Author Topic: Bis Starter Motor  (Read 1821 times)
f40fanatic
Bis Starter Motor
« on: October 03, 2012, 11:18:54 AM »
Im after a starter motor, preferablly re-conditioned :) Dave
Ricky126
Re: Bis Starter Motor
« Reply #1 on: October 13, 2012, 10:20:10 PM »
I've got a starter but it's not reconditioned works though
f40fanatic
« Reply #2 on: October 15, 2012, 06:38:57 PM »
I was ideally after a recon one, is it in very good condition?
Dave.
« Reply #3 on: October 15, 2012, 07:01:52 PM »
What's wrong with the starter motor?
If the starter motor just clicks when you turn the ignition key, 9 times out of ten its usually the solenoid that bolts on top of the starter motor I've not had problems with the starter motor its self but have had to replaced the solenoid on 3 occasions over the years.
f40fanatic
« Reply #4 on: October 16, 2012, 01:07:58 AM »
O right, well the battery is fully charged but it struggles to turn over the engine and the motor makes a graunching noise, it eventually starts but only when the engine is cold. When the engine is hot it rurns over so slowly it wont start the engine. On a couple of occasions the motor has only clicked and not worked, but after a thump with a hammer it frees up....
« Reply #5 on: October 16, 2012, 05:46:22 AM »
Have you checked the points gap and ignition timing? It sounds like a similar problem rusty was having http://club126uk.co.uk/smf/index.php?topic=7113.0  If that does not sort it an auto electrician should be able to test your starter motor.
f40fanatic
« Reply #6 on: October 26, 2012, 05:31:57 PM »
It is definatly the Starter, ive had problems with it before, anyone know whete i can get a new one for reasonable price?
« Reply #7 on: October 26, 2012, 06:03:45 PM »
