Author Topic: First gear  (Read 13066 times)
First gear
« on: January 21, 2008, 04:13:18 PM »
Ive got an annoying problem on my bis and would be grateful for any feedback whatsoever..
Thing is: when I come to a complete halt on the smallest hill, and try to move again, the car starts shaking badly, and sometimes pops out of fitrst gear.. The only way for this not to happen is to release the clutch wery quickly but then it pulls foreward not too comfortably...
Thanx for any info.   :smt006
MaLi
First gear
« Reply #1 on: January 21, 2008, 07:09:00 PM »
You might need a new clutch.
First gear
« Reply #2 on: January 21, 2008, 07:22:19 PM »
You think so? I just hope that the gear isnt somehow messed up cos I dont think i could get one let alone install it??
This doesnt happen in any other gear, and at this point its starting to get rather embarassing  :oops:
banjomandolin
Wobbling engine.
« Reply #3 on: January 21, 2008, 08:11:03 PM »
Check your engine and gearbox mountings, i.e. one engine, two gearbox. There is one new gearbox mounting for sale on e-bay at present "Buy it now" £25.
banjo
John Clark
First gear
« Reply #4 on: January 21, 2008, 08:20:41 PM »
If there is an oil leaking from the bell housing this can contaminate the clutch plate and give the same problem. if not check the free play on clutch arm it should measure 8-10mm and can be adjusted using the nut at the end of the clutch cable
First gear
« Reply #5 on: January 21, 2008, 09:49:00 PM »
There is an oil leak on the bell housing, there is always some oil under the bell. What shuld I do? remove the gearbox and replace the clutch or just clean and replace the gaskets?
First gear
« Reply #6 on: January 21, 2008, 10:55:11 PM »
It sounds like you have the same trouble as i did, so you will have to replace the clutch plate, rear bearing and seal as this is where the oil is leaking out, the rear bearing wears oval and the oil seal does not seal because the crank jumps up and down, its not a hard job to do but you have to take the engine out.
the rear bearing cap and seal are not expensive around 20 Euro could be cheaper where you are + the clutch wether you fit the complete 3 piece or just the plate you will no when you have inspected them. this is a pic of the rear bearing i replaced.
as you can see there is no white metal left
First gear
« Reply #7 on: January 22, 2008, 05:08:43 PM »
This happend on a bis i had years ago, it would shake and judder in 1st only, it turned out to be the spiggot bearing in the centre of the flywheel, at the time, i managed to get one from the local fiat dealer but i don't know wheres best now?
First gear
« Reply #8 on: January 22, 2008, 05:16:48 PM »
I was afraid of that. Taking engines out is not my favourite thing to do but ill do  what must be done...  :???:
Thanx pete for all your info, it has sure saved me a lot of trouble, ill report back when it is done...(I need to gather all my courage, and study removing the engine in the manual) Thanks again. :smt023
First gear
« Reply #9 on: January 22, 2008, 05:20:54 PM »
Does the engine really have to be removed?
The manual sates that it only has to be lowered a bit to facilitate the removal of the gearbox.  :smt017
First gear
« Reply #10 on: January 22, 2008, 07:05:52 PM »
I found removing the engine is the easiest way unless you have access to a four poster ramp, leave the gearbox in the car and support it on an axel stand when everything has been disconnected jack the engine up on a trolly jack and wheel it out of the back.
Its also alot easier to remove the clutch, flywheel and replace the bearing holder, crankshaft oil seal working on a bench.
while its out you can clean the centrifugal oil filter which always gets forgotten
First gear
« Reply #11 on: January 22, 2008, 08:14:30 PM »
I found the 3 piece clutch in a local store for 55€, and have to look up other parts later, The problem with removing the engine is that i dont have a jack for the engine so ill have to find another way. (it costs about 150€ and Id rather buy some bits and pieces for my BIS, or another 126  :lol: )
I was about to clean the filter anyway one of these days so ill do it all together.
Do u think it would be better to find a used bis gearbox and replace the whole thing? (does the aircooled version have the same gearbox?)
I could probably get the whole engine and gearbox cheaper than the clutch alone  :???:
First gear
« Reply #12 on: January 22, 2008, 09:31:26 PM »
you don't really need a trolley jack, if you got someone to help you its very easy to lift out once the back panel is off, there not very heavy, if you take the engine out first inspect the pressure plate  and thrust bearing if there o.k. just renewing the clutch plate, rear bearing and seal.
not sure about the aircooled box maybe some one on the forum could tell you.
First gear
« Reply #13 on: January 22, 2008, 10:07:46 PM »
I did some reserch on the net and it turns up that the bis has a larger clutch (160mm diaphragm opposed to 155mm diaphragm on the air c.)
Ill take the whole thing out and ispect it,replace what needs replacing and put it back together (hopefully). Simple as that...
Should i change the gearbox oil? dont htink it has been changed ever...(dont have much exp. with these things, just learnig  :wink: )
First gear
« Reply #14 on: January 22, 2008, 11:47:07 PM »
yes. change the gearbox oil but remember when you refill it the gearbox should be level or you could over or underfill it, if you get stuck just ask.
