Author Topic: Bis leaking rocker cover  (Read 3349 times)
« on: March 22, 2012, 07:39:15 PM »
The rocker cover is leaking oil all over my exhaust, it seems to be coming from the nuts that hold it on what is the best way to seal these?
Re: Bis leaking rocker cover
« Reply #1 on: March 22, 2012, 07:46:44 PM »
Mine was doing that, turned out to be the inlet manifold gasket.
« Reply #2 on: March 22, 2012, 07:52:17 PM »
What do you mean 'inlet manifold gasket'?
« Reply #3 on: March 22, 2012, 08:06:19 PM »
Where the inlet manifold (bit between the bottom of the carb and the block) attaches to the top (right) of the engine, there is a water channel through that. If you take the carb off, it is held on with three (I think) bolts. I had a bit of trouble finding the right replacement gasket, luckily it came off in one piece, so I cleaned up all faces of gasket, block and manifold and very carefully applied red hermetite, seems to be working ok ish.
« Reply #4 on: March 22, 2012, 08:10:17 PM »
Until I took the carb off I thought the water was coming off of the bolts on the rocker as well, I was quite confused by it  :$
« Reply #5 on: March 22, 2012, 08:12:02 PM »
Cheers, I know the bit you mean and I have a gasket!
« Reply #6 on: March 22, 2012, 08:17:24 PM »
You jammy person!! Good luck with it, you will need a slim 13mm socket on a short extension, if memory serves right, for the internal manifold bolt ( you will know when you see it). I also found that the two carb bolts and washers toward the drivers side need to be removed and replaced with the carb slightly lifted.
Marc
« Reply #7 on: March 22, 2012, 08:21:40 PM »
I would also suggest replacing the water pipe that goes to the inlet manifold, and the heat exchange type thing from the exhaust to the drivers side side vent when you are there. I found the water pipe was well done, due to the heat from the exhaust I suppose
« Reply #8 on: March 22, 2012, 08:22:02 PM »
If it is not the intake manifold I think I may need these as I don't have them.....
http://www.ricambio.co.uk/1330-rocker-cover-fibre-washer--classic-fiat-500-126
« Reply #9 on: March 22, 2012, 08:24:31 PM »
I can't see (please shout me down if I am wrong) how water would be seeping from the rocker cover without some serious problems. I think if that was the case both your oil and water would resemble very cheap and overcooked scotch broth.
« Last Edit: March 22, 2012, 08:26:32 PM by Hazey-n-Marc »
« Reply #10 on: March 22, 2012, 08:26:30 PM »
Only oil is leaking from my rocker
« Reply #11 on: March 22, 2012, 08:27:47 PM »
poo! sorry :$ I misread the first post as water :$.  :$
« Reply #12 on: March 22, 2012, 08:28:57 PM »
What a cupid stunt I am!! (slight anti censorship protest :D )
You should probably ignore most of that :$
« Last Edit: March 22, 2012, 08:33:16 PM by Hazey-n-Marc »
« Reply #13 on: March 22, 2012, 08:37:33 PM »
So don't touch the inlet gasket then.........I did think this was a little odd, thanks for your help though!
« Reply #14 on: March 22, 2012, 08:39:32 PM »
Don't thank me for wasting your time, take the piss instead ( I probably would  :D )
