Author Topic: Transmission: for 126 aircooled 1989  (Read 2011 times)
AlleyNiki
« on: July 07, 2011, 12:34:23 AM »
Seeing as my back wheels locked I may be in need of a new transmission, or hopefully just the innards for the gearbox. The possible cause is a destroyed gear shaft bearing. I have spare bearings and a spare main shaft, but I don't know what the extent of the damage was.. :cry:
I'm in Australia but may just have to get something sent from overseas and wear the postage costs!
Will post again this week when I know what the problem is (taking it apart today).
Alastair
Re: Transmission: for 126 aircooled 1989
« Reply #1 on: July 11, 2011, 08:36:29 AM »
I have a gearbox in bits, maybe you could identify the offending items as postage might kill us.
AlleyNiki
« Reply #2 on: July 11, 2011, 09:50:41 AM »
Hi Darrell, thanks for responding so quickly!
I've opened up the gearbox and found .. no damage, and all the parts intact!
Basically I think the problem is the input shaft on top. It seems to be able to move - the bearing is sliding out about half a centimetre towards the front of the car, and when this happens this input shaft meshes with other gears and jams things up. (When in second gear, at least)
Also, I think the syncro tabs on the 2nd gear, lower pinion shaft were not held in properly. The spring clip seemed to have slipped off and when I removed the hub, they all fell out.
I put it all back and tried the gears out by pushing the selectors with my hands, and it seems to be fine - no jamming up any more but I need to prevent that shaft from sliding.
I'm not sure if I need any new parts at the moment, but cheers for posting. I'll post this up on the mech problems forum and see what people say.
Thanks! :)
Alastair
skelz
« Reply #3 on: July 11, 2011, 11:11:34 AM »
AlleyNiki
« Reply #4 on: July 13, 2011, 10:58:12 AM »
Thanks guys :),
It seems that I don't need new transmission parts after all. The jam up was caused by my transmission mount finally disintegrating and I've got a new one of those!
I will be looking for a sports exhaust however, if you guys know of a good one!
