Author Topic: Fiat 126 polski  (Read 35203 times)
sunriser81
Re: Fiat 126 polski
« Reply #30 on: February 15, 2015, 12:53:52 PM »
Had chance to get freshed up with alloys, just polished them and sprayed. Next plans to sort steering. It Will be welding time, going to remove steering box and replace with steering rack conversion, fit front discs & calipers. Also Find that rear left shock absorber housing needs welding, bit of rust on front & rear windscreen, offside wing needs respray. this is to do list.
« Last Edit: May 09, 2015, 10:49:16 PM by sunriser81 »
sunriser81
Re: Fiat 126 polski
« Reply #31 on: May 09, 2015, 10:38:08 PM »
HFit steering rack, after test drive confirm this was best step for my 126.
Handling & steering great was worth long 2 days of my work. (1 day to make bracket and 1 day fitting)
some photos uploading.
first remove all steering system.
cut bit of metal.
« Last Edit: December 19, 2016, 09:20:42 AM by sunriser81 »
sunriser81
Re: Fiat 126 polski
« Reply #32 on: May 09, 2015, 10:39:29 PM »
another side the same grinding.
sunriser81
Re: Fiat 126 polski
« Reply #33 on: May 09, 2015, 10:40:25 PM »
conversion bracket.
« Last Edit: May 09, 2015, 11:30:21 PM by sunriser81 »
sunriser81
Re: Fiat 126 polski
« Reply #34 on: May 09, 2015, 10:42:00 PM »
sunriser81
Re: Fiat 126 polski
« Reply #35 on: May 09, 2015, 10:43:11 PM »
fit the barcket
sunriser81
Re: Fiat 126 polski
« Reply #36 on: May 09, 2015, 10:44:19 PM »
hard bit
to drill the hole.
sunriser81
Re: Fiat 126 polski
« Reply #37 on: May 09, 2015, 10:45:28 PM »
sunriser81
Re: Fiat 126 polski
« Reply #38 on: May 09, 2015, 10:47:15 PM »
sunriser81
Re: Fiat 126 polski
« Reply #39 on: May 09, 2015, 10:48:03 PM »
sunriser81
Re: Fiat 126 polski
« Reply #40 on: May 09, 2015, 10:48:37 PM »
extended UJ
sunriser81
Re: Fiat 126 polski
« Reply #41 on: May 09, 2015, 11:03:08 PM »
next step
rear wishbone, sport shocks, shorter springs
« Last Edit: December 19, 2016, 09:21:58 AM by sunriser81 »
sunriser81
Re: Fiat 126 polski
« Reply #42 on: May 10, 2015, 12:01:11 PM »
sunriser81
Re: Fiat 126 polski
« Reply #43 on: May 10, 2015, 12:02:46 PM »
Starting to prepare old type door for full EL glass type and wing mirrors fitted to the frame with adjusters inside car. Also better type EL regulator.
sunriser81
Re: Fiat 126 polski
« Reply #44 on: May 12, 2015, 09:19:06 AM »
Rolling arches job done.
