Author Topic: wiper relay  (Read 5010 times)
mintex
wiper relay
« on: May 16, 2015, 05:40:25 PM »
Hi.
Im after a intermittent wiper relay please, the ra23 one in this pic that cider kindly posted for me  :good:
Dave
mintex
Re: wiper relay
« Reply #1 on: May 17, 2015, 06:07:50 PM »
Or if anyone knows where i can buy one please ;)
Dave
shielsy
Re: wiper relay
« Reply #2 on: May 17, 2015, 10:03:55 PM »
scrapp yard it must be the same as most cars
andyzeetec
  • 126 BIS
Re: wiper relay
« Reply #3 on: May 18, 2015, 10:38:21 PM »
If you can't find one or an equivelent there's allways one of these..bit extreme though  :cry:
http://www.maplin.co.uk/p/k2599-intermittent-wiper-controller-ve03d
mintex
Re: wiper relay
« Reply #4 on: May 19, 2015, 08:53:41 PM »
Thanks, its an option to think about as i still haven't managed to find a suitable one yet  :(
Dave
mintex
Re: wiper relay
« Reply #5 on: June 10, 2015, 01:26:17 PM »
I finally got one, i emailed a scrap yard that was breaking one and got the full set of relays while i was at it  :yahoo:
« Last Edit: June 10, 2015, 03:05:20 PM by mintex »
Dave
andyzeetec
  • 126 BIS
Re: wiper relay
« Reply #6 on: June 10, 2015, 02:42:43 PM »
I fainally got one, i emailed a scrap yard that was breaking one and got the full set of relays while i was at it  :yahoo:
good news, you done alright there.
Bambino126
Re: wiper relay
« Reply #7 on: June 10, 2015, 09:16:48 PM »
That's good news.
Did it fix the problem?
I'll have to do that too as I still need one I think.
The problem I have is the wipers don't "park" at the bottom of the screen.
On intermittent wipe they do a single wipe and stop in the vertical position rather than horizontal.
On full speed they work fine, but when you turn them off they stop literally wherever they happen to be.
Are those the symptoms you had?
mintex
Re: wiper relay
« Reply #8 on: June 10, 2015, 09:45:47 PM »
Yes it fixed mine but my problem was i had no intermittent at all, it did nothing.
Ive had a similar problem to yours but that was on an old landrover and i fixed that.
It turned out to be the wiper motor. i opened it up and inside was 2 contact legs that are meant to touch the inside ring, one had worn away and after i bent and re shaped it so that when i put it back together it touched the contact ring then it worked perfect after  :)
This picture might help explain, its not a fiat motor but the ideas probably the same
Dave
mintex
Re: wiper relay
« Reply #9 on: June 11, 2015, 10:48:39 AM »
Also an easy way to find out if its your relay or motor is to remove the ra23 relay and try the wipers on normal speed, they should would and park as normal, they just wont do anything on the first intermittent  setting  :)
Dave
Bambino126
Re: wiper relay
« Reply #10 on: July 06, 2015, 05:22:07 PM »
Thanks Mintex
Just tried pulling the relay - you lose intemittant altogether but no change to the "park" problem.
So the problem must be inside the motor itself just like in your diagram.
I'll take it apart and try to find the fault.
Bambino126
Re: wiper relay
« Reply #11 on: July 09, 2015, 10:36:10 AM »
Mintex - What a great tip!
Took the wiper motor out and inside were two contacts just like you said, and one of them was bent. The plastic surounding it had melted for some reason. I simply bent them back into the correct position and re-fitted it. Now the wipers "park" in the correct position both for intemittant and when you switch them off from full speed.
Karma +1
Bambino126
Re: wiper relay
« Reply #12 on: July 09, 2015, 10:41:05 AM »
Now that "intermittant wipe" is actually working for the first time on my car I notice that the delay between wipes is quite long.
I've timed it at 40 seconds.
Which component controls the wiper delay?
I would like it more like 10 seconds.
Re: wiper relay
« Reply #13 on: July 09, 2015, 04:57:09 PM »
Usually there is a small electronic circuit board in the relay?
mintex
Re: wiper relay
« Reply #14 on: July 12, 2015, 11:25:45 AM »
Karma +1
Nice one, glad it worked for you bud  :)
Dave
