Does your fan relay click when your bridge white/black? If so, its worth checking the connections to the low speed resistor at the bottom of the fan housing. Its in an excellent position for getting blasted by road muck/salt etc. My connections were in a bit of a state. Otherwise, it could be the relay itself. I was it that position not long ago and finding corroded connections everywhere drove my decision to rewire the circuit. While I was at it, it seemed sensible to put the extra relay for the high speed earth so I can use an alternative fan switch with lower trip-in.......
Keith
