Author Topic: 1990 Fiat 126 BIS  (Read 41502 times)
Crusader
Re: 1990 Fiat 126 BIS
« Reply #60 on: November 21, 2015, 02:21:34 PM »
Gadge - Cheers mate, I'm really pleased with how they've turned out. I can't wait to put them in the car and see how they fit in. Best cloth seats is a great compliment.
Piotross - Thanks buddy, that was exactly the look I was going for with the design.
dombooth - Thanks pal, I have no issue with you asking how much they cost. I personally think they were very reasonable but I'll send you the answer via PM.
dadandlad
« Reply #61 on: November 21, 2015, 08:29:23 PM »
Love the seats very retro looking and certainly in keeping with the rest of the car
Mine are original but I think yours look far better  :thumbup
DeVilleChris
    • Club 126 UK
« Reply #62 on: November 21, 2015, 08:45:08 PM »
Nice looking car, those seats look ace too. I bet they look great in the car!
1979 Fiat 126 DeVille
1979 Fiat 900T Amigo
« Reply #63 on: November 22, 2015, 10:59:16 AM »
What a transformation!! Great work!!!!!
Crusader
« Reply #64 on: November 22, 2015, 04:14:52 PM »
dadandlad - Thanks buddy, don't get me wrong. I'm not knocking the original seats. But I didn't realise how much they'd faded until the original material had been stripped. They were a much darker grey originally. The plastics headrests I'd never liked so they just had to go. It's a bit like the BIS bumpers. Very plastic and grey.
DeVilleChris - Thanks mate, I can't wait to fit them. I'm away this weekend but I'm really looking forward to getting them back in the car. Got some other interior bits as well that are getting some attention.
Amateb8 - Thanks buddy, pleased you like the end result.  :D
mintex
« Reply #65 on: November 26, 2015, 03:02:38 PM »
They look good mate  :good:
Dave
Crusader
« Reply #66 on: December 11, 2015, 02:30:59 PM »
mintex - Thanks buddy.
Time for a little update on the BIS.
This was the original parcel shelf that was on the car.
As you can see from the pictures it was looking sorry for itself as it had bleached in the sunlight and had some scratches.
So I had the dilemma of what to do with it. I couldn't find a replacement part. Then I saw this thread on here.
http://retrorides.proboards.com/thread/127954/flocking-notts-based
So I contacted 'Prey' and asked him for a quote, he came back very quickly and very competitive. As he is a forum member I decided to support him. What a good decision that was. Check this out.
To say I'm impressed is an understatement, the whole experience was great. Good communication, great postage, trustworthy. I cannot recommend enough.
BHBASS
« Reply #67 on: December 16, 2015, 07:17:08 PM »
These seats and door cards look the business, I am thinking of doing the same thing on mine, as I have a set in this colour, but the driver seat trim has a sizeable frayed hole in it...
Trimming these seats should be relatively easy, as the design is not particularly complex ;) I will put in the aftermarket seats in and have a go at it myself  ;)
Crusader
« Reply #68 on: May 14, 2016, 10:18:31 PM »
BHBASS - Thank you mate, I'm really pleased with the interior. Hope you like the next update.
So time for an update on the little BIS. The dust sheets were removed and he was wheeled out from the corner to do some work on him.
First up, I fitted my newly trimmed door cards to the passenger door. You may remember I had the interior retrimmed. I really liked the original material but it was clearly cheap and not made to last. I hope my choice will stand the test of time. Door card fitted.
Also here is a little comparison next to the seat to show you the match.
Next up it was time to get the welder out. You may remember I had the matching rot in both sides of the outer sill. It's obviously a common place for these to go as both sides had already been badly plated.
So I made a couple of plates up from some sheet to fill both sides.
I then shaped it in to position to make sure it fitted well with a joggled top edge.
My welds aren't brilliant as I'm a complete amateur, so I've taken a pic after it was welded and ground flat!
I then got the filler out!
I then flatted down the filler, it was always going to go back to textured stone chip so I didn't go too detailed on the sanding. Just got it smooth and levelled out.
Next up I applied the white stone chip to the panels, to achieve the textured rough effect like the rest of the sill I dabbed it gently with a sponge to achieve the similar desired result. I was quite happy with it in the end.
It does need another dust over with the stone chip once it's dried just to get rid of the dark parts. It takes a few hours to dry so he was pushed back in to the corner to dry.
As usual though. Thanks for looking and all comments welcomed and appreciated.
« Last Edit: May 14, 2016, 11:57:20 PM by Crusader »
Piotross
« Reply #69 on: May 14, 2016, 11:36:09 PM »
nice work, looks really good :)
Frigorius
« Reply #70 on: May 16, 2016, 01:10:37 PM »
This is a grat job you are doing. I feel a little jealous :p
Having a BIS myself, I'd like to ask you if you can take the measurements of your parcel shelf. I'm planning to make one myself, mine got lost before I got the car. It is not so easy to measure an empty space (I know I will probably do it wrong a few times, if I do it myself  :P )
Xylaquin
« Reply #71 on: May 17, 2016, 01:02:09 PM »
Those seats look really nice and plush!
What do you use to close the doors when you're in the car?
shielsy
« Reply #72 on: May 17, 2016, 07:01:16 PM »
pump that repair full of paint and wax now or it will return good job
Crusader
« Reply #73 on: May 27, 2016, 08:12:31 PM »
Piotross - Thank you my friend!
Frigorious - Thanks buddy. Yes I'll do my best to measure the shelf for you. Once I've done it I'll send you a DM.
Xylaquin - Thanks, I'm really pleased with the interior. You raised a really good point and for a second you had me very worried I'd missed something. However in answer to your question, I don't know what you use, they appear to have left them off from the factory! I think I'll use the door pocket. What does everyone else with a BIS use?
shielsy - You can count on that buddy!
Time for an update again on the BIS. I finished off the repairs on both the sills. I'm quite happy with the end result, to try and achieve the OEM underseal look I let the stonechip dry till tacky, then dabbed it with a sponge.
Now cast your memory back to the early part of this thread, to a job I've been putting off for some reason. The chips in the top of the door. To begin I rubbed the area down.
After a good coating of filler primer, I then applied several thin coats of Fiat Blanco Corfu to build up the colour.
Once cured and happy with the end result I gave a few coats of lacquer and removed the masking tape. I also fitted the drivers side door card and furniture.
Really happy with how it turned out in the end, not much left to do on the little BIS.
Thanks for looking.
Xylaquin
« Reply #74 on: May 28, 2016, 11:03:09 PM »
Mine has these:
