Author Topic: customising intake valve  (Read 4675 times)
smallcox
Re: customising intake valve
« Reply #15 on: February 26, 2011, 03:10:45 PM »
 OK,
gsxr126 is sort off correct when warned about port increase in size as this effects port verlosity. If using a standard head reshaping the valve and valve seat will not cause any bad effects as airflow speed has not been changed in the port area. Also if you go down the route off port shaping there are do's and don't which when understanded are sort off obiveous. So basic steps to follow and don't get carried away as head modifacation gets more involved when cams,carbs, and special tuning parts are used. This is when matching all parts is important.
This picture is off a standard intake valve, one reshaped. If going to a half decent machine shop this is really basic stuff so he should be able to help you. the same can be done to the exhaust but keep the valve thick in material as this has to conduct heat away. also on the exhaust valve you can radius the valve around the circumference off the face to aid flow around the valve into the port but do not do this on the inlet [-/
note the stem has been thinned
« Last Edit: February 26, 2011, 03:13:41 PM by smallcox »
