Author Topic: brakes ... arghhhhhhhhhhhhh  (Read 15070 times)
richard
FOUND THEM
« Reply #15 on: August 27, 2006, 07:01:30 PM »
FOUND THEM SPRINGS ALSO... THANKS FOR EVERYONE WHO LOOKED .
I REPLACED THE FRONT DRIVERS WHEEL CYLINDER TODAY ASWELL AS SHOES ..
THE CYLINDER WAS DEFFO FAULTY , IT WAS RUSTY AS f**K AND WASNT PERFORMING ITS IN AND OUT MOTION INFACT IT WAS SEIZED UP... AND HAD OBVIOSLY BEEN LEAKING
GONNA BLEED SYSTEM UP TOMORROW AND SEE WHAT HAPPENS ..
I WILL GET THERE IN THE END ..
richard
tried bleeding ..
« Reply #16 on: August 28, 2006, 11:19:14 AM »
hello folks, further woes im afraid ....  i thought i would try a a Gunsons Eezi-Bleed kit to use to bleed my fiat 500 brakes ..
I WARN YOU ... THE BLOODY THING DOESNT FIT THE BRAKE FLIUD RESOVIOR ????
SO LIKE I IDIOT I THOUGHT IT WOULD BE OK IF I TAPED IT DOWN ...
DONT DO THIS AS I NOW KNOW TO MY COST ITS DUMPED NEALLY A LITRE OF BRAKE FLUID ALL INSIDE MY BONNENT BAY .. AND ON THE FLOOR ????
i know i was warned . this may happen , but ive now found its true ...
i will use my old method that i was using previous ...
keep you all posted ..
annoyed richard  :oops:
i struggle on :)
« Reply #17 on: August 28, 2006, 08:12:50 PM »
rich,sorry to hear that.................but use the tried and tested method i described to you.......after you have fitted NEW parts mate....... :cool:
richard
brake wooes
« Reply #18 on: September 17, 2006, 03:59:08 PM »
ive NOW replaced the front shoes / cylinders .. they are very very stiff ..
once bled will the self adjusters work and correct the shoes ???
please help reguards
richard
PaulB
« Reply #19 on: September 18, 2006, 09:15:11 AM »
Brakes suffer badly from not being used. If in doubt then replace parts - its just not worth the risk and parts are cheap enough.
Hope your paintwork survived the brake fluid. Its just all of the "joy" of car restoration to  learn the hard way - I am routinely cocking something or other up.
richard
STIFF ?
« Reply #20 on: September 18, 2006, 06:00:25 PM »
IVE REPLACED THE SHOES ETC ETC ??
THEY STILL STIFF ? WITH THEY SELF ADJUST ONCE BLED ??
« Reply #21 on: September 19, 2006, 10:59:44 PM »
Rich, Hi. Not so much on the subject of brakes but on the car itself. I have strived to restore mine on a budget as tight as a ducks ...
Some of my panel repairs were genuine fiat parts purely because i cut the metal from a fiat uno bonnet (commtment!!) and welded it in place.
The point being, if you have any 500 issues and need a low cost response, i may have come accross it. Mine went through the mot first time. any questions you can PM me on [email protected] as i dont always remember to check for messages!!
Michael
« Reply #22 on: September 19, 2006, 11:16:48 PM »
just read the bit about the bleed kit. Tried this some years ago with the same results!!
1 option is to get a for fista/escort/mondeo reservoir. Match the 2 ouptputs with hoses and merge them into one with a plastic/brass T-piece. plumb that onto the brake system. Very easy to do, easy bleed recommends 10 PSI, i got it up to 20 PSI and nothing gave. I tried this option as i was struggling to find a problem yet my brakes wouldnt work and i figured that amount of PSI would show a leak
Michael
« Reply #23 on: September 20, 2006, 06:31:41 PM »
sorry,but i still maintain you need to fit new parts to the brake system(shoes/pipes/flexis/wheel cylinders/master cylinder)drums/backplates you can getaway with s/hand/un restored.......i know diff peeps have diff budgets,but if you cannot afford decent brake parts(or lack the knowledge to rebuild used parts to a good standerd) perhaps you should re evaluate if you should be restoring the car?,however tight the budget,safety issues must not be sacrificed
126/500 brake parts are some of the cheapest i've ever seen,to me there is no excuse to cut corners
sorry to be harsh,but you could end up killing yourself,or,worse, others. :shock:
i really mean to be constructive,not damning in any way rich.
richard
NO ONE READING THIS ???
« Reply #24 on: September 22, 2006, 09:15:00 AM »
I have replaced the flexs/lines/clylinder and pads all for new ..
just wondered if they will self adjust when they get bled up ??
as i dont have any fluid in the system atall at the moment, but they are very stiff ..
if i do drive the car in reverse and slam brakes on, wont i need to have put fluid in the system first ? and if so will this adjust the brakes ?? on the new self adjesters, as i said they are very stiff ?
hudsonhenry
    • http://www.retro500.com
DON'T 'SHOUT' YOU ARE GIVING ME A HEAD ACHE
« Reply #25 on: September 22, 2006, 11:28:00 AM »
'THERE IS NO NEED TO SHOUT'
Yes somtimes the drums will be a little stiff when you replace the shoes, especialy if you try to turn the drum by hand. It should be a little easier with the wheel on. If they are solid then somthing is wrong. Once you are driving they should loosen off. To re set the adjusters, drive in reverse then hit the brakes hard (please check that they work first).
Before you drive the car in anger, test the brakes at very low speeds then stop and have a look at all the unions (joins) to make sure that there is no sign of any leaking fluids. Also check you break fluiid level on a regular basis, if this is going down then you have a leak somewhere.
Nigel
richard
thanks huds
« Reply #26 on: September 22, 2006, 12:06:55 PM »
thanks huds .. dodnt mean to shout ... sorry to everyone im just frustrated with my brake issues
i know dave and everyone can do brakes a peice of pish .. i however obviously cannot ..
this is my current situation ...
ive no fluid in the system , i am working from the front of the car and so far have replaced . shoes / lines/clyinders / .... i moved the self adjuster on its cam so i could get hub on ...  (VERY TIGHT FIT) ....
couldnt turn by hand, and when drove didnt free off that much ... IS THIS BECAUSE IVE NO FLUID IN THE SYSTEM ?..
guess i should ask the right qustions first hehe ...
please get in touch
reguards
richard
hudsonhenry
« Reply #27 on: September 22, 2006, 09:51:53 PM »
Richard if you are knowingly driving the car with no brake fluid in the system you need more help than I can give!
My advice is to get a qualified mechanic to look at it for you.
richard
??? you what ??
« Reply #28 on: September 22, 2006, 11:09:51 PM »
i am not driving the car anywhere ???
it has no mot ???
its being restored????
« Reply #29 on: September 22, 2006, 11:21:34 PM »
Richard which brakes are you having a problem with? Back or Front?
C
