Author Topic: Towing a 126 with a A-frame device  (Read 3056 times)
tayto.king
« on: August 20, 2011, 09:29:43 AM »
Has anyone towed a 126 using an A-frame towing device that normally goes on the front wishbones of a car, was there any clearence issues as i'll be using my transit to tow it.
« Last Edit: August 20, 2011, 12:07:23 PM by tayto.king »
Re: Towing a 126 with a A-frame device
« Reply #1 on: August 20, 2011, 11:13:55 AM »
 I haven't but I do have such a frame if it of any use to anyone :-)
126blackbird
« Reply #2 on: August 20, 2011, 12:52:08 PM »
Could be interested in your A-frame, how much do you want for it?
« Reply #3 on: August 20, 2011, 01:09:39 PM »
I only have the frame that bolts onto the leaf springs and pokes out the front of the car, with 2 holes to connect to the other car (If that makes sense).
124cso
« Reply #4 on: August 20, 2011, 03:56:25 PM »
I would summize that you would need to have the key in the ignition to stop the steering lock actuating on sharp turns ???
RicePuddin
  • Guest
« Reply #5 on: August 20, 2011, 06:02:08 PM »
I'm just seen these for sale. How do you attach them to the car?
« Last Edit: August 20, 2011, 06:22:00 PM by RicePuddin »
« Reply #6 on: August 20, 2011, 08:52:26 PM »
Front wheels are off the ground.
Bolts onto suspension and connects to the tow bar of the tow car.
tayto.king
« Reply #7 on: August 21, 2011, 02:08:52 PM »
All wheels stay on the ground. A upright part of the towing device butts up to the front of the  wishbone either side of the car & then a chain attached to that bar goes around the wishbone & back to the ratchet strap which pulls it tight not allowing any movement. After this put your key in the ignition so that the steering lock isn't on & attach the a-frame to the towing vehicle. When you turn a corner the wheels of the car your towing will follow you & straighten up when you do. Kind of like pulling a shopping trolley from the front,the wheels will turn in the direction it's being pulled.
My problem with the 126 is there is a leaf spring & a clearance issue with the height of the car being towed by a transit van.
That's why i was asking has anyone used this device on a 126. I know it works on my 127 & 130tc but unsure of a 126.
« Reply #8 on: August 21, 2011, 08:37:12 PM »
 How big is your Transit? You can always put the 126 in the back of it, if it`s one of the bigger ones... :P
« Last Edit: August 23, 2011, 08:20:33 AM by 1973/126 »
tayto.king
« Reply #9 on: August 21, 2011, 09:22:19 PM »
it's a mk7 SWB semi hi roof. I was thinking of that but there is no safe way to tie it down,and if the Police pull me and find out i have a car in the back of my van they wouldn't be too happy :D
« Reply #10 on: August 21, 2011, 09:30:08 PM »
I assure you plenty have done it. 'Beryl' my 126 was transported in a Fiat Ducato  ;D
tayto.king
« Reply #11 on: August 22, 2011, 08:47:08 AM »
It would be a lot easier if i could put it in the back of my van,do you know the lenght, width  & weight of a 126.
124cso
« Reply #12 on: August 23, 2011, 02:32:34 AM »
600Kg without fuel,
3054mm or 3100mm long depending on what type of bumpers it has,
1377mm wide and
1335mm tall.
Remember, if you ar putting it in a van or on a trailer, you need to be able to open the doors to put the handbrake on. Or if you leave the window down (for same reason) be able to keep the rain out.
landyman
« Reply #13 on: August 24, 2011, 12:34:18 AM »
hi two years ago i bought a 126 aircooled with a tow system built in it consisted of a square box welded to the underside of the car with a hole to accept a bolt and a six foot length of twoXtwo box section with a trailor hitch on the front this ran down the centre line of the car and had a square welded to the top which lined up with the centre bolt on the front spring. easy to fit one bolt trolly jack and one reasonably fit lad can hitch it up lifts steering wheels of the ground alltogether turns 126 into a trailor lights can be wired acordingly and using trailer reflectors and tow car reg is used becomes a trailer under 750kg so towed by anyone with a driving liscence no need for brakes. also have a tow frame as described by someone else above , 126's don't like these ok for a few miles but really chews the front tyres up :o found out the hard way on a 30 mile journey through edinburgh.
tayto.king
« Reply #14 on: August 25, 2011, 09:03:59 PM »
Had a look under a 126 today & it looks like it'll work. Will be travelling a short distance with it from Gosport to Romford on saturday morning,about 110 miles :o Fingers crossed :D
