Author Topic: MOT Pass!  (Read 1632 times)
MOT Pass!
« on: October 25, 2012, 11:21:56 AM »
MOT pass today on the 126 ;D after a fail yesterday  :(
Went to my very strict but fair garage where they are into old cars. I thought I felt a bit of a brake pull when I drove the car on Sunday then again a hint of on the way to the MOT. On the brake test machine the near side was working at one sixth of the off side. Other fail item was the lack of a boot on the nearside ball joint. The boot thing was interesting as they have a steel collar on them so whilst they can rot they can not fall off completely so at some stage that boot had been just left off.
Said to the MOT man "you missed that one when you did the MOT last year"
answer "they only added it to the MOT test about 6 months ago!"
The brake cylinder had one seized piston and the other one piston leaked along with quite worn brake shoes. So sorted all that then had a hell of a job getting the brake fluid to run through for bleeding, I must have pumped that pedal over 100 times with the bleed nipple completely removed before any fluid came through. The brake drum was a bit grooved so I knew that the shoes would take a little bedding in. So back at the garage which is about a 12 mile run & the brake pulled up straight. On the brake tester the near side was still well down but the guy knew the situation and being a good old boy he used the power of the rollers to keep the nearside wheel turning while he kept the brakes on, release, then on again. After about 3 minutes the result was that the braking power came up to almost the same as the offside. Still a little bedding in to go but MOT pass  ;D
Seabee1978126
Re: MOT Pass!
« Reply #1 on: October 25, 2012, 12:01:57 PM »
Congrats man! What is a MOT inspection exactly? Is it like a annual safety inspection for all vehicles that are driven on the road or some other inspection? Sorry for my inexperience with this... Ive only been in Europe for a year and a half.
Lina
    • Facebook profile
Re: MOT Pass!
« Reply #2 on: October 25, 2012, 01:49:25 PM »
Congrats!  ;D
Hoping to join you over on the sunny 'pass' side soon!
Lina - as in Lyna - as in dustbin liner, eye liner, ocean going... etc!
Re: MOT Pass!
« Reply #3 on: October 25, 2012, 04:36:01 PM »
Seebee the MOT test is an annual thing where you go to an approved station to have your car inspected for safety & roadworthyness. Always a nervey time as you never know what might be found as a fail and put you off the road or hit you deep in the wallet. A good centre like the one I use will do an honest test and report however painfull. However many centres use their position to generate work for the garage , often picking easy to fix work that they will charge you a fortune for. I had a local garage tried to charge me 2 hours labour for changing a ball joint , they assured me that they had reset the tracking which I had had done the day before when I had two new front tyres fitted. 8 months later the new tyres had worn down to the cords on the very inside corner. Main agents are some of the worse because of their high labour charges and if you have a number of items to be fixed they use "menu pricing" and charge each item as if it is a one off job so simple work that may take an apprentice 30 mins or so may land you with a bill for 3 hours labour +parts +vat. I know it happened to me at a Peugeot main agent and at the time they were charging £75 + vat per hour  :o
So my advice is do what you can yourself and get a written quote for any work you farm out  :)
Re: MOT Pass!
« Reply #4 on: October 25, 2012, 09:34:49 PM »
 :wave Nice one.
Seabee1978126
Re: MOT Pass!
« Reply #5 on: October 26, 2012, 09:51:43 AM »
Thank you for explaning that to me!  ;D
Re: MOT Pass!
« Reply #6 on: October 26, 2012, 10:47:24 AM »
Great well done!  My brakes were pulling to the side after a major rebuild but worked fine and a pass for the MOT must be the bedding in process!
Re: MOT Pass!
« Reply #7 on: October 26, 2012, 03:22:07 PM »
I followed the thread on your brakes. Forgot to mention that if the car pulls to the left then it is either near side front or off side rear under performing then the opposite if it pulls the other way. Easy test is to lock the wheels on a gravel road and check the tracks  :)
Re: MOT Pass!
« Reply #8 on: October 26, 2012, 07:09:03 PM »
Cheers Rusty,  MOT man said I would need a new leaf spring soon so it could be that......
