I had alot of it apart this weekend, thought I'd check the fan and that seems fine and spinning the altenator by hand it is free and unobstructed, all blades in place. The deflector is in place. I've welded-up the hole where the air cleaner was.
The oil light only comes-on when it is hot (running for a while)
I checked the carb joint and that seems good so don't think she's running lean.
I tried different curves on the 123 ignition, but no matter which one I use, it ends-up in the same result, oil light on and pinking up hills.
I am beginning to suspect lubrication and will strip it completely this weekend, check bearings and oil pump
