I'll have a look at that this weekend Rusty [-/
I'm going a bit crazy here, I've ordered new bearings new oil pump, the fancy 4 litre ally sump, the ally extended rocker cover, a new thermostat and a few other bits and bobs. The idea is to get cracking on it this weekend and solve the oil pressure problem once and for all and add extra cooling.
I've wanted to upgrade the sump for a while now and the rocket cover and figure the extended one will give bigger volume on top of the head therefore reducing the amount the gasses can be compressed...we'll see if there is any merit in the theory however the bigger block of ally with fins is bound to give-off more heat.
Once the oil issue is sorted it's off to the local dyno tune bunch to do a tune-up, make sure the mixture and timing are 100% right according to a tuning guru.
I'm not certain about a horsepower test with fresh bearings in her, perhaps i'll do that another time but with a bit of luck any overheating will become a thing of the past [-/ If all is good and I'm confident the issues are gone, I might ask for a little test with not too many revs
