Author Topic: First gear  (Read 13066 times)
First gear
« Reply #30 on: February 13, 2008, 06:32:52 PM »
just been on the gerste site and there all listed with the same part number :)
First gear
« Reply #31 on: February 13, 2008, 07:45:46 PM »
yes, they seem to be the same, but i still cant seem to find one....
Did you replace both those bearings ( the one on the oil filter side asvell) or just the flywheel one? Was it just replacing the parts with new ones cos some people told me i gotta skim that shaft that goes thru the bearing??? im getting more and more confused.... :sad:  :x
First gear
« Reply #32 on: February 13, 2008, 08:51:35 PM »
I've stripped a few of these engines and it seems, its just the back bearing that wears probably due to weight of the flywheel/clutch and flexing, if you get the crank ground it starts to get expensive and you end up with this :D
if you just replace the rear bearing it should last for quite a while, you can get them from Germany for 20euros, once its back up and running look for a good spare engine.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=160135498427&ssPageName=STRK:MEWA:IT&ih=006
ask around there must be someone you know with an Ebay account. :)
First gear
« Reply #33 on: February 13, 2008, 09:47:50 PM »
OMG, I certainly dont want that, but it also looks so nice and shiny....  :wink:
I was thinking about a whole spare car, but a engine would do nice, ill certainly keep an eye out....
First gear
« Reply #34 on: February 13, 2008, 09:49:43 PM »
oooohhhh, that engine looks nice like that... shiney i mean, would hate to reasemble it... wouldnt know where to start, hope you get it sorted gordan
First gear
« Reply #35 on: February 13, 2008, 10:17:48 PM »
that one is petes, i wouldnt dare take it apart.... :wink:
(SHIIIIINYYYYYYYYYY :!:  :D  :D  :D )
im just so pissed off, ewerything always goes wrong.... i just bought a new type of seal and put the engine back in just to try it, and then the screw that holds that spring that holds the engine broke... i mean really, throw me a freakin bone!!!! :twisted:  :wink: (but i aint mad, ill get it done tommorow...)
First gear
« Reply #36 on: April 01, 2008, 02:14:23 PM »
yesterday i replaced my clutch cover and release bearing and ive noticed that the input shaft has a lot of free play in every direction. now is this normal or does this mean some bearing is on holiday...??  :wink:
ive found a replaceement gearbox so ill replace tho whole thing...
THANX... G
First gear
« Reply #37 on: April 01, 2008, 09:06:08 PM »
cmon guys, someone must know somehing...
this is really bothering me..... :sad:  :sad:
First gear
« Reply #38 on: April 01, 2008, 10:49:57 PM »
Sorry to here your still having problems, But i think it all stems from the worn rear bearing.
If C. is worn, the crank oscillates up/down side/side this wears the spiggot hole where the input shaft sits in the end of the crank, also wears B. the bearing on the input shaft as it pivots on the bearing and finally the end A. if you just replace the gearbox the same will happen again,
the only advice i can offer is try and find another engine and gearbox :sad:
First gear
« Reply #39 on: April 02, 2008, 10:33:59 AM »
im ordering that bearing from the site you recomended as i failed to find one locally, i found the main bearing on the oil filter side so ill replace it too, and im gunna replace the box, and see what happens.... hoping for the best....
Maddog
First gear
« Reply #40 on: April 02, 2008, 03:54:16 PM »
the gearbox input shaft does have a lot of free play, it's meant to be like that, as long as the seal isn't leaking then it is fine, it is always supported by either the clutch or thrust release bearing which keeps it centred
First gear
« Reply #41 on: April 02, 2008, 04:30:46 PM »
okay... so i just need to get those damn bearings.... gggrrrrrrrrrrrrr!!!!!!
i vonder if i can fit two same bearings as i can get this one but the other i have to order online, , and i never liked this kind of shopping...  :cry:
again, thanks for all your input.
First gear
« Reply #42 on: April 02, 2008, 04:47:55 PM »
whoops, ignore the last post, its obvious from a pic that they do not fit...   :oops:
First gear
« Reply #43 on: April 02, 2008, 06:40:26 PM »
As Maddog said there is always a little play on the input shaft, i can't find any info about how much. one other thing to check is the outside diameter of the input shaft where it goes into the crank and the inside diam" of the hole in the crank to check its not worn.
The bearing in your pic is the front one.
First gear
« Reply #44 on: April 13, 2008, 04:45:19 PM »
Just found myself a new engine and gearbox in trieste, italy. it has a better carb than mine a new fuelpump and only has 70000km on it (mine has 93000...) the only prob is the guy wants 200€ for the eng and box so all i need to do now is wait for my next paycheck, and hope it wont be sold... all the while my bis will be sitting outside, motionless.. alone.. afraid...  :sad:  :cry:  :cry:
