Author Topic: Polski Fiat 126p for race COMPRESSORE INIEZIONE  (Read 15713 times)
Pony007fromPL
« on: December 15, 2013, 12:00:51 PM »
The topic I will be documenting the work:)
I'll start with the engine
The idea evolved from early concepts. The reconstruction changed a lot of times - for example: adaptation of the head with 8 valves DOHC:
(once for sure I come back to this), the use of the head of the Fiat CC700 to 126p standard engine air-cooled, power supply with two carburetors and many other better or worse ideas. Certainly due to the fact that there were so many ideas , lessons and tests parts put together this together, I have gained a lot of experience .
In brief:
- 2x 34mm Mikuni carburetor (in this engine unnecessary)
http://www.odrdzewiacz.fora.pl/sport-z-epoki,8/traby-do-gaznikow,139.html
- Adaptation of the head of CC700 ( head fr use - but with water-cooled cylinders )
http://www.odrdzewiacz.fora.pl/sport-z-epoki,8/glowica-cc700-do-fiata-126p,147.html
-Oil catch tank  ( useful )
http://www.odrdzewiacz.fora.pl/sport-z-epoki,8/zbiornik-odmy-mojego-pomyslu,141.html
- Full flow oil filter + cooling ( useful )
http://www.odrdzewiacz.fora.pl/sport-z-epoki,8/przystawka-pelnoprzeplywowego-filtra-oleju-126p,149.html
- Lightened flywheel ( useful )
At the moment is 4.4 kg , is likely to be less
http://www.odrdzewiacz.fora.pl/sport-z-epoki,8/odchudzanie-kola-zamachowego,145.html
- Water pump DIY ( most likely replace it with an electric pump )
http://www.odrdzewiacz.fora.pl/sport-z-epoki,8/pompa-wody-diy-126p,151.html
So, it was shown how it was done. Later, quite by accident , I discovered that the engine block from the CC700 quite nicely fits into the gearbox ordinary Fiat 126p - when this block is VERTICAL .
This engine reminds me of something ...
 I'm really liked it , because it looks very nice and retains the character of 126p - engine is the same engine (I mean BIS ) at 126p , only " drenched " another block - so for me it 's not even a swap, but something interesting :) . From what I know , I am the first , which realizes this idea. Well, but the thing - I wanted to use the engine block of CC700 due to hydraulic valves, but I gave up the idea because this solution is not very suitable for sports applications , in addition, requires a number of improvements ( factory defect of these engines is just too soft " glasses " ).
BUT the BIS engine is haven't got hydraulic valves:). I was able to buy a brand new engine block. Head is from CC700 (bigger valves than BIS), and everything I put on a standard oil pan 126p without air duct.
 Here 's probably a lot of people ask , but what about the water pump and oil (in BIS / CC they are located in the oil pan) . With certain adaptations , the timing of the cover fits into a standard Fiata126p BIS block , and thus fits the oil pump.
Valve cover is BIS- fit plug & play , of course, to the head of the CC , but in contrast to the CC is steel, so it can be welded to the elements of an ordinary 126p :) because the engine will stand upright.
After sand blasting + already drilled base of the filter.
I started porting the head
The next thing - what I wore on the head it was " something of interest " to the engine. I do not like engines forced induction, but I considered the use of a turbocharger. But still, non- turbo is a little hard to tame, is much different phenomena and difficult issues , in addition there is something quite hard to choose. Did a little research and bought a supercharger,  Eaton 24
Honestly, I chose size on the principle of an eye , and now I know that it will fit me perfectly! Even ( not tested by me) the direction of rotation is correct :) . Well I'm glad! supercharger has always been my dream.  I must design and make the whole intake, compressor and alternator mount - a lot of work .
It's nice that I have a tensioner!
I have prepared a model here:
And here we come to the point where I decided on the construction of the injection - ignition ( with the help of my brother, electronics) with the ability to control boost pressure .
