Author Topic: New Complete Engine Required  (Read 7001 times)
kitten75
« on: August 06, 2010, 04:04:46 PM »
Hi all
Right, my mechanic has said my Fiat needs a new engine due to the damage caused when the valve went.  It doesn't need the auxiliary parts such as starter or carburrettor however it does need the main engine block. He can get a brand new one from Fiat for £650 but having only bought the car 3 weeks ago for £750 (think I was done!) I'm not sure I want/can afford to spend this...?
Would it be wiser in the longer term to buy a new engine or try to find a good condition second hand engine?
All advice appreciated!
Mhairi
Worm
Re: New Complete Engine Required
« Reply #1 on: August 06, 2010, 05:23:16 PM »
Not sure if you're aircooled or water but this link has all the parts for the 126, but its in Germany not sure how much shipping would be, but i would think it will be cheaper than from Fiat, may find some thing in UK as well. Look in the for sale items too on the forum too
http://www.fiatclassic.com/HTML126/KATA126U.HTM#engine
« Last Edit: August 06, 2010, 05:27:03 PM by Worm »
Worm
« Reply #5 on: August 06, 2010, 06:13:06 PM »
I am pretty sure she's after a Bis engine going by her old threads.
Ask your mechanic what's wrong with the block? it may be that the pistons have been damaged? if that is the case fair enough you will need a replacement engine.
If the block is ok a replacement cylinder head is your best option.
rmbruton
  • before
« Reply #6 on: August 06, 2010, 06:33:13 PM »
i think £650 is good for an engine from fiat. it would give your car a new lease of life.
Worm
« Reply #7 on: August 06, 2010, 06:58:25 PM »
Opps :oops:
« Reply #8 on: August 06, 2010, 07:09:39 PM »
I am sure you will find a used Bis engine for little money. In fact look in the for sale section on here there is a Bis for sale with 2 free engines thrown in. I am sure they would sell an engine.
« Reply #9 on: August 06, 2010, 07:32:10 PM »
 I can`t see why you would need a new engine unless the damage is serious. The other thing, is the £650 for the whole engine, or just the block? Plus if you put labour on top of that the final price would be mad.
 Maybe it would be wort talking to Jan-in-uk, or one of the Polish guys on here. I`m sure I saw some new bis engines-blocks on Alegro, or just go for a complete second hand one as already suggested.
 Hope you get it sorted somehow!
kitten75
« Reply #10 on: August 06, 2010, 09:37:02 PM »
cheers for all the advice...i'm taking my other car down to mechanic tomorrow as he's got a potential buyer for it as need to sell it to repair the Fiat.  I'll speak to him tomorrow to get some more info on engine status and i am going to get a total cost including labour before i make a decision.
I am erring toward just biting the bullet and forking out for the new engine (should labour charge not be too bad) as Robin says, it'll give my car a new lease of life and as I know so little (ie. nothing) about cars it may be better for me in the long run.  I don't want to buy a 2nd hand engine plus shipping for £100/200 etc and then have numerous repairs on top of that..even though keeping costs as low as poss at the minute is very appealing.
I see the chap that was doing the Mongolian race thing bought a 2nd hand engine for £600!
I'll get some more info tomorrow from Robert (mechanic) and see what he thinks.
It's a BIS enginer, water cooled I'm looking for...
thanks again, it's good to know there are folk out there who understand what i'm going through!  I miss my little car!!
Mhairi
« Reply #11 on: August 06, 2010, 10:12:20 PM »
Amazing....I had a great BIS with a great engine and struggled to get £200 for it ::)
« Reply #12 on: August 06, 2010, 10:26:58 PM »
 Â£600 for a second hand engine is definitely too much. You can sometimes buy a whole bis for less than that. You have to do your research first and add all the costs up to weigh up things. Ask Rusty how it can go even with a brand new bis :-X
kitten75
« Reply #13 on: August 06, 2010, 10:31:24 PM »
God, now you're really scaring me..I assume rusty had a nightmare with a new BIS engine??
« Reply #14 on: August 06, 2010, 10:42:54 PM »
There were problems with the BIS when it came out. I think the ones that survived were sorted-out.
The one thing I learnt was they were prone to overheating. This is apparently due to the thermostat being far away from the head. Ricambio had a conversion to move it closer to the head. I simply removed the thermostat as thermostats can stick in the closed position therefore making it overheat.
Basically nothing should go wrong even with a standard BIS provided maintenance is strictly adhered to however in the real world, that is never the case, thus sticking thermostats will e the end of many a BIS engine.
I'm a little confused with yours, as the valve I assume failed to be the thermostat, which would simply need a head gasket replacement. A horrid little job to do but very do-able even for a relatively novice mechanic. A light skim of the head might be advisable. Not trying to second-guess you mechanic, but what possibly could have gone wrong to kill valve spring etc etc and require a new block even!
