Author Topic: brakes ... arghhhhhhhhhhhhh  (Read 15070 times)
« Reply #30 on: September 22, 2006, 11:36:25 PM »
hi richard, ight be worth having getting a mechanic to do them, everybody knows what a pain they are on these cars. It will be an investment, as they will have to be working well for MOT,
i hope the rest of the resto is going well
regards
richard
problems
« Reply #31 on: September 23, 2006, 08:09:30 AM »
hello there ....   ( cars ive pmd you )  ....
chris / huds etc a mechanic is not a option , it cannot be that much , as whats been pointed out before in posts .
the braking system on a fiat and fiat 126 are one of the simplest . i am just having some trouble with mine ...
here are the facts again :
new brake lines all round ..
new flexy pipes all round
new wheel cylinders all round
new brake shoes on fronts so far ( and this is where trouble is ) ..
no air or fluid in the system at present ... but front hub is very very stiff .. wont move by hand . but with drive although sticky .....  JUST UP AND DOWN MY SMALL DRIVE NOT ON THE ROAD BTW .......
and i was just wondering if bled up .. would they self adjust under pressure ?? .... i could do whats been suggested and drive backwards and slam brakes on however with no fluid in the system i fear the worst and they wouldnt work atall would they ?
furthermore i will not overlook my resto .... and consider getting rid ... ive got this far i plan on seeing it to the end ...  although not mint at end will be good enough for me ..
« Reply #32 on: September 23, 2006, 08:33:01 AM »
richard,well done on the new bits and getting this far with it,many cars have gone to the dump in bits after failed resto's.
now,with all new bits like you have stated,and assuming the drums are in good nick,(dont be afraid to use some sand paper inside them to get shot of any rust on the braking surface,and a good scrub with hot soapy water will remove any old brakefluid and dust as well),i would just carry on and fit the rest(rear) then bleed the system,the hydrulic forces are very severe inside the drums,and should center and adjust the shoes.
if this is still a problem,with new parts and correctly bled and after the gentle reverse and brake procedure,then come back on here and im sure we will sort the problem for you,however,do not be tempted to drive the car with 'binding' drums on the road ,they will quickly over heat and either distort the drums or destroy the shoes or even the wheel cylinders
dave
« Reply #33 on: September 27, 2006, 09:59:39 PM »
Hi. If you are still having binding issues with the brake then the old reverse and brake worked very well for me, but my problem was that there was no pressure in the system at all.
I've noticed that you have replaced pretty much everything and I sympathise with you as I went through the same process and still had a headache.
These are all 126 parts I presume? I fitted my fiat 500 with 126 hubs and brakes all round. No 500 brake parts at all, with the exception of the pedal box, closer inspection showed me that the push rod was too short since the 126 uses a dual circuit system whereas the 500 does not.
Another point to this is that with the 126 dual brake system, the rear brakes are activated first, so if the front is seized why isnt the rear seized?
phreak97
  • Niki!
« Reply #34 on: July 16, 2007, 04:17:52 PM »
you should never expect any part of your brakes to work if there is no fluid in the system, the system works on the pressure of the fluid pushed through the pipes by the pump (master cylinder) connected to the pedal. the very first thing you need to do before worrying about how tight things are is fill the master cylinder with brake fluid and make sure it gets through all the lines, as that manual exserpt says, loosen all bleed nipples, pump the brake pedal until fluid is coming out of all four nipples, then tighten them all, then do the same again but with only the furthest nipple loosened, then tighten that, then do the second furthest, etc until all four are done. keep the master cylinder topped up the whole time you are doing it, if you run out of fluid in the master cylinder, you have to start all over again. you only need to loosen the nipples a tiny bit, turn them an eighth of a turn, see if that works, if not then try a little further. i had to learn this on the spot when one of our cylinders locked up and the brake fluid boiled at one wheel, i had to bleed out that wheel. if you loosen it too much then you will get air going back in when you let the pedal back out. once the whole system is done, THEN you can worry about things being stiff, try reversing and braking hard, then try braking normally going forward, see how it all works after that.
as for driving it, i know alot of people who just take the risk and drive cars around the block with no rego or anything just to test things. but that comes down to how well you know your neighborhoods police content, and how clearly obvious it is that your car should not be on the road. it also means you are breaking the law, and that is never something to forget. but it is helpful:P (dont do it, if you do i dont take responsibility)
phreak97
