Author Topic: Gearbox query 2  (Read 3216 times)
punkydog
Gearbox query 2
« on: January 13, 2006, 09:17:44 AM »
Are the internals of a regular 126 gearbox the same as a Bis gearbox? I do actually mean the gearbox, not the diff, clutch or bellhousing. Spares seem to available for the aircooled 126 gearbox but none listed for 126Bis.
Brian
Darkhorse
Gearbox query 2
« Reply #1 on: January 14, 2006, 07:00:10 PM »
Apart from the actual gear ratios the box's are completely identical, the only differences are the actual ratios
punkydog
Ratios
« Reply #2 on: January 17, 2006, 12:57:58 PM »
126 suppliers have told me that the gearboxes are identical but the higher ratio is achieved with the diff.- not sure if the pinion gear is different.
If that isn't correct there will be a few gearbox repair items for an aircooled 126 on eBay soon.
Brian
paul harbinson.
Box
« Reply #3 on: January 19, 2006, 08:05:09 AM »
I thought the boxes were the same but did'nt want to say in case I made a numpty out of myself :D
Dante Giacoso, pure genius!
Gearbox query 2
« Reply #4 on: January 19, 2006, 10:26:12 AM »
Quote from: "Darkhorse"
Does that mean the bellhousings are the same as well?
Darkhorse
Gearbox query 2
« Reply #5 on: January 27, 2006, 06:25:14 PM »
The bellhousings are different, 500's have the starter sat up at the top, the 126 aircooled down to the side and the bis completely different again
