Author Topic: Fiat 126 polski  (Read 35160 times)
sunriser81
Re: Fiat 126 polski
« Reply #45 on: June 02, 2015, 11:17:25 PM »
ok more weldings inside and out to keep the car all together.
sunriser81
Re: Fiat 126 polski
« Reply #46 on: June 02, 2015, 11:19:50 PM »
front brakes.
sunriser81
Re: Fiat 126 polski
« Reply #47 on: June 02, 2015, 11:21:08 PM »
Craig126
Re: Fiat 126 polski
« Reply #48 on: June 06, 2015, 05:05:43 PM »
Cars looking good, I already have the brake conversion brackets for mine but i'm unsure which calipers and discs to use.
Am I right in thinking I need 240mm solid discs and standard pads from either a cinquecento, seicento or mk1 punto, along with the calipers and caliper brackets?
sunriser81
Re: Fiat 126 polski
« Reply #49 on: June 11, 2015, 07:08:53 PM »
Hi Craig126 Is your plates exactly the same as mine?
sunriser81
Re: Fiat 126 polski
« Reply #50 on: June 11, 2015, 07:16:25 PM »
Some more work done.
Battery tray, radiator fits good, welded plate to support steering.
sunriser81
Re: Fiat 126 polski
« Reply #51 on: June 11, 2015, 07:17:16 PM »
« Last Edit: December 19, 2016, 09:23:24 AM by sunriser81 »
sunriser81
Re: Fiat 126 polski
« Reply #52 on: June 13, 2015, 11:05:32 PM »
Front end epoxy primed
sunriser81
Re: Fiat 126 polski
« Reply #53 on: June 14, 2015, 10:39:45 PM »
some more photos after primer sanding.
Re: Fiat 126 polski
« Reply #54 on: June 15, 2015, 07:54:22 AM »
Great work! :thumbup: really looking forward to seeing this done  :D
sunriser81
Re: Fiat 126 polski
« Reply #55 on: June 15, 2015, 09:16:54 PM »
Gadge thank you.
Front end finished today, have to put everything together and do MOT this week, so car will back on road to test suspension, steering and brakes. Have to set up tracking, angle and will move to rear of the car to do some welding, fit BIS rear arms, sport short shocks and engine.
some photos from today.
mintex
Re: Fiat 126 polski
« Reply #56 on: June 15, 2015, 09:22:56 PM »
its looking might fine  :D
Dave
sunriser81
Re: Fiat 126 polski
« Reply #57 on: June 16, 2015, 03:55:02 PM »
sunriser81
Re: Fiat 126 polski
« Reply #58 on: June 23, 2015, 12:54:40 PM »
Fiat get back on road to some suspension & brakes test.
now going to fit rear calipers and rear suspension.
BIS gearbox should be ready end of week, but if someone have any source to skoda rapid gearbox plese help.
nathanfiddes
Re: Fiat 126 polski
« Reply #59 on: June 23, 2015, 01:00:53 PM »
Wow! Love this car!