I decided to apply the injection of a number of reasons - the most important is to gain experience and knowledge to a greater extent than would result from the traditional system. Another reason is the potential and accuracy of solution - injection, in particular, the MPI can very accurately control the motor and most importantly, to regulate its performance at a specified time (eg data speeds ).The engine very easy to destroy , and I want to have control over it and to learn, gradually improving its performance. Injection , in the initial phase of work and adaptation is complicated , but for example, later to change the settings I don't have to move ( mechanically ) in the system , and also I know a lot more. You can prepare different maps for different purposes , change them accurately and quickly. I want to get close to the limit of my knowledge and continue to learn .
My first attempt with the composite intake manifold - today I have an another idea ( technology )
This is a first model of the interior of the "positive" manifold - is wax.
View the lamination :
(it was a prototype , is now working on another )
That brings us to the current moment!
Sheet:
I'm working on a new intake manifold :
I also have an electrically operated relief valve ( by- pass) to the compressor ! New technology!
I finished the model of the manifold:
Now it looks:
Greetings!
« Last Edit: December 15, 2013, 08:54:27 PM by Pony007fromPL »
Wagoneer
Re: Polski Fiat 126p for race COMPRESSORE INIEZIONE
« Reply #1 on: December 15, 2013, 06:40:42 PM »
Wow Pony, that's an amazing build so far, I'm looking forward to more.
« Reply #2 on: December 15, 2013, 06:52:09 PM »
Fantastic Build so far :thumbup Thanks for sharing keep us updated on your progress :)
r20vt
« Reply #3 on: December 15, 2013, 07:13:42 PM »
bravo dear friend for your progress
you love to doing this!!
 :D :D
Pony007fromPL
« Reply #4 on: December 15, 2013, 08:57:35 PM »
Thanks 4all!
I corrected the links in the first post! Check this :D
That's what I write is understandable for you ?
DEYAN IYI
« Reply #5 on: December 15, 2013, 11:51:58 PM »
 :o :good: "Like"
Waiting for the song of the engine!!! 8)
What about the cam shaft, will it be modified?
Thanks for the fun!
Pony007fromPL
« Reply #6 on: December 16, 2013, 02:32:13 PM »
I don't know what cam shaft yet :$ Something little faster then production:)
DEYAN IYI
« Reply #7 on: December 16, 2013, 04:34:07 PM »
About perfect for supercharging is the 650E one. You don't need something like 290 or 300*
Check this out!  :) http://victorylibrary.com/supercharger/super-engine5.htm
My second project is also with a blower, but for now I got only Aisin AMR 300 and Dellorto DHLA 40, so I need another 126 ;D
Kind regards! I'm very happy to follow both supercharger projects on the forum!
Pony007fromPL
« Reply #8 on: December 18, 2013, 08:06:09 PM »
Last parts to injection:
(boost pressure sensor, air valve)
Oil pan modify:
(before)
Great place for oil dipstick!
Pony007fromPL
« Reply #9 on: December 22, 2013, 11:23:58 AM »
Supercharger (airbox) & alternator mounting
Oil pan:
pietschokkenbroek
« Reply #10 on: December 22, 2013, 03:10:42 PM »
WOW!!  :o really impressive  :thumbup please keep us posted!!
Pony007fromPL
« Reply #11 on: January 02, 2014, 05:22:48 PM »
« Last Edit: January 02, 2014, 05:26:28 PM by Pony007fromPL »
« Reply #12 on: January 03, 2014, 07:31:44 PM »
That's Sweet Man :thumbup Well Done :good:
grubscrew
« Reply #13 on: January 18, 2014, 07:42:50 PM »
 Nice work, very very nice. Mike.
All things Italian.
Pony007fromPL
« Reply #14 on: February 05, 2014, 06:17:34 PM »
My engine gallery (like it! :) ):
https://www.facebook.com/media/set/?set=a.538729222889066.1073741831.453274184767904&type=1
Sorry for photos quality!
Con rods from Fiat 1050ccm! It's fits almost perfect (they are 2mm longer then 126p)
Comparison:
In this month I don't have a lot of time for engine:(
BUT! See idea for mounts exhaust MIVV
[/url]
[/url]
MIVV - to repair:
[/url]
http://www.odrdzewiacz.fora.pl/blacha-karoseria-nadwozie,4/naprawa-tlumika-motocyklowego-kosmetyka,204.html
The inscription will be engraved
[/url]
[/url]
[/url]
