another car that never made it to the UK ( unless you are talking 126 Bis ) . So with 8mms valve stems you must be running with enlarged valve guides . After some research I found that the 34 to 28 inlet ratio of inlet to exhaust was good. I then took a standard 499ccs head to a racing engine specialist with 33, 34 & 36 inlet valves plus 28 & 31 exhaust valves. After inspection the guy was not happy with the max 36/31 combination as the measurements showed that the valve seats required would have interfered , would need to be cut at the interface (like a figure 8) and therefore prone to cracking & failure. So under guidance we went for no skim on head , open inlet port to 30mms (same as 126) , 34 inlet and 28 exhaust, ported & polished all the way through. 28 IMB carb , later 126 cam & 126 exhaust. The engine looks very standard outside but goes up hills a whole lot better  ;D
deda
« Reply #7 on: February 23, 2011, 10:24:23 PM »
ok..now it is more and more interesting..i appreciate that you want to help me..but one question for smallcox...what exectly you think(i know in global) when you tell reshape...becouse i must to explaint that the guy who will do that...that is solution if i dont find parts from panda,cinquecento..
DEYAN IYI
« Reply #8 on: February 23, 2011, 10:41:58 PM »
smallcox
« Reply #9 on: February 24, 2011, 09:47:07 PM »
This gets boring for some but reshapeing is simply finding a well suited shape off valve (head) that will flow highest cmf of air for a given pressure drop, Imagine you connect you vacume cleaner to the combustion chamber and that when sucking it draws air through the intake valve port only ( only imaging it). ok If this was done with the valve removed this would probalay flow a given figure at max.
Now if the valve was replaced and opened 1 mm off the seat the flow would be a lot less, you agree? As you do this at different amounts off valve lift you would be able to plot a graft ,Yes. Now go back to the valve only 1mm off its seat, what can be done to increase the air flow at this amout off lift? Sharp corners impede air flow so a gentle angle applied to the valve and seat would greatly aid air flow at low lift YES. and a Valve spends more time at low lift then at fully open so if you can increase airflow, you now see more bang inside the cyclinder and power at the wheels.
Valve seat widths and port angles also increase flow into the cyclinders but the valve to valve seat has the most room for increase in airflow/power
I have a standard valve reshaped in the garage and will try to post a picture to show a good shape for increased power :)
gsxr126
« Reply #10 on: February 25, 2011, 01:47:27 AM »
Be careful here. Increasing the valve size does not necessarily mean you will increase flow. In fact if bigger valves are fitted with no other changes you will hurt flow. There is a formula that matches port flow figures to the best valve size. Sharp corners may impede airflow, but the effect of getting pooled fuel back into the airflow from a sharp edge is more vital to good cylinder filling.
I'll try find the formula at home tonight and post.
« Reply #11 on: February 25, 2011, 08:05:52 AM »
That is why I took my head to a specialist  ;)
He now has the "stage 1" head from my 795 ccs engine to fit larger inlet valves (Panda 30) , unleaded seats, modify valves & seats. Re-port (some work already done) & polish where he sees fit. The head has already been skimmed. The guy is a master of the "dark art"  but the downside is that his work is in such demand that you have to book work in months in advance . Gives you time to save up the pennies for the bill though  :oops:
Allan
« Reply #12 on: February 25, 2011, 08:13:38 AM »
I will go with smallcox and GSXR126 on this one. Much of my experience with head work has been bought about by finances so i have found that smoothing the ports and the valves gives good gains particually in these smaller engines. I could never afford the cost of new seats and valves. Also a larger valve may not work that well unless you can remove combustion chamber material to prevent shrouding.
Allan
gsxr126
« Reply #13 on: February 25, 2011, 10:14:28 AM »
Couldnt find the formula but from what i can remember in a nut shell - if your intake port flows a certain hp, lets say 25hp for the 650cc motors head and you had one with a 34mm valve and one with a 32mm valve, the smaller intake valve port will make more power.
Valve size choice is all about the relationship to the intake port flow figures, thats why a panda head comes out with larger valves. By all means go larger valves if your improving the rest of the head (as it seems Rusty is learning all about, and the "dark artists" command a premium here too), but its crucial not to overstep the mark. Personally i think smallcox's valve sizes sound spot on.
I have heads for a windsor v8 that flow 450hp and they have massive valves in them - 2.05/1.78in and i've been told that a 1.94/1.65in setup will give me 500hp.
deda
« Reply #14 on: February 25, 2011, 10:19:45 PM »
After very careful reading of oall post and i see that the solution of Smallcox is maybe the best...i will wery grateful if you can post me some pics to see how look like a head after reshaped...you explain me very good ,but for my man who will do that ,it will be much easy if you post me some pics..Thank you
