Author Topic: Lowering/Wide wheels  (Read 1825 times)
f40fanatic
« on: September 11, 2011, 08:48:01 PM »
I was just wondering how these guys went about lowering there cars and fitting wider wheels without them rubbing, https://picasaweb.google.com/116592171807503851211/Ratstajlooo#
as i have trouble finding any wheels that fit the bis anyway,
is it just that the Bis model is hard to customise??
Dave.
Re: Lowering/Wide wheels
« Reply #1 on: September 12, 2011, 08:16:13 AM »
the bis can be lowered quite easily-  by buying a complete lowering kit with rear springs shocks and a reverese eye front spring-
these guys are prob-LEE running a more modified set up to get them this low.
When I lowered mine I had to put a reverese eyed front spring (1 leaf removed) in with air cooled rear shocks on the front (they are shorter than standard and stiffer) then had to do a camber mod to get the tyres under the arches. I also rolled the front arches in and had to "modify" the insides of the wheel wells slightly with a hammer where it rubbed. I plan to lower it more my cutting down  the alloy isolater blocks above the leaf spring by about 10mm.
at the back I run cut down bis springs measuring about 15cm tall uncompressed with a set of spax adjustable again with rolled arches for clearance.
I have a set of cut down polybush bumpstops front and back.
I have 13" x 5.5 wide wheels running 175/60/13 tyres and Im pretty sure you cant get much wider under a standard bis arch when this low-
so in short yes you can lower a bis- how easy it it depends on how low you want to go but I'm pretty happy with this.
its worth remebering that 13" fiat/lanci and alfa wheels with a 4x98 stud pattern shoud fit.
« Last Edit: September 12, 2011, 08:31:26 AM by stuey »
« Reply #2 on: September 12, 2011, 08:00:05 PM »
That looks awesome  :thumbup
