Author Topic: brakes ... arghhhhhhhhhhhhh  (Read 15070 times)
richard
« on: August 13, 2006, 10:44:21 AM »
HELLO THERE PEEPS ...
RIGHT THIS IS WHERE I STAND WITH MY FIAT 500 BRAKES ...
IVE CHANGED THE FUEL LINES, AND BLEED NIPPLES . AND MASTER CYLINDER ..
NOW I AM ATTEMPTING TO BLEED UP THE SYSTEM ...
I HAVE NO LEAKS FROM WHAT I CAN SEE , BUT STILL A AWFUL LOT OF AIR FROM SOMEWHERE ???
AND THE PEDAL DOESNT GET HARDER ????
ANYBODY GOT ANY SUGGESTIONS ???
HAVE I MAYBE GOT DODGY WHEEL BRAKE CYLINDERS? BUT WOULDNT THEY LEAK ?? IF FAULTY ???
HELP ME PLEASE ..
ALL THE BEST
OH AND IVE GOT SKYPE NOW
SO ADD ME : MY USER NAME IS RICHEMON
« Reply #1 on: August 13, 2006, 11:49:34 AM »
hi rich,they can be a pain,but keep cool,if all is new then just make sure your reservour is full and bleed from the furthest wheel away ending up with the closest one,how are you doing it?? if they are being awkward,a good way (landrovers series2 need this) is to have a helper  who slowly depresses the pedal to full down,then you lock the nipple before they slowly return the pedal to full up,un lock and do again all round.
sometimes air just goes back and forth,this stops that.
the discs kit i just fitted would not bleed in the normal way,had to use this old trick
« Reply #2 on: August 13, 2006, 01:13:45 PM »
They can be a right sod sometimes to do!
I tried and tried after renewing my brake system and just could not get it right in the end I bought a Gunsons Eezi-Bleed kit
It worked great!
neil 126
« Reply #3 on: August 13, 2006, 04:33:15 PM »
yep, just ad the very same problem.
air was entering the slave cylinders when the brake peddal was released, it was getting in between the threads of the bleed nipple and cylinder. very very frustrating, i lost my rag a bit with this one, in the end i got an easy bleed kit, it worked a treat, but you must dry pressure test it for leaks, or you may end up spitting brake fluid all over your piantwork. trust me i know.
learnt it the hard way
richard
thank you
« Reply #4 on: August 13, 2006, 06:11:54 PM »
thanks for your info , i will persue it . at a later date.
as i must move on with primer and paint as weather is getting colder .
all the best and thank you
will of course keep you posted
thanks all
« Reply #5 on: August 14, 2006, 06:47:29 PM »
Found this info in the 500 shop manual
richard
update..
« Reply #6 on: August 18, 2006, 06:36:15 PM »
on closer inspection of the front drivers side hub , i noticed alot of brake fluid inside it after removal ???
and the drums / liners of the brakes were shot and corroded ..
and funnily enough ?? the brake pedal from being very very soft now is hard as anything ???
i really am thrown by all this ?
i have ordered 2 new wheels cylinders from ebay and will replace them .. and try it again in a few weeks when i get time
reguards
richard
« Reply #7 on: August 18, 2006, 07:35:59 PM »
oh rich...............i thought you had renewd everything like a good boy would....................................all advice i and others gave was for bleeding after a complete brake overhaul (that you should have done)................................ :roll:
i hope the rest of your 'restoration' is to a higher standard??????????
richard
really ???
« Reply #8 on: August 18, 2006, 11:25:54 PM »
what restoration ?
 and what standard ???
i am a ametuer ( if i could spell it )  ...
it wont be perfect and im making alot of mistakes as i go, i am however learning slowly ..
if your expecting a mint looking fiat 500 at the end of this you will be dissipointed..
i however wont be, as all bits and bobs and many many jobs would have been done by me , and i will have total excitment for the vehicle ..
rather than buying a minter ( which i had ,but sold ) ..
or rather than just paying a garage 10k to do a complete resto and have no excitment or joy out of it ...
hey wish i was as handy as some of you lot.... thing is im not and i dont pretend to be anything other than a enthusiast on a budjet . who loves his little 500
i will keep u posted ..
« Reply #9 on: August 19, 2006, 06:56:32 AM »
hi rich,i'm sorry if that post was a bit harsh....... :sad: ,but you really cannot skimp on brakes..or suspension etc,but any budget you have should pay for brakes first mate..all that work will be wasted if you hit the anchors and the little car pulls across the road into a tree or summit 'cause a wheel cylinder has pissed all over the shoes on one wheel!!!
i only mean to be constructive rich,it really is important mate  :wink:
richard
springs ???
« Reply #10 on: August 25, 2006, 06:56:21 PM »
thank you for letting me know ..
i have actually got a box full of shoes about 20 sets so i will use some of them .
now comes the silly part , i have just brought new wheel cylinders and have dismantled one drum , and i have now lost the two springs that hold the shoes together ???
blast .........  does anybody have two i can have please?
i would gladlly pay postage ?
please let me know
« Reply #11 on: August 25, 2006, 08:09:14 PM »
rich,buy new linings.....do not mix and match from a box of old stuff,diff manufactures use diff material for the linings=diff brake action........do yourself a favour,new wheel cylinders,new linings,new master cylinder,new pipe work,new flexies,new dot 4 fluid..............................you wont regret it......otherwise i will not be happy if you behind me!!!!!........  :shock:
richard
please help ?
« Reply #12 on: August 25, 2006, 09:32:40 PM »
its ok, i have a set of shoes ... ( matching)
so cant anybody help me with the springs please?
« Reply #13 on: August 25, 2006, 09:39:31 PM »
Richard I may have some spare springs if I have I will pm you tomorrow.
C :)
richard
nice one
« Reply #14 on: August 25, 2006, 10:07:53 PM »
nice one, hope to hear from you
