Author Topic: Guido the Fiat  (Read 87579 times)
0 Members and 5 Guests are viewing this topic.
Guido the Fiat
« Reply #75 on: June 21, 2008, 09:04:22 AM »
It is good, I found it on the net when I was trying to fit alloys to mine!
Guido the Fiat
« Reply #76 on: June 21, 2008, 01:19:12 PM »
I gave up on alloys for now, all my tyres are brand new, and unless i find the same size wheels, im gunna stick with these untill they wear out. plus my white wheelcovers match the car nicely, and it will be hard finding white wheels... which reminds me, can alloy wheels be resprayed? whats the procedure?
Guido the Fiat
« Reply #77 on: June 21, 2008, 04:25:37 PM »
they can be but its better to have the blasted and powder coated costs about £20-25 a rim (it does mean you can buy dirty scabby wheels no one else wants as powdercoating brings them up like new!!!
Guido the Fiat
« Reply #78 on: June 21, 2008, 07:09:20 PM »
o r depending on the alloys and your prepwork use some hammerite smooth it does a very good job thats a sight less cheaper and keeps you fully hansd on with your resto/cutomising
Guido the Fiat
« Reply #79 on: June 30, 2008, 09:20:38 AM »
well, it just wouldnt be fun without problems... now my box is leaking oil....
its leaking where the rubber seals hold to the drive shafts... just dont understand why, since they didnt leak before the box swap... the question is will it stop if i replace just the rubber seals?
Guido the Fiat
« Reply #80 on: June 30, 2008, 01:15:29 PM »
ok, found those rubber seals, 2.8pounds each  :D  so im gunna replacem.. should stop the oil from leaking out (im not in a hurry though, cos i poured in 2 liter of box oil, and the specs recomend 1.1 liter... lol  :cool: )
phreak97
  • Niki!
Guido the Fiat
« Reply #81 on: July 27, 2008, 04:35:33 PM »
i thought it was bad to overfill a gearbox?
just undo the level plug on the side and itll drain back down to where it should be (with your car on a level surface). it's a half inch square, stick a half inch socket extension on it then use a half inch spanner to turn the end of the extension.
that's probably why it's leaking too.. the level is between the bottom of the rubber and the drive shaft, if you fill it right up to the drive shaft then itll leak out between the shaft and the rubber.
phreak97
Guido the Fiat
« Reply #82 on: July 27, 2008, 04:48:36 PM »
the leak is sorted, replaced the rubber seals (wery cheap :D ) and the leaking stopped  :D  :D
i returned about 1,5 liters, which is 0,4 liters above spec standards, so far its working ok, so ill just leave it be. Gearboxes are really cheap here, so i can always replace it if i scr€w something up....  :lol:  :lol:
p.s. the airc. box i fitted is even better than the bis model, i can drive in third now up rather steep hills, which was inpossible with the orig box si id actually recommend this swap to anyone living in a hilly area :cool:
phreak97
  • Niki!
Guido the Fiat
« Reply #83 on: July 27, 2008, 04:58:48 PM »
mine already has an aircooled box, cos it's aircooled:P
is the watercooled engine much more powerful? what size is it?
by the way cro, i added you to my msn list. dunno if you use it or not though..
phreak97
Guido the Fiat
« Reply #84 on: July 27, 2008, 05:10:03 PM »
dk if its much more powerful, newer ridden an aircooled, it has 26hp, over the aircooleds 23hp, i beat local aircooleds easilly when racing :D  :D  (at ludacris speeds of 60-70kmh  :lol: )... it has 703cc of pure musclepower :D .
i dont use msn, newer got around to installing it, but i use facebook, Gordan Josić is the name :wink:
Guido the Fiat
« Reply #85 on: August 05, 2008, 08:01:08 PM »
Hi Gordan, if there just discoloured you can spray them with satin black until you find a pair of good original door cards  :D
Guido the Fiat
« Reply #86 on: August 05, 2008, 08:36:11 PM »
You know, i thought about it, but it isnt that theyre dirty, its that they somehow shrank, and keep poping out of those brackets in the doors, its kinda ugly....  :???:  so im trying to locate nice vynil ones, since im trying to make it look more retro...  :D
Guido the Fiat
« Reply #88 on: August 06, 2008, 07:21:56 AM »
Dont understand a thing on that site...  :cry:
well except "lewy bok"....  :D  (what about desny bok"  :P
Guido the Fiat
« Reply #89 on: August 06, 2008, 04:14:08 PM »
Sorry. it's a brand new drivers side door panel cost:- about £5
