Author Topic: Rear Hub safety modification  (Read 4220 times)
barchetta
« on: September 12, 2007, 07:27:11 PM »
Its been a common occurance that the rear stub axles has come loose on 126's and 500's fitted with the 126 hubs when the rear hub nut that is peened in place has worked loose. a 500 club member lost his stub axle at 50mph on a french motorway!
 The original 500 had a drilled stub axle and a split pin was fitted to stop the nut coming loose. To make the 126 as safe as this i have had a locking plate machined up ,it  fits between the aluminium cush drive and the drive flange and stops the nut coming undone.
 I have asked the machine shop to make some more and they have given me a price of 4 pounds each, however to do this i need to order a certain quantity.
If anyone is interested please email me at [email protected] and i can give you more details and email a photo. i can take numbers now that you all need and you can pay after i have had the batch machined up.
« Reply #1 on: September 12, 2007, 11:18:26 PM »
if these have come loose its because the parts have not been replaced with new when refitted , so its a very dangerous and expensive shortcut.
if you wish to redesign the stub axle fitting thats up to you but isnt really neccessary , just sensible use of new parts and regular maintainance should be fine.
barchetta
safety repair
« Reply #2 on: September 13, 2007, 10:21:45 AM »
yes in an ideal world there would be no failures ,but this problem has happened to cars that have been correctly serviced by dealers ,i witnessed one failure where a new nut had been fitted and the 'notch' peened into the slot in the stub axle had split and fell out so there was no location .i would call this is a peace of mind modification to supplement the original fiat locking nut because if there is a failure of the locking nut then the result could be serious.
« Reply #3 on: September 13, 2007, 04:40:48 PM »
Do you wrear a helmet when you drive by any chance? :D
barchetta
safety modification
« Reply #4 on: September 13, 2007, 08:14:39 PM »
Sorry but i dont wear a crash hat,i was expecting sensible replies to the post but should have made exceptions from 126 owners from Chavland.
« Reply #5 on: September 13, 2007, 10:04:36 PM »
Thank you.
As explained! You are trying to repair something that is not broken.
meuton
Re: safety modification
« Reply #6 on: September 13, 2007, 10:11:47 PM »
Quote from: "barchetta"
come on now barchetta I think what the owners are trying to say is MOOOOOOOOOOOOooooooooooooooooooooo...oh sorry that just slipped out,
well if our cars can only go at slightly faster than walking pace and put out less power than a childs watch then and excaluding extreme on off failures, they don't feel the need for a belt and braces, now pu thte toysback in the buggy and play nicely with the other boys and girls
cheers Doug
Its slow but it does it in style !!
« Reply #7 on: September 13, 2007, 10:21:52 PM »
hay, i lernt that the 126 site is full of jokers! but if it aint broke dont fix it. a 126 is suppose to fall to bits now and again, thats why clowns buy em... lol..........
giggle
banjomandolin
Rear stub axle.
« Reply #8 on: September 13, 2007, 11:49:53 PM »
I have owned numerous rear engined Fiats and they all have the same arrangement i.e.a large castellated nut with split pin - perfectly safe, well designed and I see no reason to start visualising problems when there aren't any.
Banjo
John Clark
barchetta
Rear Hub Safety Modification
« Reply #9 on: September 14, 2007, 07:03:25 AM »
Hi Banjo,
 The castellated nut and split pin is a belt and braces locking mechanism as fitted to 500's etc..
 Unfortunately the 126 has a slot in the stub axle and you peen in the top of the rear hub nut to lock it in place , A new nut should be fitted every time the stub axle is removed ,However if the process of hammering the top of the nut into the slot is not deep enough or you hammer too far in and the top lip of the nut breaks off you have problems, This nut is only tightened to the correct pre-load of the bearing and if it is not locked into place can come loose. Maybe the owners of the cars it happened to did not do the job 100% ,This mod would have prevented the wheel coming loose and  causing a serious accident.
Maddog
« Reply #10 on: September 14, 2007, 02:04:04 PM »
Quote
your right its a cost cutting measure which can come loose if not fitted properly, its a not uncommon design on lots of moderns but as long as a new nut is used and peened in properly with a punch/screwdriver it will stay in place, there is very little rotational force acting on it, also, only the N/S wheel will come off, the O/S will just overtighten the bearing
banjomandolin
Rear Stub Axle Nut.
« Reply #11 on: September 14, 2007, 08:39:13 PM »
Hi barchetta, you are quite right. I have just been outside to my shed and found a spare  rear stub axle assembly for 126 and one for 133. The 126 has slot in axle shaft arrangement, the 133 has castellated / split pin arrangement so my post last night was wrong. My excuse is that during the day I did a round trip of 130 miles in my 2cv to look at a Bis in Lincolnshire and didn't buy it because of its poorly bodywork so I was trying to work off some of my frustration on something. I agree that re-using a peened nut is fraught with danger but have to own up to doing it myself but only after fitting an extra washer on the splined shaft which allows you to peen the nut at a different point on the circumference.
I will buy one of your widgets when I can find a Bis to fit it to. Who has a Bis body to sell me (not white) ?. I have so many mechanical parts they are coming out of my ears.
banjo.
John Clark
Tommo32
« Reply #12 on: September 15, 2007, 09:06:35 PM »
stick a bit of locktite on it. or drill the exposed thread and stick a split pin through. i like to live dangerously! and having had wheels fall off in the past its not all as bad as it sounds. I was going down hill in the landrover once and the wheel came off, bounced through the tailgate window of a honda civic. nasty stuff.
dexter
Re: Rear Stub Axle Nut.
« Reply #13 on: September 20, 2007, 03:25:15 PM »
Quote from: "banjomandolin"
banjo.
sorry to high jack the thread was this bis in lincoln in gainsbrough? and is it the one on another forum?
old people are like slinkys.....not much use but they make you smile when you push them down stairs....
if any one knows to mk2 granada parts please pm me. i have a love for old rusty cars,what ever they are !!!!!!!!!!!!!!!!!!!
Bruce
« Reply #14 on: September 20, 2007, 06:12:16 PM »
i had the rear wheel come off a motorbike once, forgot to put the split pin in, was quite interesting, luckely it happened pulling away from lights. might not have been so much fun if it happened at speed.
