Author Topic: Speeds in gears?  (Read 1482 times)
fightingtorque
Speeds in gears?
« on: January 11, 2012, 12:47:54 AM »
Hello,
Been enjoying 126ing the last few days, generally it is running reasonably well although the main thing is to get on with the mark 2 fuel injection setup.
One thing, it doesn't seem so tractable at low engine speeds as i had remembered, maybe this is something that I lost a bit when I raised the compression ratio.  I remember when I first got the car I was really surprised at how torquey the engine was consider its small size.
It isn't so much that I now feel a lack of torque, I think it is better than before, but the minimum speed at which it will pull comfortably seems quite high.  I know the gearing is quite long considering its a small engine and only 4 speeds, but it doesn't really pull smoothly below about 35mph in 4th gear for example.  Is this also true of the standard car?  (BIS).
I have 145/70 tyres on, so that does mean it is a little geared up over standard.
I am still using the original distributor ignition at the moment.  With the mark 2 fuel injection I will get fully mappable ignition across speed/load table.
Gav
Re: Speeds in gears?
« Reply #1 on: January 11, 2012, 12:13:38 PM »
The old speedometers had red dots next to the speeds where it was ideal to change gears (or near red line, don't know). 2nd at 30km/h, 3rd at 50km/h and 4th at 80km/h.  I found that it cruised comfortably in 4th at 50km/h (though not much acceleration if you floored it but it did pull nicely).
I actually found the gearing to be short, I think the diff. ratio is around 4.0 or 4.1:1 and my service manual showed the ratio of each gear to be low (even 4th is around 1.1 or 1.2:1), a longer 4th gear or a 5th gear (maybe even a different diff. ratio) could have given a slightly higher top speed and would have made cruising at or a bit above 100km/h more comfortable for long distances in my opinion.
DEYAN IYI
« Reply #2 on: January 11, 2012, 03:53:33 PM »
With standard 135/70 R13 the Bis on highest torque on 2000rpm goes with 52km/h or 32mph. So must be really happy on that speed.
I don't know for the Bis, but according to the instructions for the aircooled one the lowest cruising speed is about 2000rpm on each gear or 12-19-30-45km/h. On 3000rpm (highest torque) is 18-31-41-66km/h. And max speed 30-50-80km/h that is about 5300-5600rpm when shifting. Not recommended to run for long time over 5000rpm. Max speed on IV is 105km/h on 4800rpm.
126's IV gear is real V gear being overdrive of 0.871; with the Bis's final drive 9/39 (8/39 for the aircooled) is just perfect, but needs on the place of III (1.3) one shorter and one longer like in the Abarth options III - 1,421; IV - 1,091) :) The good thing is that is something easy to buy, except the price. 8)
PS - lower than 2000rpm isn't good for the cooling of the AC.
DEYAN IYI
« Reply #3 on: January 11, 2012, 06:48:49 PM »
So, you can shift gears on 5000rpm. Top speed 116km/h at 4500rpm where the max power is.
« Last Edit: January 11, 2012, 06:56:13 PM by DEYAN IYI »
fightingtorque
« Reply #4 on: January 11, 2012, 11:35:36 PM »
Good info.
So if 2000rpm in BIS is 32 mph, I guess it probably isn't too surprising that the minimum speed i find it happy at is about 32-35mph.
I think I have been spoiled by these modern engines which can run down to low revs (more cylinders, multipoint injection etc) - my Cinq will happily totter along at 1500rpm in 5th and I have an alfa 156 V6 which will take 6th gear at 30mph with about 1200rpm.
But with only 2 cylinders, single point injection and currently only conventional distributor ignition, you cant expect the same thing.
I had to go on a speed awareness course recently, the guy was telling people his simple rule of 2nd gear for 20mph limits, 3rd for 30.  He believed too high a gear will hurt the fuel consumption.  We started to get into a debate about cylinder pressure, engine friction, fuel injection, variable cam timing etc. but i dedided we would be there all night and let him get on with it.....................
