Author Topic: Rear Hub safety modification  (Read 4221 times)
hudsonhenry
    • http://www.retro500.com
« Reply #15 on: September 21, 2007, 06:29:31 PM »
Sounds like a good idea to me, I had a nut come off my hub on the M25. I was lucky that I felt the vibration before the wheel fell off, I came off at the next junction. When I jacked up the back of the car I pulled off the wheel and hub!
I had been a bit hasty when fitting new bearings, I should have adjusted the nut, peened it over then gone around the block, and then checked that it was still OK. I have done many of these bearings and always check after a couple of miles, except on this occasion.
I would be interested in a set
Nigel
