Author Topic: First gear  (Read 13066 times)
First gear
« Reply #15 on: January 23, 2008, 02:54:38 PM »
Will do, Thanx.
First gear
« Reply #16 on: January 26, 2008, 08:46:17 PM »
Still havent started the work, currently gathering info and waiting for my salary....
Pete,  I was hoping you could send me a pic where the parts you replaced are located, I red the manual but couldnt find a bearing looking like the one on your pic, or the one in your garage... :smt017
Thanx in advance. :smt045
First gear
« Reply #17 on: January 26, 2008, 10:18:16 PM »
i'll sort some pics out in the next couple of days.
First gear
« Reply #18 on: January 28, 2008, 07:59:06 PM »
The rear bearing and oil seal live behind the flywheel
Heres a pic of the clutch components
from left to right, Clutch release bearing, Clutch cover, Driven plate, Flywheel and rear bearing cap and oil seal.
two things to remember when re-assembling, the fly wheel must go back in the same position you have taken it off.
the new driven plate needs to be centralized before you tighten the clutch cover up fully.
First gear
« Reply #19 on: January 29, 2008, 08:37:23 PM »
I took the engine out today. The rear bearing looks just like the one in your pics and Ill be replacing it shortly. The bell housing had a puddle of oil in it so i cleaned it up. I dont think ill change the clutch becouse it looks good (it has apparently been changed recently). all other parts seem to be okay, so i hope the new rear bearing will solve the problem.
And i cleaned the oil filter- it was full of black, plastic-like mass, and it looks good now.
First gear
« Reply #20 on: February 04, 2008, 05:26:04 PM »
I put the engine back in today, took it for a little spin and seems that the problem is solved. I turns out that the oil in the bell housing was the problem. I replaced the seal on the bearing and used some sealing paste on it so i dont think itll be leaking any time soon  :wink:
Thanks Pete for all your help,it sure has saved me a lot of trouble and a few headaches.  :smt039
It felt soo good to hear that little engine rumbling after a whole week of silence....  :smt041  :smt041  :smt041
Cheers! :smt025
First gear
« Reply #21 on: February 04, 2008, 06:09:12 PM »
Great News Gordon,  :smt041
First gear
« Reply #22 on: February 12, 2008, 09:02:28 PM »
Episode 2:
OIL STRIKES BACK.....
The bloody problem has returned, seems I did a bad job at sealing that bearing....  :cry: it just took the oil some time to accumulate...  Ill be taking the engine out tommorow (AGAIN, i fear this becoming a habbit :!: ) and i plan to go to the local FIAT dealer to see if they can get the whole part....
I dont get it, I replaced the front seal (the orange one), but I didnt replace the thin rear one, so this must be the problem.... :x
First gear
« Reply #23 on: February 12, 2008, 10:13:42 PM »
Hi Gordon sorry to here that. you haven't done a bad job, i don't think it will be leaking oil from the big O ring seal as you sealed it with silicon seal.
what i think is that the end bearing shell is worn and has gone oval, as the engine runs the crank oscillates up and down and the orange oil seal opens because it can not seal as its being pulled up and down very fast and allows the oil to leak out.
You can check this when you have the engine out again by pulling the flywheel up and down, if you can feel some play its best to replace the complete bearing end cap.
If you can remember when you took the bearing cap off, if it looked like this a copper colour it does need replacing, it should be white metal on all the surfaces
Good luck for tomorrow, i'll be doing the same thing and replacing my front oil seal on the timing chain cover. :)
First gear
« Reply #24 on: February 12, 2008, 10:49:11 PM »
it was copper coloured, just hope those fiat guys have it, cos im running out of options... (hope they dont start laughing when i ask about it.... :D )
First gear
« Reply #25 on: February 12, 2008, 10:54:48 PM »
should have the engine out in 30mins :D  :D
First gear
« Reply #26 on: February 12, 2008, 11:02:31 PM »
30mins.... nice, takes me a bit longer but ill get there...
well, best of luck... to both of us!!! :wink:  :D
P.s. just wondering, how many times did you take it out??? :?:
First gear
« Reply #27 on: February 12, 2008, 11:45:29 PM »
Just once (touch wood) the front oil seal was my own fault (doh), when i was fitting the electric fuel pump i connected the electrics and fuel pipes and thought i would just test it before i mounted the pump, so i put it on top of the engine. Then i thought that will rattle , so i put a big piece of rag under the pump went to the front to start it, started first time (yipee) blipped the throttle a few times then the engine started to slow down so i switch off and went round the back.
when i looked at the engine the rag had been caught by the fan belt and wound itself round the front pulley so tight that i had to cut it off in little bits with a stanley knife, when i got it all off it noticed that it had pushed the oil seal back through the timing cover :D  :D  :D well you live and learn, won't do that trick again.
First gear
« Reply #28 on: February 13, 2008, 10:18:41 AM »
hi pete the aircooled is the same job .
First gear
« Reply #29 on: February 13, 2008, 10:53:22 AM »
LOL pete, wont be doing anything with rags round my engine, thank you wery much... :D
Another question, and this one goes out to all members, does the aircooled have the same rear bearing??  :?:  (would be easirer to get one surely)
