Author Topic: LHD headlamps  (Read 2912 times)
nathanfiddes
LHD headlamps
« on: September 04, 2014, 09:51:26 PM »
I have done a few searches and couldn't find my answer. I need to get my LHD lamps to pass an MOT.
Can the lenses be adapted to do this?
I'm guessing RHD ones are hard to find!
Nath
Re: LHD headlamps
« Reply #1 on: September 04, 2014, 10:04:12 PM »
You can stick beam deflectors (Black Tape) over the triangle part that causes the Right hand Uplift Or Bar Vitelli on the forum has some new ones.
ronb1967
Re: LHD headlamps
« Reply #2 on: September 04, 2014, 10:14:03 PM »
Hi this is what i have fitted to me LHD 126 and passes MOT no problem ,
for european cars driving in the UK
Ebay seller CLICK-PARTS  item number=  121361493921
  HEADLAMP BEAM DEFLECTOR HEADLIGHT CONVERTORS ADAPTOR DRIVING IN THE UK EUROLITES
124cso
Re: LHD headlamps
« Reply #3 on: September 05, 2014, 03:57:55 AM »
If your reflectors are good, go looking for used RHD lights at a wrecker's. Any old crap will do as long as the lenses are intact.
Now you have to do what the 500D owners do. Carefully cut thru the glue joint between the glass and the reflectors and swap the old RHD glasses onto your good reflectors or buy new ones- New LHD lamps are so cheap !
You just have to get the correct glue and be careful to align things and wear rubber gloves so you do not leave corrosive sweaty prints on the reflectors.
You can cut the old glue joint with a dremel or dimond disk and beware of the dust !
Fiat 127 used the same lights as I have read, did some versions of the 128 (in limited countries)
nathanfiddes
Re: LHD headlamps
« Reply #4 on: September 05, 2014, 08:57:07 AM »
Thanks for the replies folks. Very helpful. Ronb1967 do you have a photo of those defectors fitted? My reflectors are perfect so I will look for some RHD lamps.
ronb1967
Re: LHD headlamps
« Reply #5 on: September 06, 2014, 02:49:30 PM »
Hope this helps
nathanfiddes
Re: LHD headlamps
« Reply #6 on: September 08, 2014, 11:05:55 AM »
Perfect! Thanks!
Scarlettkitten
Re: LHD headlamps
« Reply #7 on: September 08, 2014, 02:55:24 PM »
My mot tester stuck some black tape on for me when he did the alignment, didn't charge me either :)
1990 126 BIS
nathanfiddes
Re: LHD headlamps
« Reply #8 on: September 09, 2014, 03:53:49 PM »
Great news! I found set of deflectors on the back seat
