Author Topic: New Complete Engine Required  (Read 7001 times)
kitten75
Re: New Complete Engine Required
« Reply #15 on: August 06, 2010, 10:54:36 PM »
thanks Darrell - no problem in second guessing mechanic, I haven't got a clue what went wrong but i'm going to find out tomorrow morning. all he's said to me so far is that when the valve went it caused a lot of damage - but that could mean anything?
I'm pretty confused with all this thermostat, block, head gasket chat and not sure what questions I should be asking!
I wish someone could translate to my mechanic for me!!  I've been using him for years as have had quite a lot of cars in my time (most with a life span of about 12 months!) so I know he won't be taking the p##' but it would still be good to be able to understand what has gone wrong and if I do definitely need a new engine before making any decision.
Mhairi
« Reply #16 on: August 06, 2010, 11:09:46 PM »
I guess it is best to go with your mechanic.
Try write down the technical details of what went wrong and we can try give our 5p worth one how to make sure it doesnt happen again.
Good luck, hope the car isn't a non-runner for long :o
kitten75
« Reply #17 on: August 06, 2010, 11:13:33 PM »
Thanks - will just be sad tomorrow and take notes when he's going over what went wrong!  On the plus side he thinks he's got a buyer for my Peugeot so i'll be able to buy the Fiat a new air freshener and bumper sticker at the very least!
watch this space tomorrow for my hilarious description of what is actually wrong!
Mhairi
« Reply #18 on: August 06, 2010, 11:22:55 PM »
 I`m not trying to scare you! I think Darrell explained it a bit better. You need to get to the bottom of things first, to understand what happened, and than make preventions to minimise the chance of it happening again as the bis engines do suffer with overheating.
 I hope it gets sorted one way, or the other as you like the car so much [-/
« Reply #19 on: August 06, 2010, 11:51:58 PM »
I run an aircooled engine.
I took the engine out to rebuilt and re-fitted a 500cc (£50), didn't realise it was loosing oil through the main bearing while running and sezied it. I then bought another 2nd hander for £80 from a guy on a farm. Emgine hasn't let me down since.
If you buy a new engine, the head gasket might bloe.
If you buy a second hand engine, the head gasket might blow, but it will have cost you far less money. A new engine won't sort out the poor water flow of a bis engine, but we are all here to offer help whenever you need it.
Michael
kitten75
« Reply #20 on: August 07, 2010, 10:58:15 PM »
Right, bear with me whilst i try to explain...had long discussion with Robert (mechanic) and he showed me my little car with engine in bits,  boo, but to be honest it was over 12 hours ago and I'm struggling to remember - should have taken my notepad, oops.
what I can remember is that one of the springs on one of the valves completely disintegrated whilst i was driving and that's what  he said has caused the damage.  the little nut type things that bolt the valves to the 'rocker feet' had also broken.  He didn't think this any of the damage was due to overheating, he just said he thought I was unlucky!  he said he would be wary of rebuilding the existing engine as there's a danger in rebuilding the top half of the engine and not the bottom half, and then a problem occurs in the bottom half and then they aren't in harmony>! Please excuse this - not his exact words and like i say I never took notes so if it doesn't make sense then blame me!  Maybe I'll get Robert to join the forum and he can be my 'voice'!.
 I explained to him all the points everyone has raised about the design fault and problems with BIS engines overheating etc however he kind of agreed with what everyone has said so far in that - it's risk you've got take if you want to drive a 126!
On further investigation there was an invoice in the log book from 1994 (car is a 1990) and the engine was rebuilt then for some reason...again Robert said he would be concerned about rebuilding the engine given that it had £700 worth of work done on it 4 years after registration?
he's going to do a local part search for a 2nd hand engine and let me know Tuesday if he's come up with anything that he thinks is decent, failing that new engine from Fiat it will have to be.  Labour is looking like £200-300 so all in worst case scenario i'm looking at £1k - oops.  Also found the purchase invoice for the car and it was bought for £1300 back in the day so i've already spent more than it was originally bought for...!  Just as well i totally love my little car...
Took my ever faithful Peugeot to him today and told him whatever money he sells it for to put on my account for the Fiat!  Fingers crossed he sells it quickly...sad to see it go even though it was a 1998, never had a problem with it in the whole 5 years i've owned it.  somehow i don't think i'll be saying that again...
Mhairi
« Reply #21 on: August 07, 2010, 11:14:55 PM »
Just my observation from what you wrote: valve springs can break but rarely. The air cooled engines have 2 springs, don't know in the BIS, but that's why there are 2 springs so that if 1 breaks the other spring won't let the valve fall in. He didn't mention anything about  the timing chain breaking?
If the block isn't badly worn, damaged (e.g. cracked) then i don't see why it has to be replaced.  If the pistons aren't damaged (even then you can  replace the pistons and the piston rings, worse if you have to replace the conrods too)  then you may just need a new cylinder head or have the cylinder head repaired. (Just my opinion)
« Last Edit: August 07, 2010, 11:20:53 PM by GTMaster »
kitten75
« Reply #22 on: August 07, 2010, 11:49:30 PM »
there was only one large spring on each valve. No mention of timing chain breaking. I did ask if I could get away with just a head gasket repair but that's when he said he didn't like to rebuild the top half of the engine and not the bottom at the same time?
I meant to ask if the engine block was ok but forgot...was trying to remember all the earliers posts and points raised without pulling out my iphone and reading the comments to him!
M
« Reply #23 on: August 08, 2010, 09:53:20 AM »
Buy a second hand engine off ebay and put it in yourself, 1K is too much to have yours repaired proberbly be good though if it's done!  Mine went so got a second hand one for £75 put it in and never looked back has been great!
Worm
« Reply #24 on: August 08, 2010, 09:57:04 AM »
Got to agree, but if you cant due to know how then so be it O0 £1000 then you will be back on the road to enjoy the rest of the summer O0 O0 O0
« Reply #25 on: August 08, 2010, 10:44:00 AM »
Shame you are not nearer otherwise I would love to help!
kitten75
« Reply #27 on: August 08, 2010, 10:57:56 PM »
thanks Ciaoflyer...i wish you were closer too so you could help!  re engine for a tenner...why is it so cheap when all the other engines on Ebay are hundreds of pounds??  anyway, can't get to Kent to pick it up so it's a no go.  I'll see if Robert is able to source a 2nd hand one tomorrow...
m
« Reply #28 on: August 09, 2010, 08:58:50 AM »
I recon if you ask the seller to courier it to you he might be tempted, make it worth his while  [-/
The diference is trade versus a private sale. The trade put things at a price they think they can sell them for, and when you desparate, you pay...
kitten75
« Reply #29 on: August 09, 2010, 10:02:57 AM »
"was told engine was running at time of removal" - there's no guarantee the engine is in full working order so it would be tenner plus courier of about £100 or so - bit risky?
m
