Author Topic: Solenoid valve blocked  (Read 2182 times)
mile
« on: July 21, 2012, 05:32:29 PM »
Solenoid valve is open when I turned on the fan. For me it is open and provides vacuum and when the fan is not working. So I blocked him.
comment?
Re: Solenoid valve blocked
« Reply #1 on: July 22, 2012, 12:00:44 AM »
Hi Mile
I don't know why you would want to block this pipe, If the tick-over is set to 850 RPM this solenoid is there to stop the engine from stalling on tick-over when the fan kicks in,
When the thermo switch in the radiator switches the fan on, the solenoid is energized and opens the vacuum from the manifold which pulls the diaphragm up on the carb, and in turn increases the throttle to compensate for the extra power needed to drive the fan. There is an adjustment screw on the top of the diaphragm housing, when the fan cuts in this should be adjusted so the engine RPM stays the same whether the fan is on or off.
It does not make any difference to the performance of the engine.
« Reply #2 on: July 22, 2012, 07:18:28 AM »
Interestingly, on my 126 Bis, the engine rpm rises slightly when the fan automatically switches on. Is it easy to adjust?
mile
« Reply #3 on: July 22, 2012, 07:55:48 AM »
The reason - faulty solenoid. Do not close the valve when the fan is off. Higher fuel consumption.
With solenoid blocked -great, better fuel economy.
« Last Edit: July 22, 2012, 07:57:24 AM by mile »
mile
« Reply #4 on: July 22, 2012, 08:05:28 AM »
yes
quick adjust when the fan is turned on
twisting the screw reduces rpm
Adjust -only correct solenoid
If you are unsure-block
« Last Edit: July 22, 2012, 08:10:15 AM by mile »
« Reply #5 on: July 22, 2012, 08:57:23 AM »
Sorry. Will turning the screw clockwise reduce the rpm?
mile
« Reply #6 on: July 22, 2012, 09:16:11 AM »
yes.
« Reply #7 on: July 22, 2012, 11:10:07 AM »
If you wanted to replace the valve, But have difficulty in finding a replacement you could adapt a 12v Vacuum Solenoid Valve from another Vehicle, They are usually found in the Vacuum line to open and close the EGR valve :D
