Author Topic: Fiat 126 polski  (Read 35162 times)
Craig126
Re: Fiat 126 polski
« Reply #60 on: July 17, 2015, 10:06:46 PM »
Looking good mate, what rear calipers are they, uno turbo?
sunriser81
Re: Fiat 126 polski
« Reply #61 on: December 08, 2015, 08:12:27 PM »
rear calipers from new fiat 500 abarth, just managed to find some more time before xmas and finally fitted them.
sunriser81
Re: Fiat 126 polski
« Reply #62 on: December 08, 2015, 08:17:46 PM »
« Last Edit: December 19, 2016, 09:24:10 AM by sunriser81 »
sunriser81
Re: Fiat 126 polski
« Reply #63 on: December 08, 2015, 08:22:15 PM »
some more photos.
made rear spacers total with plates 31mm wider, so later rear arches will be wider.
master cylinder with bigger piston 20,6mm looks very simmilar to master cylinder from 126
« Last Edit: December 19, 2016, 09:24:31 AM by sunriser81 »
Re: Fiat 126 polski
« Reply #64 on: December 09, 2015, 12:34:49 AM »
Hi, great work looks fantastic do you know what the master cylinder is off.
Bambino126
Re: Fiat 126 polski
« Reply #65 on: December 09, 2015, 01:26:59 AM »
Excellent work!
What size tyres are you running?
sunriser81
Re: Fiat 126 polski
« Reply #66 on: December 09, 2015, 08:17:16 AM »
Tyres are 165/55 r 13
and master cylinder from Uno fits very good to the car,
the one problem my old bolts holding master cylinder both snapped, so unfortunately drilling time to replace bolts, ohhhh....
« Last Edit: December 15, 2015, 08:40:59 PM by sunriser81 »
Re: Fiat 126 polski
« Reply #67 on: December 09, 2015, 09:22:24 AM »
That looks fantastic mate :thumbup great tip about the undo master cylinder, will that make it a less spongy feel at the pedal because it's bigger?
Re: Fiat 126 polski
« Reply #68 on: December 09, 2015, 09:43:25 AM »
 Looking great. I like all that gold too, very bling 8)
 One question, how come you are using bis swing arms and what are the shock absorbers from? Seems to be a pain to get decent shocks for the bis.
sunriser81
Re: Fiat 126 polski
« Reply #69 on: December 09, 2015, 07:37:07 PM »
new bolts fitted, master cylinder fitted. 2 lines are connected and have to replace rear line tommorow. The tread is fine 1.25 so fiat brake line end no good anymore.
« Last Edit: December 15, 2015, 07:01:06 PM by sunriser81 »
sunriser81
Re: Fiat 126 polski
« Reply #70 on: December 09, 2015, 07:40:51 PM »
Gadge I have been used standart cylinder with front disc for around 8mths working fine but feel that could be better, so bigger piston will do job as my other friend use it and brakes really good. will give feedback soon hope this will be worth hours and hours spent with this brakes.
Rear arms are from BIS and found them with blistein shock in my other fiat 126 with 903cc engine, fiat was all rotten but arms after resto looks better :)
« Last Edit: December 09, 2015, 07:44:07 PM by sunriser81 »
sunriser81
Re: Fiat 126 polski
« Reply #71 on: December 10, 2015, 09:41:57 PM »
Good News.
My barkes working very well now i am so happy with, pedal much better than before with standart cylinder.
next step to fit new engine in.
I can go for holiday now
jacw
Re: Fiat 126 polski
« Reply #72 on: December 11, 2015, 05:22:43 PM »
Great work and many thanks for the info on the Uno master cylinder.
I have had a spongy long travel pedal since fitting discs up front with locking up wheels if pushed hard in an emergency! Not a nice feeling.
Do you have a part number for the Uno master cylinder (as there so many to choose from)?
Thanks again, John
sunriser81
Re: Fiat 126 polski
« Reply #73 on: December 12, 2015, 09:58:07 AM »
Hi just emailed you part number.
Cheers Lucas
jacw
Re: Fiat 126 polski
« Reply #74 on: December 12, 2015, 02:07:57 PM »
Could you please resend email as it seems to have been lost in space. Thanks, John
