Author Topic: Water Pump seal  (Read 2856 times)
cider
Water Pump seal
« on: February 24, 2015, 09:15:09 PM »
Hi All
After many hours searching for a water pump seal "form the dealer and parts suppliers" heres what I`ve fitted
First you`ll need a new oil seal it`s a standard size so easily available from any bearing/seal supplier
30x16x7 mine cost £0.97each
As for the water pump seal the nearest size and the one that i`ve fitted was a water pump seal for a
massey ferguson model MF135 same as MF 35, the best place to get them is either ebay or a classic tractor
parts supplier mine was £7.50 delivered
Tis a Proper job ;)
Hope this helps someone out
Alexander_Rychok
Water Pump seal
« Reply #1 on: March 19, 2015, 09:27:17 AM »
Hello , I am looking for a water pump seal with the bearings. Can some one help me out or link me . Morini franco usa dont have them
cider
cider
Re: Water Pump seal
« Reply #3 on: April 12, 2015, 09:11:19 PM »
Well after swopping out engines today, due to fiat pump seal failure taking out the head gasket:( ???
I`ve now had chance to try out the engine with the MF seal fitted and its looking proper ;)
no leaks even when up to temperature :D
Re: Water Pump seal
« Reply #4 on: April 12, 2015, 09:27:54 PM »
Well done Cider :good: Thanks for the info
cider
Re: Water Pump seal
« Reply #5 on: May 25, 2015, 09:30:48 PM »
Here`s a few pictures of the seal and fitted
dadandlad
Re: Water Pump seal
« Reply #6 on: May 25, 2015, 10:01:27 PM »
Quote
Well done Cider good Thanks for the info
I will second that ,used the same seal in my engine rebuild but not run it yet
dadandlad
Re: Water Pump seal
« Reply #7 on: August 25, 2015, 09:21:23 PM »
Engine started up for first time yesterday and pump seal dry as a bone  :)
Brilliant thanks
Re: Water Pump seal
« Reply #8 on: August 25, 2015, 09:52:53 PM »
Great News, Its got to be good its for a Tractor :P
